Question about GE Refrigerators
Compressor turns on (GE profile arctica PSS255GNABS) when power is turned on but then turns off within 5 min
  • 74 Answers
SOURCE: I have a GE Profile,model PFS22SISBSS,3 years
Possible main pcb failure failure which would cause everything to cut out and restart . Is the compressor or back of the appliance hot ?? Do all the control lights go out when the compressor cuts out ??
Posted on Feb 26, 2009
  • 531 Answers
SOURCE: ge profile arctica (pss25ngna) dos not cool down
you may have compressor problem call service
Posted on Apr 07, 2009
Sea Breeze
  • 4655 Answers
SOURCE: GE Profile Arctica PSS25SGNA BS Icemaker is not
The water dispenser and ice maker side run separate sides of the water control valve. Fill ice maker with tap water and let it freeze. If it dumps the ice then does not refill then the water control valve is the problem. I will be back soon with a photo and some links, Thanks, Sea Breeze
Posted on Nov 18, 2009
SOURCE: my ice maker will not work, Ge profile Arctica.
ICE MAKER MAKES ICE, DISPENSES WATER BUT DOES NOT DISPENSE ICE WHEN HANDLE IN DOOR DEPRESSED. REMOVED TRAY FROM FREEZER, WASHED ALL ICE OUT OF TRAY AND CHECKED ROD FOR FREE MOVEMENT REPLACED -TRAY--- STILL DOES NOT WORK..
Posted on Dec 30, 2010
SOURCE: GE Profile Arctica model # PSS25NGMD - can't control temperature
Check the little damper door next the water filter at top inside the unit. You will have to remove the covers to get it. The little plastic ends will break off and then you can not control the temperture it act like a freezer. Hope this helps Also you can get this part online.
Posted on Jan 31, 2011
Profile Arctica, Air flow fan runs but compressor dont kick in to make anything cold!
1. is light on in side when you open the door. If not check breakers or fuses.
2. Can you hear the compressor running. If not do you hear any clicking sounds.
3. If you hear clicking sounds, try putting a fan on compressor and unplug refrigerator.
4. Wait one hour.
5. plug back in. If compressor starts let it run and see if it cools, if it doesnt, call service man.
6. If it goes back to clicking, call a service man.
try this.
Feb 23, 2011 | GE Profile Arctica 25.4 Cubic Feet...
Ge profile artica profile freezer on top -- refrigerator clicking and not cooling
Check compressor is working. If not, replace relay and check. If still compressor not working, you have to replace compressor.
Feb 12, 2011 | GE Profile Arctica 25.4 Cubic Feet...
Have a GE Profile Arctica that is a few years old. It is "clicking" every couple seconds, like turning off and on constantly. I have been gone for a week if that matters. The HRS light is...
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. The relay is a small usually black cube shaped electrical part plugged into the compressor or wired to it nearby. It may appear burnt or rattle when shaken if it's bad. The two connections should show continuity with an amp meter. If it's good then it's most likely the compressor causing the problem.
Dec 29, 2010 | GE Profile CustomStyle PSI23SCR Stainless...
Freezer n refrigerator is warm at 78 degrees
If the compressor is running it either has broken valves or the refrigerant has leaked out. Without knowing more than the information you've provided I would start with the basics. Does the fridge have power? Can you hear both the condenser and evaporator fans running? Have you checked the coils under the fridge to see if they are clean?
Jun 21, 2010 | GE Profile Arctica Stainless Steel Top...
Ge profile artica is not working. how do you change the fuse?
I believe fridges doesn't use fuses. Compressors uses a thermal protection (a breaker) located next to it, it should be next to the compressor. The compressor is located in the back of the appliance, the lower side.
Nov 05, 2009 | GE Profile Arctica Stainless Steel Top...
Top Freezer Not Cooling...Fan Running...everything thawed :(
Check the thermostat in the refrigerator and make sure it's not accidently turned to the defrost mode
Jan 08, 2009 | GE Profile Arctica Stainless Steel Top...
GE Profile Stainless Steel Top Freezer Refrigerator
Check the compressor.
Unplug for 15-20 min. plug it back in and listen for the compressor to start. You will have to be behind the ref to listen and make sure you hear the compressor start and not just a fan running. If you hear a clicking noise then the compressor relay is bad.
Dec 16, 2008 | GE Profile Arctica Stainless Steel Top...
Refrigerators Logo
59 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
