Question about Sanyo Cell Phones
How do I get the lock key code? - Sanyo Cell Phones
  • Sanyo Master
  • 13,433 Answers
Take it to your dealer or service provider or contact the manufacturer for support.
Posted on Apr 04, 2011
2000 Trooper LS. Why won't the ignition key unlock any of the doors? (the metal key part)
  • Some of the locks have been probably changed before.
  • Or you need to get original keys for truck, copies just get worn out by use.
Here a link to your SUV manufacturer:
Good Luck!
JP
Help Isuzu com
Jul 13, 2015 | Isuzu Cars & Trucks
Hi my names Trevor. I need to get the lock code from my truck so i can get a new key since i lost mine. I was hoping you could tell me exactly where this lock code is at... Thanks
Hello trevor
The best way to get the correct key made is to remove another lock that the lost key operated and
take it to a locksmith, they will make you a key for about $10.00. Either of the door locks will have
the code stamped on them, or if you have a locking glove box or console that locked with the ign.
key these may have the code stomped on them. Hope this is helpful.
Feb 09, 2011 | 1984 Toyota Pickup Deluxe
Lost key to "81" honda goldwing GL1100 standard
hi, you are more likely to find the key code on 1 of the other locks on the bike like the seat lock, if you can remove the seat, and the lock, in the old days manufactors would put the code on the lock normaly wher you cant see it a good locksmith will make you a key if you take him the lock, paul
Jan 18, 2011 | 1981 Honda GL 1100 Gold Wing
Central locking went on my lexus took it the garage they said the key wouldn't reprogramme is there anything that can be done
Programming
When
Key added or replaced. System malfunction.
How
Driver's door open and key removed from ignition switch. Insert key into ignition switch, then remove it. Within 40 seconds: Press lock and unlock on the vehicle door lock control switch at 1 second intervals 5 times. Close and re-open driver's door. Within 40 seconds: Press lock and unlock on the vehicle door lock control switch at 1 second intervals 5 times. Insert key into ignition switch. Switch ignition ON and OFF once to program a new key code whilst retaining the original codes or twice to program a new key code whilst erasing the original codes. Remove key from ignition switch. System should now lock and unlock vehicle, once or twice depending which mode has been selected. Within 40 seconds: Simultaneously press and hold key lock and unlock buttons for a maximum of 1,5 seconds. Within 3 seconds: Press any key button for a minimum of 1 second. System should now lock and unlock vehicle once.
Manufacturer: Lexus Model: IS 2,0 200 Engine code: 1G-FE Output: 114 (153) 6200 Tuned for: R-Cat Year: 1999-05
© Autodata Limited 2009 25/02/2010 V8.207M-ukad113581
NOTE: If system locks and unlocks vehicle twice, programming procedure has not been completed. Repeat programming procedure.
Within 40 seconds: If required repeat button procedure to program remaining keys.
NOTE: To exit programming mode: Close driver's door or insert ignition key. NOTE: A maximum of 4 keys can be programmed
Feb 25, 2010 | Lexus IS Cars & Trucks
I want to put password for my Nokia N73 mobile
  1. Press the Nokia Menu key to the left of the 1 and 2 keys then choose Tools.
  2. In the Tools screen click on Settings
  3. In the Settings screen click on Security
  4. In the Security screen click on Phone and SIM
  5. Scroll down and select Lock Code
  6. Now type ‘12345’ and then choose OK with the left Selection key. ‘12345’ is the default lock code for the Nokia N73
  7. Next type your new lock code then choose OK with the left Selection key. Your lock code can only include the numbers 0 to 9. You will be asked to enter it again. Do this then choose OK with the left Selection key again. You will see a message that says ‘Lock code changed’
  8. Next click on Autolock period. You can set your phone to lock itself automatically after a period of inactivity. To do this click on User defined with the scroll key. Now enter the number of minutes after which you want the phone to automatically lock itself and choose OK with the left Selection key
  9. You will have to enter the lock code you set up and then choose OK, and finally you get the message ‘Code accepted’. Now after the period of time you set the Nokia N73 will lock itself and a screensaver will appear to show that it is locked
Unlock the phone
To unlock the phone select Unlock with the left Selection key then type the lock code and choose OK with the left Selection key. The message ‘Code accepted’ will appear and you will be able to use the phone.
