Question about Microsoft Windows 7 Home Premium 64BIT Operating System Software OEM DVD
Security holes problem! - Microsoft Windows 7 Home Premium 64BIT Operating System Software OEM DVD
  • Microsoft Master
  • 13,433 Answers
Retarded person problem
Posted on Apr 04, 2011
I would like to reverse the door on my Zanussi ZDC68560W dryer
REVERSIBILITY OF THE DOOR
Proceed as follows:
    1.Remove the screws which secure the hinges to the cabinet (fig.A.1). Remove the door.
    2.Remove the screws which secure the hinge hole masking plates (fig.A-2) and fit the plates to the holes to which the hinges were previously fitted (fig.A-1).
    3.Remove the canister.
    4.Remove the work top.
    5.Remove the left- and right-hand panels.
    6.Remove the front panel hole cap (fig.A-4). To do so, squeeze together the anchor tabs which secure it to the cabinet.
    7.Remove the screws which secure the door interlock (fig.A-3) to the cabinet and remove the lock.
    8.Detach the connector from the door lock.
    9.Remove the tapes from the wiring (fig. B) and separate the wires for the door lock from the remaining wires.
    10.Re-tape the remaining wiring.
    11.Insert the general wiring harness into the support(s) positioned on the duct (fig. C) and position them parallel to the front panel so that they cannot come into contact with the drum. Attach to the anchor using a wire tie.
    12.Insert the door lock connector between the drum and the canister container, then remove it from the position shown by the arrow (fig.D-1).
    13.Insert it beneath the front brush cover (fig.D-2), secure to the anchors on the duct (fig.D-3), and remove the wiring from the other side of the cabinet.
    14.Insert the door lock connector and secure with screws to the front panel (fig.E-5). Ensure that the wiring is not trapped between the door lock and the front panel.
    15.Check that the wiring is routed through all the anchors released when removing the door lock wiring.
    16.The excess section of the door lock wiring should be secured using a wire tie to the wiring cover (fig.D-6). Fit the masking cap into the hole from which the door lock was removed (fig.E-4).
    Dado
25637655-hcssld2gpo2sm22yg24xoxcy-3-2.jpg 25637655-hcssld2gpo2sm22yg24xoxcy-3-5.jpg 25637655-hcssld2gpo2sm22yg24xoxcy-3-9.jpg
Apr 09, 2015 | Zanussi Dryers
Security lot slot
Security ?lot? slot...
Do you mean security lock slot? There is a hole at the back of the computer which takes a device called a Kingston lock which is used to secure a laptop to a desk to prevent theft.
It looks like this
Jul 06, 2014 | Toshiba Satellite L500 Series Notebook
Why won't the thermostat fit secure on the hole
the thermostat usually just fits in the groove of the housing, they aren't usually very tight as you can just pull them out by hand, make sure that you have the right one for your vehicle.....cheers.
Sep 10, 2011 | 2000 Pontiac Grand Am GT
How does the tv mount?
1- remove the wall plate from the arm.
2- fix the front plate to the back of your television.
3- mark the position of the holes and drill
4- put wall plugs into holes.
5- secure the wall plate to the wall
6-attach the arm to the wall plate.
7-hang the screen on the arm (i recommend having someone help) and secure it in place
Mar 05, 2011 | OmniMount "OmniMount 23" to 42" 4in1 Flat...
My keyboard has 2 threaded holes in the bottom that look like they'd be used to attach it to a stand. So...how do I secure it so it doesn't fall off when my dog bumps the stand?
Unless the stand was specifically made for the Casio, the holes probably will not line up with anything. You can COUNT on them being Metric threaded and you have to be careful to not put too long screws in the holes. If you stand doen't line up with the holes, best to secure a piece of plywood to your stand first that is drilled to match the synth and attach the synth to the plywood. I don't know how your stand is made so I can't give you more details.
Jan 09, 2011 | Casio WK200 76Key Digital Keyboard
Problem with the 2004 Land Rover FreeLander How to install a Freelander Window Regulator with cable loose not broken just off winder
Tools you will need:
1. Panel removal tool
2. Philips screw driver
3. 1/4 Ratchet with extension and 8 mm socket.
4. grease to lube new regulator. The first thing, is to remove the door panel:
1. Remove 2 screws securing hand rail to door.
2. Remove screw securing door handle escutcheon to door and remove the escutcheon.
3. Remove 4 screws securing pocket to door.
4. Carefully release 10 clips securing trim casing to door. (Best to use a door panel removal tool, the plastic clips break very easy)
5. Disconnect multi-plug from upper door speaker. Do the same for lower speaker
6. Remove trim panel from door.
7. Remove the plastic vapor barrier , care full not to destroy. (You may have to cut around some things such as the hand rail brackets.)
At this point you will be able to see the regulator and motor through the small holes in the door. At this stage a small flash light is very handy
to see such things as the power connector for the window motor.
1. Loosen the two bolts in the slotted holes, shown above.
2. Remove the remaining 4 bolts securing regulator assembly to door.
3. Lower glass and loosen the 2 bolts securing door glass to regulator. Then slide the channel bar forward to remove.
4. Disconnect the power from the window motor.
5. lift the window and secure in the up position ( I used Duct tape).
6. Collapse all the arms and maneuver the old regulator out the center hole in door. Assembly is basically the reverse of the removal procedures:
1. take the two screws that you partially removed out of the old regulator and install them partially install them into the new regulator.
2. Work the new regulator through the center hole.
3. Connect the power to the regulator motor.
4. Lower the window glass, take the channel that secures the glass to the regulator, insert it over the tow bolts that were loosened in step 2 above
5. Raise the window and secure.
6. Insert the 2 bolts on regulator through the keyed holes in the door and finger tighten.
7. line up the rest of the bolt holes and install the remaining two bolts in both the regulator and then tighten two bolts in step 6 above
8. install the two in the bottom channel.
9. Now is a good time to test..........
Then all that is left to install the hook up the speaker(s) and mount the door panel.
1. Position trim panel close to the door and connect door speaker(s) multi-plug(s).
2. Secure door panel to door with clips.
3. insert escutcheon to door handle and secure with screw.
5. Fit pocket to door and secure with four screws."
Dec 04, 2010 | 2004 Land Rover FreeLander
What holds the 3 pin connector in the bottom of a shure bets 58? it won't stay in...How do I secure it?
there is a small screw in the side of the xlr connector and a small hole in the body of the mic.put everything together until you see the screw thru the small hole.tighten the screw clockwise and the job done!
Jan 06, 2010 | Shure Beta 58A Professional Microphone
I forgot my security enabled password
Reset the router to factory defaults. Look for a hole/button on the router near which it says RESET. If a button, press it; if a hole, use a blunt paper clip to insert in the hole and press gently. Router will be reset to factory default and you will have to reconfigure it to secure your network.
Hope it helps.
Aug 30, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
I have a WRT54G router and set up security when I
On your router, look for a button or a hole near which is written reset. Press the button or use a blunt paper clip to introduce inside the hole. After resetting, the router state is returned to factory default.
Hope it helps
Aug 30, 2009 | Linksys Computers & Internet
Microsoft Windows 7 Home Premium 64BIT Operating System Software  OEM DVD Logo
20 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
