Question about Sony Televison & Video
All the buttons on my RM-GD005 work correctly EXCEPT the rocker switches to scroll through stations and the volume - (the little round mute button is not working either. The Buttons that work all light up the little red TV light at the top of the control - the buttons that do NOT work don't do this. Functioning of the "bad" buttons sort of phased itself in - they got a little hard to use - only eorked intermittently - then conked altogether.
  • malolo2 Apr 04, 2011
    Thanks - that sounds like the right answer actually - makes good sense anyway. Unfortunately I can't open the remote to get at the circuit board! I found two little cross point screws under the battery cover - but undoing these does NOT seem to loosen anything. Tried sliding the top back as well as pulling them apart - but short of damaging it I really can't open it. Almost as if the beast was cast in one piece. A new "original" is horribly expensive - there is supposed to be an "electronically identical" substitute for about a quarter the price - or I could try a universal. Had some bad experiences with a universal a couple of televisions back - it lost its programming all the time and it was very fiddly to get it back. Can you think of any likely tricks to get it open? Otherwise I might just have to get a substitute.
  • malolo2 Apr 05, 2011
    Yes
    President:
  • 2,080 Answers
Your remote control's internal button contacts on the circuit board may just need cleaning. If there is some residue, or debris, or oxidation inside on the surface of the circuit board it may be interfering with the correct operation of only a few buttons in particular.
It does not sound like a battery connection issue or a bad transmitter since most of the other buttons work fine.
You can try unscrewing, and disassembling the remote control in order to access the contact pads on the circuit board.
First check if there are any screws holding the remote control halves together. Be sure to open up and look inside the battery compartment as well. Once all the holding screws are removed, then gently pry the two halves of the remote control apart.
Use a cloth or a paper towel and some Isopropyl alcohol to clean off the surface of the circuit board and the underside of the button pads. Now check the circuit board for any signs of excessive wear, cracks, or oxidation on the copper contacts. You can use a pencil eraser to gently polish the copper contact pads on the circuit board if necessary. Once the unit is cleaned, just reassemble it and replace the screws and then try it out.
If you did see any significant damage inside or cracks in the circuit board, then you are probably going to have to eventually replace the remote. A wide variety of universal remotes to suit your needs and budget are available at any decent electronics store.
Please comment back here to this page if you have any questions, or just require further general assistance and I will respond as soon as I see it.
Thank you very much and good luck.
Posted on Apr 04, 2011
  • Joe2
    Joe2 Apr 04, 2011
    Yeah, some of them can be tricky to open even when the screws are removed.
    There are usually a bunch of little plastic tabs inside that keep the two halves together. The trick is usually to start at one end, usually then battery end, and pry open the two halves a bit with a flat head micro screwdriver.
    Start wherever you can find a little bit of play and pry open a gap, then just run the screwdriver along the gap until you get to a spot that is held together by one of the interior tabs. Then use the screwdriver or your fingers to try popping each tab loose in turn and the two halves should eventually come apart.
    Just try not to gouge the plastic too much or snap the little plastic tabs inside off completely. If you can't get it apart, that's fine, some are a lot more difficult than others even with experience.
    You could always opt for the universal remote. Although I would stay away from the really cheap universal remotes and I would certainly not bother paying full price for a factory replacement. Just get a really good dependable one from Logitech Harmony, or Sony, or a similar brand that comes with with good documentation, service, and product support. It makes a huge difference compared to the old cheapo ones. Then you can use it for all your electronics and it will be a pleasure to use for years to come.
    Good luck.
    Joe.
Where is the ipad mute button cant get any sound fron down loaded war game
The mute switch is on the right side of the iPad. Check your switch settings first:
Tap Settings > General.
Under "Use Side Switch to:", select Lock Rotation or Mute.
Settings > General
Make sure you're using it to mute, and then slide the switch to toggle mute on and off. Also use the volume rocker in case you have the volume set too low.
Nov 03, 2011 | Apple iPad with Wi-Fi + 3G (Choice of...