Disable autolock
If you decide you want to disable the autolock the go back to the Security Settings screen (see above), scroll to where it says Autolock period then click with the Scroll key and click. Choose None. You will need to enter the lock code and choose OK with the left Selection key. The message ‘Code accepted’ will appear and the Autolock period will be reset to ‘None’.
Oct 09, 2009 | Nokia Cell Phones
Trying to find a key code location for 89 toyota tercel hatchback one key fits all
Hello
I did a key code search on a 1993 toyota corolla . The key code was located on the passenger front doors lock cylinder (door lock tumbler). You have to disassemble the door panel and remove the lock cylinder from the door to read the tiny numbers on the lever of the lock cylinder..I would recommend calling your local toyota dealer and confirming it is on the lock cylinder before tearing apart the door....You would have to give them the code to get a new key cut. hope this info helps..
Apr 04, 2009 | 1989 Toyota Tercel Liftback
2000 contour
for 98 contour issue. TSB 98-21-14 not covered by warranty
This TSB article is being republished in its entirety to include the 1999 Cougar . ISSUE: The ignition key may be difficult to insert or remove and/or key chimes may sound with the ignition key removed and driver's door open on some vehicles. This may be caused by internal design characteristics in the ignition lock cylinder increasing insertion/removal efforts which may allow the lock cylinder to stick.
ACTION: Install a revised ignition lock cylinder. The revised ignition lock cylinder should reduce the possibility of high insertion/removal efforts and ensure proper chime function. Refer to the following Service Procedure for details.
SERVICE PROCEDURE
  1. Verify customer concern.
  2. Observe the ignition lock cylinder as the key is removed. If the lock cylinder snaps outward to the non-depressed position and the chimes stop sounding, continue to Step 3. If it does not snap outward, replace the ignition lock cylinder with the appropriate cylinder by referring to the Parts Block in this article.
  3. Insert and remove the ignition key from the lock cylinder. If binding or high efforts are encountered, replace the ignition lock cylinder.
  4. From the Parts Block, select a lock cylinder with a part number suffix identical to the center character of the key code of the vehicle. The suffix must match the center key code character to maintain a single key system.
  5. Install the replacement lock cylinder, by referring to the 1998 Contour/Mystique Workshop Manual, Section 211-05 or the 1999 Cougar Workshop Manual, Section 211-04. NOTE: KEYS INCLUDED WITH NEW IGNITION LOCK CYLINDERS ARE CUT FOR THE IGNITION ONLY. IN ORDER FOR THE KEYS TO FUNCTION IN THE DOOR LOCKS, THE KEYS MUST BE CUT TO THE DOOR CODE OF THE ORIGINAL LOCKSET. THE KEY CODE WILL CHANGE UPON INSTALLATION OF THE REPLACEMENT LOCK CYLINDER (FIGURE 1).
    Figure 1 - Article 98-21-14
    NOTE: ADVISE THE CUSTOMER TO DISCARD ALL KEYS THAT WERE CUT TO THE ORIGINAL IGNITION LOCK CYLINDER.
  6. Record the new key code on the repair order and provide to the customer. Advise the customer to record the new key code in a permanent location and to discard all references to the original key code. NOTE: REPLACEMENT IGNITION LOCK CYLINDERS ARE SHIPPED WITH NON-PASSIVE ANTI-THEFT SYSTEM (PATS) KEYS. IF THE VEHICLE IS EQUIPPED WITH PATS, OBTAIN TWO (2) ROTUNDA KEY BLANKS (OR OTHER FORD AUTHORIZED BLANKS, SUCH AS: ILCO, STRATTEC, CURTIS, HUF, OR VALEO) AND CUT TO THE REVISED KEY CODE. USE OF OTHER UNAUTHORIZED KEYS MAY CAUSE ERRATIC OPERATION OF THE PATS SYSTEM.
  7. Program PATS keys using one of the two following methods:
(1) For vehicles with Integrated PATS (IPATS), function built into the Powertrain Control Module (PCM) and built beginning:
  • 2/2/98 Kansas City (Contour/Mystique)
  • 2/16/98 Mexico (Contour/Mystique)
  • All 1999 Cougars
Using the New Generation Star (NGS) Tester equipped with Service card (green) level 3.0 or higher:
  1. From NGS menu, select:
    • Service Bay Functions
    • PCM
    • Enter Security Access (10 minute delay)
    • Ignition Key-Code-Erase
  2. Disconnect Data Link Connector (DLC).
  3. Cycle the first non-programmed key in the ignition to run position for at least 3 seconds and then turn to the off position.
