Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Suction, after cleaning every part/filter, is virtually non-existant, other than the motor (which works very well) when reassembled various times, I get a big 0 for performance. PO'd in Tx. DC-07 seemes to be a waste of my $$$$.
  • 710 Answers
Did you dry the filter for 12 hours before reinstalling and giving a go? Most suction problems are from a blockage of some kind. The Dyson website seems to think it's the filter.
Here is a website which has instructions on washing the filter: http://www.dyson.com/support/help.asp?article=1464&product=DC07-SY-HEPA_US
Hope this works for you. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Posted on Apr 04, 2011
Ther is no suction in the power tool hose . the soap is dispensed but no suction or at best a very very very faint suction
This sounds like a clogged Lint Filter. The filter (looks like a screen) is located on the Tank Cap. Remove it and clean and put it back. Don't run the unit without the filter. If that doesn't work then try the Flow Indicator Filter (Turn the Flow Indicator cap counter-clockwise to remove it, lift out the rotor and filter. Clean filter and reassemble in reverse order. You can contact Bissell Consumer Care at 1-800-237-7691 for a person to person contact if you need more assistance.
Sep 23, 2015 | Bissell Proheat Upright Carpet Cleaner...
Hoover S3639 Suction Failure/Turns itself off and restarts later
If you did all this already the motor is not having power, must be replaced.
Sep 06, 2008 | Hoover S3639 WindTunnel Bagged Canister...
No suction only the blower works its a canister model
Loss of suction is invariably caused by a blockage. Sometimes I have needed to rod out the hose but mostly servicing the filters are what is needed.
Filters generally remain fairly clean but some spillage of bag contents due to over-filling or a burst bag can block a filter in a very short time.
It isn't unusual for users to remove the filters for better suction but the next time the bag bursts the contents are sucked through the motor and sprayed back into the local atmosphere. It is often the ruination of the motor.
Feb 25, 2015 | Vacuums
I have a Hoover Wind Tunnel Self propelled 12amp. There seems to be very little suction. I have cleaned the hoses and filters but still not much suction. any ideas? thanks.
Make sure all filters are cleaned out and entry ways are clear of all debris. Remove hose and check for blockage. Usually the low suction can be remedied when all filters are cleaned. Hope this works for you.
Jul 17, 2010 | Hoover Self-Propelled WindTunnel Bagless...
I have a dyson dc 17 what is the best way to thourghly cleaning , so I can get better suction , also do you have a instruction manul to. I seem to have misplaced mine thanks
The first step towards improving the suction is to clean the circular HEPA filter. The filter also houses a circular sponge which should be rinsed and dried before putting it back. Check the HEPA filter to see if it needs replacement -- will look muddy! Another quick check is to remove the HEPA filter, run the vacuum cleaner momentarily in upright position to check if suction is restored at the hose end.
After doing this if suction is still poor or non existent, you should detach the transparent canister - a bit tricky since the release rod for the flap has to be aligned when you want to reassemble the unit.
Once the canister is removed, you should check and clean the center tube/shaft for any clogged dust (use a wire coat hanger if needed to pry out the dust). This tube gets clogged if the vacuum cleaner was used to pick up damp/wet spills etc.
Sep 30, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
The suction on my eureka optima stopped working but the roller still works, what might i do to fix it?
Hi there. Most suction problems are due to a blockage. Start with the base and look carefully for debris that is stopping air flow. You may have to remove the base plate to get to the problem. I am including a link to the manual for your machine. look on page four so see how to remove the base and check for blocked airways. http://www.eureka.com/service/manuals/75287_eng.pdf
Aug 19, 2009 | Eureka 431A Optima Bagless Upright Vacuum
Poor suction
This page has useful tips for unclogging a central vac. https://www.centralvacuumstores.com/cvs/trouble_help.php
Feb 01, 2009 | M&S Systems FX-3000 Bagged Central System...
No suction
have u checked all of the filters. I know that when not all the filters r clean the machine will turn on but then it will sound louder and still have no suction. Most times there is a filter under dirt container thats sits above motor and if this filter is not clean the motor cannot breath. Thus no suction
Sep 29, 2008 | Hoover U6630-900 WindTunnel Bagless...
Not picking up
Did you check down by the brush roll? If the hose has suction, then the problem has to be in the nozzle asm. The hose having suction tells you that the main part of the vacuum is working ok.
Mar 17, 2008 | Eureka 7618 Bagged Upright Vacuum
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
