Question about Samsung WF337AA Front Load Washer
My Samsung vrt washer has a foul smell whenever I wash a load...I can wash it in hot water warm water and cold water....This is not solved there is still a foul smell.. I used Borax, sanitizer (tide), bleach and nothing seems to work....I need help!!!
  • Samsung Master
  • 1,583 Answers
You may have a biofilm buildup in the tub that is too thick to be removed by splashing it with your cleaner. The owner's manual says "Clean the interior of your Washer periodically to remove any dirt, soil, odor, mold, mildew, or bacterial residue that may remain in your Washer as a result of washing clothes. Failure to follow these instructions may result in unsatisfactory conditions, including unpleasant odor and/or permanent stains on your Washer or laundry. Hard water deposits may be removed, if needed. Use a cleaner labeled "Washer safe". "
I take that to mean you'll need a bucket of soapy water, rubber gloves and a sponge or rag to manually scrub the tub and door. Don't neglect the gasket, especially around the edges. Run a rinse cycle to finish the job. If you still have odor, run a rinse with the sanitizer and the SilverCare option; perhaps the silver will take out the remaining bacteria on the outer tub. As a last resort, you may have to disassemble the machine to hand-scrub otherwise inaccessible parts in contact with wash water.
If you use well water or city water with little or no chlorination, you may have bacteria in the water lines to the washer. This may make the water itself stink. To check for this, shut off the external water supply valve to the washer, disconnect the hoses and place them in a large (5-gallon) bucket. Turn on the water supply briefly and sniff. If the water is bad, you'll need to run it at full rate into the bucket to flush the lines, then consider installing an anti-microbial filter in you household plumbing. Also, check the inlet strainers where the hose connects to the machine. If they are clogged or loaded with slime, this will slow the flow rate and make it easier for bacteria to hang on inside the hoses.
Another possibility is a bad reaction between a chemical contaminant in the water and your laundry detergent. You can test for this by stirring a bit of the detergent into the bucket of sample water.
Posted on Apr 04, 2011
Why is my samsung vrt steam washer leaking from the bottem right model #WF331ANW/XAA
Locating And Repairing A Mystery Leak In A Front-Loading ...
? 3:55
www.youtube.com/watch?v=3D5q1ynWb-U
Jul 28, 2012 - Uploaded by SamuraiRepairman ... source of a leak in a front-loading washing machine and then mercilessly repairs it. ... LG Washer Repair & Diagnostic -Leaking Water from front & bottom ... Samsung Front-LoadWasher Disassembly - Washing Machine ...
Samsung vrt steam washer leaking - Fixya
www.fixya.com/support/t13638559-samsung_vrt_steam_washer_leaking
Jul 15, 2012 - Samsung vrt steam washer leaking - Samsung WF338AAB 4.0 cu. ft. ... I have a vrt ... I hope this helps.... Take of that little door on the front. Have a ...
Oct 29, 2015 | Samsung Washing Machines
Cold/cold cyle wash water not cold
try to do cold cycle first without doing warm cycle first
Apr 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washer water temperature is wrong
i would guess that if you actually have hot water at the faucet it is connected to, the the inlet hot water valve is defective in the washer. seems like a lowes exchange to me.
Jul 22, 2015 | Samsung 4.5 Cu Ft Capacity White Top Load...
Samsung WF210 not draining
Unplug the washer and check for all kind of clogs in drain hose and check for clog in hose from tub to pump and remove the pump and check for dirt and junk inside pump clean the pump with warm water and test pump for continuity as the pump running properly other wise replace it with the new one and reinstall it ,it should solve problem
Jul 10, 2014 | Samsung 3.5 cu. ft. High Efficiency VRT...
Error code of NF (no fill) on samsung top load washer (WA422PRHDWR/AA) even after checking lines for restrictions and ensuring clean line filters (red and blue). Now, when it does work, it will only do a...
Put the temp select switch on HOT, start machine. If water comes out check the flow amount. If no water flow, replace inlet water valve. If there is water flow switch to COLD, start machine. If water comes out check the flow amount should be approximately equal or slightly more than flow on HOT. If no water flow, replace inlet water valve. Move selector to WARM, start machine. Now there should be twice the flow of water than there was with HOT and COLD temps. I suspect it is the HOT side of inlet water valve that has failed because machines usually rinse with COLD water.
Jan 20, 2013 | Samsung WA422PRHDWR 4.2 Cu. Ft. VRT Top...
Water temperature control not working
the fill hoses are backwards,,,reverse fill hoses...on the job...also your under warranty ..call for service but you can do it your self..
Jan 17, 2009 | Whirlpool LTE6234D Top Load Stacked...
Hot water doesnt work, switch to warm and warm comes out.
If the cold works on cold wash but the hot don't work on hot wash . Then yes the switch is bad.give What model is it?
Jan 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Samsung WF337AA Front Load Washer Logo
1,944 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