  4. Cycle the second non-programmed key in the ignition to run position. The theft indicator should prove out for 3 seconds.
  5. Verify the vehicle will now start using both keys.
(2) For Contours/Mystiques with Stand Alone PATS and built before:
  • 2/16/98 Mexico
Using the New Generation Star (NGS) Tester equipped with Service card (green) level 1.0 or higher:
    • PATS
    • Ignition Key-Code-Erase (this process may take up to 8 minutes to complete )
  2. Disconnect DLC.
  3. Cycle first unprogrammed key in the ignition to run position. First key will program and allow vehicle to start.
  4. Again cycle first programmed key to run position. Within 15 seconds, remove original key and turn new unprogrammed key to run position. The theft indicator should prove out for 2 seconds. New key will start vehicle.
  5. Repeat this process for additional key programming. NOTE: THE FOLLOWING SHOULD BE NOTED FOR THE PART NUMBER BLOCK:
    • Part Number suffix will match center character in key code
    • Logo on key is Ford for Contour models
    • Logo on key is Mercury for Mystique and Cougar models
PART NUMBER PART NAME F5RZ-11582-A Ignition Lock Cylinder (Contour) F5RZ-11582-B Ignition Lock Cylinder (Contour) F5RZ-11582-C Ignition Lock Cylinder (Contour) F5RZ-11582-D Ignition Lock Cylinder (Contour) F5RZ-11582-E Ignition Lock Cylinder (Contour) F5RY-11582-A Ignition Lock Cylinder (Mystique, Cougar) F5RY-11582-B Ignition Lock Cylinder (Mystique, Cougar) F5RY-11582-C Ignition Lock Cylinder (Mystique, Cougar) F5RY-11582-D Ignition Lock Cylinder (Mystique, Cougar) F5RY-11582-E Ignition Lock Cylinder (Mystique, Cougar)
Mar 09, 2009 | 2000 Ford Contour
Need to unlock a Nokia 6103b
Unlock your phone
  • Press Menu, enter the lock code, then press OK.
Answering a call when the phone is locked
  • Press Answer.
To change the lock code of your phone
Your phone's lock code is used to lock and unlock your phone.
The default lock code is 1234.
  1. Use Menu 4-3-2-3 (Settings - Security settings - Access Codes - Change lock code) to change the lock code.
  2. When the phone requires the lock code, it displays "Enter lock code:".
  3. Enter the code, then press OK.
If you enter a wrong lock code five times in succession, your phone prompts you for the security code.
Saving the unlocked phone number
Use Menu 4-3-2-2 (Settings - Security - Settings - Unlocked phone number) to save a number that may be called even when your phone is locked. You will be required to enter the lock code.
  1. Calling the unlocked phone number.
  2. Press the Up or Down arrow keys or or manually enter the number exactly as it is saved, then press Call.
Note: The More key will pause the automatic scrolling of the help text. Pressing the More key or the Up or Down arrow keys will toggle through the pages. The More key is only displayed when the help text is displayed.
Jan 26, 2009 | Nokia 6103 Cellular Phone
1997 ford contour
this is for 98, but may apply if yours is late 97 build.
Article No.
98-21-14
  • IGNITION SWITCH - HIGH EFFORT IGNITION KEY INSERTION/REMOVAL AND/OR KEY CHIMES SOUND WITH DOOR OPEN AND IGNITION KEY REMOVED
Publication Date: OCTOBER 15, 1998
FORD: 1998 CONTOUR LINCOLN-MERCURY: 1998 MYSTIQUE
1999 COUGAR
SERVICE PROCEDURE
  • All 1999 Cougars
    • PCM
  • 2/16/98 Mexico
    • PATS
  2. Disconnect DLC.
Aug 13, 2008 | 1997 Ford Contour
Change key pad lock code
if you havent changed your mob's keypad lock code til it got locked, the preset lock code will be 12345. you can use this code to unlock your mobile.
hope you will find my suggestion usefull.
Jan 17, 2008 | Nokia 1100
Cell Phones Logo
Top Sanyo Cell Phones Experts
Computer Repairing
Computer Repairing
Jeffrey Thomas
Jeffrey Thomas
Level 1 Expert
Yoav Shilon
Yoav Shilon
Are you a Sanyo Cell Phone Expert? Answer questions, earn points and help others
