Question about HP Pavilion a450n PC Desktop
I was attempting to backup my Windows and now the drive E door won't open. What can I do to open the drive door?
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 332 Answers
I am assuming your Drive E: is your CD or DVD Drive. If so all you need is a small paper clip to open the drive door. Just open the paper clip up so its straight. Look at the front of your CD or DVD drive you will see a small pin hole opening on the front of the drive. Push the straight end of the paper clip into that hole and push on it firmly it will contact a switch and release the door. The door will pop open a bit and you can pull it out all the way. When you restart your computer the door should pull back in if not just give it a light push and it will close again for you.
I hope this helps you out, and if it does please leave me some feedback.
Posted on Apr 04, 2011
How do i view the backup from my previous computer ? i can see the photos from my iphone and one pdf file, the files from the computer are "protected"
Eortiz, did you try to read the files with a windows PC? Because when you connect the external drive to a PC you should be able to view the files and even be able to change the attributes like read only and hidden.
May 12, 2014 | Hitachi Touro Mobile Portable External 1...
Need command prompt for Acer Aspire
The Windows Backup and Restore feature allows you to save files and system images to external backup devices such as hard drives and flash drives. However, backing up files become problematic if the directory your backing up files from isn't configured properly, or if you're having issues with the devices you're backing files to. There are ways to solve or work around backup problems quickly and safely.
Hard Drive b> A backup will not complete if the files you're backing up exceed the amount of space left on the external hard drive. If you're backing up large system files, Microsoft recommends saving the backup to an external hard drive that can hold at least 200 GB. If you're running out of space, you must delete content to create space for others or use another hard drive. Error Codes In some cases, Windows displays the following error codes when it's unable to complete a backup: "0x80070001 (Invalid Function)" or "0x81000037: Windows Backup failed while trying to read from the shadow copy on one of the volumes being backed up." These error messages usually appear if Windows is unable to backup a specific library or if you opt out of adjusting your backup settings and settle for the default settings in the Windows Backup and Restore Feature. Reparse Point b> If you're unable to backup a specific library and run into error code messages, removing the reparse point allows you to complete the backup. A reparse point is a file that contains information about the user on a computer. If it doesn't point to a location that contains some of the data you want to backup, error messages appear when you try to back up your files. Type "CMD" in the Start Search box to open the Command Prompt. In the Command Prompt, typing "DIR /AL /S" and pressing Enter lists the reparse points. Each entry says "JUNCTION," which also means reparse point. The entries also tell you the location of the reparse points in Windows Explorer. If you locate a specific reparse point in Windows Explorer, delete its mounted volume from the device's Properties. Once deleted, you should be able to back up your files. Discs b> If you're backing up files to a disc, you'll run into problems if the discs are non-rewritable and already contain data, or if they are severely scratched or damaged. Non-rewritable discs can only be used once, while rewritable discs can be used to read and write data several times. If the CD or DVD you're using is severely scratched, the optical disc drive spins harder than usual in an attempt to read it. If it's incapable of reading the disc, the backup feature may freeze or display an error.
Windows backup or restore errors 0x80070001, 0x81000037, or 0x80070003
http://support.microsoft.com/kb/973455 - workaroundissue12
Apr 20, 2013 | Computers & Internet
CD-RW drive won't open, only beeps when trying to open.
Look for a hole on the front tray a little bigger then a pinhole. Straighten out a paper clip and insert it into the hole to eject the CD.
Mar 20, 2013 | Dell Inspiron 8100 Notebook
Unlock SanDisk 32GB Ultra Backup USB 2.0 Flash Drive
http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html
Support IDE/SATA/USB Hard Drives memory cards USB Memory Drives
Windows Password Cleaner
Available in Live CD to run offline
This is a utility to blank the password of any user that has a valid local account on your Windows system.
You do not need to know the old password to blank the password.
hope this helps
Jun 07, 2012 | SanDisk 32GB Ultra Backup USB 2.0 Flash...
Switched a vista hd to a xp hd and windows will not open
You can't do that, it just won't work. A hard drive with XP installed on it will be unrecognizable to a PC with vista already installed on it. You can either backup your XP drive by putting it into a compatible XP computer. Or you can buy on of these, which are handy. This let's you get the data to your new PC thru a USB connection.
Mar 26, 2012 | Dell Dimension E520 PC Desktop
I have hP mini 1000 that won't boot up windows. Just shows me Hal.dll error message. How do I fix that if it won't start.
you will need a copy of windows and an external disk drive then have it boot from the cd when it boots select install windows then leave the current drive intact with no changes or if the repair option comes up you can select that. do not select the repair at the first menu unless you are an expert in dos, always go to the install.
Jun 30, 2011 | HP Mini 1000 Netbook
How do i clone my hard drive onto an external hard drive
Are you using Windows? If you are using Windows, go to Start => Programs => Accessories => System Tools => Backup. In the backup wizard that opens, choose which backup type you want and you can choose your backup destination. Choose your Seagate Expansion external drive for your backup location so that Windows can store an image of your current system into your external drive.
Feb 09, 2010 | Computers & Internet
Flash drive stops because it says other program in use when not.
let's try the following:
restart the computer, click on F8 or F12 to open your "safe mode". after the windows is up, plug the USB and then see what happens. Follow the usual steps you do and see if you actually have these errors
Nov 11, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Running Windows 7 Home premium. External drive Verbatim USB 250 Silver is recognized, but, needs to be reformatted. I've tried to format (NTSF) using tool in Disk Management. Format runs forever and...
Hello and thank you for using Fixya's services.
This problem happens quite a bit with Windows Vista. It seems that Windows Vista puts a hidden file in the backup; which locks the device.
Open the external device (Windows 7 is fine). Click on "view hidden folders and files." Delete any hidden files you may have in the external.
Go back to "my computer" and right click on the external hard drive letter. Choose properties and security tab. Make your user-name as a main user (administrator) and disable the read only.
Reboot the computer and see if this works.
Please let me know if you have any questions.
Nov 04, 2009 | Office Equipment & Supplies
Computer won`t boot
u will have to reformat the hard drive and load win 98 or win xp whichever u want to fix this
you can have more detailed info at
http://www.computerhope.com/issues/ch000474.htm
Jan 31, 2008 | Computers & Internet
HP Pavilion a450n PC Desktop Logo
116 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