Volume on G E model 21028GE3-4
To adjust the speaker volume, press up/down on the base unit.
To change the ringer volume:
Make sure your phone is OFF (not in talk mode).
Press the MUTE/PROG button to go to the main menu.
Press CID/VOL (up or down) button to scroll to "HANDSET SETUP".
Press MUTE/PROG button to confirm.
Press CID/VOL (up or down) button to scroll to "RINGER VOLUME".
Press MUTE/PROG button to enter the menu. "SET RINGER 1HI 2LOW 3OFF" shows in the display.
Use the touch tone pad on the handset to select 1, 2 or 3, or use the CID/VOL (up or down) button to scroll to your selection. HI is the default setting.
Press the MUTE/PROG button to save your selection. You will hear a confirmation tone and the new volume setting shows in the display.
To change the receiver volume: When the handset is ON (in talk mode) you may adjust the receiver volume by pressing the CID/VOL (up or down) button.
If you need a manual, you can download one here.
Oct 06, 2011 | GE 21028GE3 Cordless Phone
My device is not working intead of shoing my banner it is showing not registered !?
What is the name and model of your device that is showing not registered?
I look forward to your reply......
Bye for now.
Apr 07, 2011 | GE Lands Phones
How to set date and time on GE 6.0?
Instructions:
- Remove the handset from the charging unit. Press the "Mute" button to enter the "Main Menu."
- Use the "Volume Up/Down" buttons to scroll to the "Set Day/Time" sub menu and press "Mute" to enter it. "Monday," the default day of the week will flash on the screen.
- Use the "Volume Up/Down" buttons to scroll to the correct day of the week. Press "Mute" to select.
- Use the number buttons to enter the correct four-digit time. Press the "#" key to switch from AM to PM.
- Press the "Mute" button to save the settings and exit setup. The correct day and time will now be displayed on the screen.
or you can visit this website
http://www.ehow.com/how_6974003_set-ge-28801-cordless-phone.html
Mar 19, 2011 | Uniden Cordless Phone
How do I change the time?
You MUST do it at the Main Extension handset - usually 101.
With the handset on the cradle:
Press Program button
Enter *#
Enter the system password - system default is 1234
Enter 000
Press the Auto Dial/Store button
Enter date using the Scroll button (the round one used for spkr volume) to move to right and left to next field
Press Auto Dial/Store button to accept setting
Press Redial button to move to time
Enter time using Scroll button (the round one used for spkr volume) to move to right and left to next field
Press Auto Ans/Mute to exit Date & Time
Press Program Button to complete
Feb 12, 2011 | Panasonic KX-T7731 Corded Phone
Just got the CD445 Base Station. Red light keeps blinking
press the cid button then press menu then scroll through your missed calls then hit exit
Dec 26, 2008 | Philips ACCESSORIES & S60202 Earbud/Line...
Setting preset radio stations
Hallo, I had the same problem and found following solution: first search the station you want to preset. Than put the the little round button below on the right side called enter/time and on the same time the button of the number of the memory preset you change.This number will appear in the display an remain the preset. Sorry about my English - I hope you understand however.
Feb 04, 2008 | Sony SRF-M10 FM Radio
Love my new Saitek Keyboard, but I don't what some of the buttons do???
You can download a manual here: http://www.saitek.com/manuals/eclipse_manual.pdf For the 1, A, and Down Arrow: My guess is that these are actually the indicator lights for Num Lock, Caps Lock, and Scroll Lock. For the four silver round buttons: The top right corner of your Eclipse keyboard features a set of controls for changing your computer?s audio volume and the brightness of the Eclipse Keyboard?s backlighting. To reduce audio volume, press button A until the desired volume level is reached. To increase volume, press button B. To mute the audio output, press button C and press it again to cancel mute. Press button D to control the brightness of the backlighting. Press the button to scroll through lights off, lights full brightness and lights half brightness.
Apr 18, 2007 | Saitek PZ30AU Keyboard
Televison & Video Logo
3,661 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
