Question about JBL (050036915083) (JBLONSTMWHT) Docking Station
My jbl docking station zyosm - 0821640 zy8c09 will
My jbl docking station zyosm - 0821640 zy8c09 will play my iphone ac/dc charger hooked to it but it will not play with just the battery hooked up and i have put in new batterys
SOURCE: JBL Radial Remote stopped working.New battery replaced no avail.
Turn on the JBL with the ipod in place, turn off at the mains plug, turn back on, turn on your JBL and the remote should work.
Posted on Mar 11, 2009
LCPLgeek
  • 125 Answers
SOURCE: compatibility issues iPhone 3G - JBL On Stage IIIp
hi there, believe it or not, apple has put a authentication chip into newer devices. It won't allow you to play music or display video on devices that are old. Apple wants you to go out and buy new accessories for the new stuff to make more money. My suggestion is to sell it on eBay and use the money to get a newer compatible dock with your iPhone.
Posted on Feb 18, 2010
SOURCE: My JBL docking station is no charging the ipods or
When you first got the speakers it should have came with a plastic insert that you put over the actual place you put the ipod on to charge. I know that you definetly need it for the movie playing ipods but not for the older ipods
Posted on May 11, 2010
SOURCE: i have a jbl docking
You can pick up an ipod docking station adapter here.
Posted on Nov 22, 2010
  • 4102 Answers
SOURCE: my i pod no longer charges when i plug it in the
Hi, this is a very common problem, its to do with all the little contacts on the dock that are causing it not to charge, over time and use these little thin metal contacs become warn and you then lose the connection with the device,
check the contacts on the ipod itself first make sure they are totally clean and no fluff or bits of rubbish are blocked in the port.
then check the docking station make sure its off with no power going to it then have a good look to see if you can see the contacts its not easy to fix or even see so you may need a good magnifying glass, so once you have one of these have a good look at each contact and make sure their is no fluff or anything else on one of the contacts, if their isnt then try the following.
make sure docking station is off and has not got any power going to it then using a magnifying glass have a real close look at the contacts then get a long pin and touch each of the contacts as if your tryin to scrape them clean with the pin, then give it a try, now if this still dont work the only other option to try and get it working is to only very slightly bend each pin so its connects with the ipod so if you have a close look at each one and bend it only very slightly outwards then give it a try again, doing this usually gets its working but if you bend them to much they can break and it will then be no good what so ever.
so have a go at fixing it but if it wont fix then the chance of getting it repaired is pretty slim.
let me know how you get on or if you need further assistance ok
Posted on Feb 07, 2011
How do I get music on my docking station through my iphone?
I would check to make sure you don't have a cable or headphones plugged into the Audio In jack. If not then I would suspect that you have a newer Ipod touch or classic that is not supported by this dock. Something changed a couple of models ago with ipods and the last two generations haven't been compatible on older devices meant to play through the dock connector. I have the same problem with an older Sony car stereo.
If you do have a newer Ipod then you can either get the patch cable to go from your headphone jack to the Audio in jack on the dock or you will need to get a newer dock.
https://docs.sony.com/release/ICFC1IP.pdf
Jun 05, 2014 | Sony ICF-C1IP (Black) Docking Station
Sony dock not working after iOS 6 update? Just says not an apple compatible product?? Any idea of an update or a fix on the way?
My wife had this problem with iPhone 4S after updating to ios6 on a Sony xdr-ds12ip docking station. Sound would play on iPhone off the docking station, but once it was docked no sound would come through the docking station speakers (docking station radio works fine, as did the iPhone before the iOS update). Fixed it by powering down both the iPhone and the docking station at the mains, gave it 2-3 minutes and then powered on the docking station and then the phone. Placed the iPhone in the docking station and voila the sound comes out of the speakers now.
Sep 29, 2012 | Audio Players & Recorders
Dell duo station
I had the same issue. I tried opening the dock and could not find anything wrong. It seems the charger was delivering sufficient voltage. So I disconnected power to the charger and reconnected couple of times and it started working again. My charger has a LED light and based on the brightness of the light you can findout if the output voltage is close to 20 volts.
Sep 20, 2012 | Dell Jbl Inspiron Duo 1090 Audio Station...
My iphone 3GS is not been charging when I dock in JBL On Time 200P and it used to charge just fine. This happened after I used in a travel a hotel iHome as my charging dock, and then a wall charger for...
It seems an issue of the dock connector of your Iphone, please check if there's no contact blocked or bended, if there's one or more contacts with these conditions, you may need to replace the dock connector of Iphone.
Feb 24, 2011 | JBL On Time Docking Station for Apple iPod...
Compatibility issues iPhone 3G - JBL On Stage IIIp
Feb 17, 2010 | On Stage Stands JBL On Stage IIIP Portable...
What ac/dc adapter do i use with the creative
check this one, they have power adapter for cambridge soundwork dock
http://www.findpowercord.com/ac-dc-power-adapter-for-cambridge-soundworks-i-dock/
Oct 24, 2009 | Creative Technology Cambridge SoundWorks...
Ipod nano not charging on jbl docking station 2
my apple ipod is not charging what should i do plz help me [nano 3rd genaration]
Jun 07, 2009 | Apple iPod touch
Getting error message software not compatible with IPod
This compatibility issue is caused by the same change with the Apple Dock Connecter introduced with the iPhone 3G. Inside the iPod / iPhone Dock Connecter are 30 metal pins. Previous iPods and iPhones allowed for charging either over pins reserved for the USB connection or pins reserved for the obsolete Firewire connection.
While Apple apparently announced this upcoming change to manufactures of “Made for iPod” accessories back in 2005, Apple only formerly discontinued Firewire charging support with the most recent iPods. New iPods and iPhones can only charge via the USB pin.
As such, there is no way that a software update can fix this issue in the future; this is truly a modification in iPod hardware.
Dec 22, 2008 | JBL (JBLRADIALWHT) Speaker System, Docking...
JBL (050036915083) (JBLONSTMWHT) Docking Station Logo
127 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Vito Vacirca Jr.
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
