Question about Refrigerators
Hotpoint future frost free fza84 not freezing,products remain soft.
kstfas
  • 75 Answers
SOURCE: frost in "frost-free" freezer
Hi, This is my suggestion to check the defrost timer. "I would suspect the defrost timer. Remove everything and place in coolers or another refrigerator. Unplug the refrigerator. With doors open let it sit for aprox 6 hrs. A fan blowing into the freezer section will help. Plug back in and see if it works good again. If it works good for a couple of days and problem returns, Replace the defrost timer." Sound like you have already done my little test so the defrost timer needs replaced. NOTE: Refrigerators are well insulated and it takes several hours to completely defrost one so you may want to try it again. Also, I believe the clicking you hear is the fan blade hitting ice. Hope this helps. Let me know. kstfas
Posted on Sep 24, 2007
  • 139 Answers
SOURCE: freezer compartment
You need to defrost the whole fridge and at the back in the freezer compartment you will c a small drainage hole.. look for it.. The get a piece of say hanger wire and clean this pour some hot water from a kettle down it and then start your fridge up again. that should sort your problem out ... if not then its either a sensor or a board fault...
Posted on Dec 04, 2007
SOURCE: Kenmore frost free refrigerator
the back wall of my side by side is frosting over. the freezer side.
Posted on Jan 23, 2009
  • 219 Answers
SOURCE: fridge freezer not working after power cut
if its a ge i would say itsyour main board not compressor boards about 200
Posted on Mar 19, 2009
SOURCE: flashing lights on hotpoint fridge
I have a hotpoint future FF187E both lights are flashing how can i stop them flashing ?
Posted on Sep 23, 2009
My hotpoint freezer fza84 light is on?
Meaning it is on when door is closed, how do you know? Generally there is only one reason, the pressure switch is defective, and they pop out easily, so pressing it manually will disclose if switch is faulty if lite does not turn off and on while depressing, sometimes you can fix switches by cleaning contacts.
FREE-PPV.com
Jun 03, 2015 | Hotpoint Refrigerators
Hotpoint ffa91 My frige is freezing everything I put inside it.
sounds like the door between the freezer and cooler is stuck open
Jan 23, 2014 | Refrigerators
Hotpoint freezer FZA84 does not freeze ,high temperature light is on. when switched on the temperature comes down to about -12 C . does not come any lower but i hear a irregular hissing sound probably
You need to cut it off. You may be doing a lot of damage there. If this freezer is 8-10 years old, you may want to go ahead and replace it. At least it will not give you any more problems.
Jan 25, 2013 | Hotpoint Freezers
Icing up
I've just had a similar problem. I fixed it by removing the large panel on the back of the inside of the freezer. I found a large build up of ice at the bottom of the freezer which seems to have developed because the drain hole at the bottom of the freezer was blocked. I defrosted the ice, cleared the drain and now the freezer is working fine.
Jul 23, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
My freezer does not seem to be freezing properly. Some of the meat is staying frozen while some is getting soft. All my bread products are not freezing at all they are staying cold but soft???
THE RED WARNING LIGHT KEEPS COMING ON AND I HAVE TO KEEP PRESSING THE FAST FREEZE BUTTON, THIS IS EVERY FEW DAYS. IF I DONT NOTICE ALL THE FOOD DEFROSTS!
Mar 23, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Flashing lights on hotpoint fridge
Aug 04, 2009 | Refrigerators
Fridge freezer not working after power cut
Mar 19, 2009 | Refrigerators
Top half not freezing
If this is not a frost free unit , it probably has a freon leak. This is usually not worth fixing in a deep freeze. If it is a frost free unit the fan could be bad. This is an easy repair.
Mar 26, 2008 | Hotpoint 6.92 cu. ft. / 196 liter Upright...
Refrigerators Logo
238 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
