Question about Stiebel Eltron TEMPRA 12 Tankless Water Heater
Stiebel eltron 12 the thermal breaker keeps popping. I'm an electrical engineer and understand that it's probably residual head left in the chamber when the water is shutting off that is causing the thermal breaker to pop, I don't want to have to keep resetting the breaker with a pencil (cover is off), so I need to do something. I turned it down a little bit and maybe I can put Heat fins to dissipate some of the heat. Any ideas??? Does not happen all the time, but is happening more now.
    President:
  • 3,433 Answers
Hello; I can't clain any formal training or education in electrical, But, I am a home owner and Mechanic so I'll give this a try. Thermal switches are in the norm based on the bi- metal concept/ Automotive flashers are in essence thermal switches. Of course there are electronic types that contain points and a coil, we can forget those since we aren't doing a car or truck, let alone turn signal. OK, moving on. As you know,excessive continuous heat generated by a excess load will destroy the bi-metal strip which serves as a bridge in the circuit. A defective flasher will increase in speed as it gets older and used heavily. Anyway, to the point. I've experience thermal switches that cease to function if trip too often or were tripped by an excessive load. Although resettable initially, it's thermal tolerance gets shorter and shorter until eventually you get irritated enough to ask someone on Fix-ya for some input. No problem. I reccommend replacing the breaker with or of same amperes. You may want to verify the load by checking the appliance data plate just in case it's the straw the breaks the circuit I hope I helped you and I apologize for the analogy used. Thanks for using fix-ya. Good Luck _Ned_t
Posted on Apr 04, 2011
The thermal breaker keeps blowing
Replace the limit, by tripping often they become even more likely to nuisance trip.
Apr 29, 2016 | Stiebel Eltron TEMPRA 24 Tankless Water...
Stiebel Eltron 221094
Stiebel eltron model 221094 hot water is not as hot as it was before,
only warm water coming through. Do I need to replace unit?
Oct 05, 2013 | Stiebel Eltron DHC 10-2 Electric Tankless...
Heating unit in a stiebel eltron electric instant hot water heater went bad and I have to replace the unit. How difficult is that?
You will have to drain the tank, make sure when doing this to OPEN the pop off valve, the little handle on the drain pipe, or the water will not drain.
Feb 21, 2013 | Stiebel Eltron 240 208 Volt Electric...
The safety thermal cut off switch keep cutting off and am not getting any hot water in the shower
There is a short somewhere ... You will have to get the fault fixed so the safety will stay engaged.
Probably not what you wanted to hear.
Apr 05, 2011 | Stiebel Eltron DHC-E 10 Electric Tankless...
How can I reset the thermal cut off
Take off front cover, on the top of the cylinder(s) in there (the heating system) there will be a small red button. That is the Safety Thermal Cut out, depress that red button. It is similar to a circuit breaker. If the red LED comes on when you turn on hot water at a sink then that was the problem. I have on that trips periodically. Its annoying but not enough to replace the part yet. Good luck.
Dec 05, 2010 | Stiebel Eltron TEMPRA 12 Tankless Water...
How can I reset the safety thermal cut out from my tempra 12
the diagram on this page shows the safety thermal cut-off on top of the heating vessel on the right, inside the unit, remember to electrically isolate before opening.http://www.tanklesswaterheaters.com/tempra12.html
Apr 11, 2010 | Stiebel Eltron TEMPRA 12 Tankless Water...
Stiebel Eltron tankless 24. Problem:No hot water.Tempature display dead.Single LED on right side comes on when cold water flows thru system.Have cleaned fine mesh input filter.No pressure problems. CCt...
Take off front cover, on the top of the two cylinders in there (the heating system) there will be a small red button. That is the Safety Thermal Cut out, depress that red button. It is similar to a circuit breaker. If the red LED comes on when you turn on hot water at a sink then that was the problem. I have on that trips periodically. Its annoying but not enough to replace the part yet. Good luck.
Oct 11, 2009 | Stiebel Eltron TEMPRA 24 Tankless Water...
Where do I find the reset button on the Stiebel Eltron Tempra 15?
On the Tempra 29 there is a "safety thermal cut-out" on the top of each of the heating elements within the box. I have had to open it up before to push the breaker. They are a small red plastic push button on the top. Carefully press the braker button without touching the electrical wiring inside. I hope that works for you.
Sep 15, 2009 | Stiebel Eltron TEMPRA 24 Tankless Water...
No hot water in our tankless water heater
You may find this info helpful.
http://www.stiebel-eltron-usa.com/pdf/install_tempra.pdf
If you don't find what you need, you will need to contact them directly.
Apr 05, 2009 | Stiebel Eltron TEMPRA 12 Tankless Water...
My heater stoped heating water. the light is out that shows temp.my husband is in Military and i am alone. I checked circut breaker but I don't know if or where there is a circuit breaker at the box or a...
I had the same problem with the Stiebel Eltron Tempura 24. Right side unit worked (with blinking LED), but the display and left side (including LED) did not work.
This is CRITICAL. Do not take the cover off unless you have turned off circuit breakers at the circuit breaker panel AND tested that there is no power. There is a lot of voltage/ampreage here and it could be life threatening if you get shocked. Call an electrician (or a plumber) if you don't know what you are doing.
My problem was solved by resetting the safety thermal cutout switch on top of the non working unit (red single press thermistor). See this manual http://www.stiebel-eltron-usa.com/pdf/install_tempra.pdf page 8.
Jan 30, 2009 | Stiebel Eltron TEMPRA 12 Tankless Water...
Stiebel Eltron TEMPRA 12 Tankless Water Heater Logo
456 people viewed this question
Top Stiebel Eltron Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Stiebel Eltron Water Heater Expert? Answer questions, earn points and help others
