Question about Kicker Car Audio & Video
Ok i got this old metro sound mpx 402 amplifier , and two kicker speakers . I used to have them in my car a long time ago . But sold the car and took them out and store them in my room for along time . now my grand daughter wants it in her car . but i car not get any sound out of the speacker . need diagram on how to connect them to speaker and to amplifier
SOURCE: nad 302 amplifier
sounds to me that the vol control has lost its earth end connection So yes its a problem with the dial control You couls try some contact cleaner But better still lift of the lid and base if possible while the amplifier is not plugged into the power socket and see if you have a dry joints around the vol control pot regards Trev
Posted on Mar 14, 2007
ongolo
  • 11 Answers
SOURCE: Bose amplifier does not work with a 6 speaker selector
your wall speakers may not be connected.... disconnect each speaker from the selector box and test with a small AAA battery to see if they are connected by putting the battery between each speaker's wires , you will hear it crackle ,then gradually connect each wall speaker onto the speaker connector box . If the first set does not work i suggest there may be a problem with your speaker selector box . Good luck
Posted on Mar 19, 2007
informatica
  • 1114 Answers
SOURCE: Wiring Diagram for Sony car amplifier XM-554ZR
You can download the installation manual from the link below: http://www.sony.co.id/support/product/xm-554zr?site=hp_en_ID_i It has the following diagram plus other hookup info... Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 14, 2007
ajdriver
  • 15 Answers
SOURCE: Vrx Bass Tube Built in amplifier
hi there mate, is the sub earthed? sometimes this might be the problem, also check that all the cables are correct in the amp, there should also be a switch on the amp to lower or increase the output, this maybe turned all the way off, the remote lead generaly is usualy the thin blue wire behind the head unit the best way to connect this to your amp remote wire is to simply go to your local halfords etc and get a little wire joining clip. then you can conect them. any other problems please ask
cheers
adam
Posted on Nov 14, 2007
SOURCE: kicker L5 solo baric
Wire the speaker in series and bridge the amp
Posted on Mar 16, 2008
I have a Legacy Predator 2000 watt amp with 2 12'' Kicker speakers. It has been in my car for about a year now, and it recently just stopped working. I have the green light to the amp, im not sure about...
If you have checked your ground, live, remote and RCA's, The problem may lie with your kicker speakers.
There may be a loose wire connection on the speaker terminals (hense no sound).
Check the terminals at the speaker (+) and (-) then check the speaker wires to your amp inputs.
Usually if there is a fault with any wires linked to your amp, the amp goes into protect mode.
If your amp is not going into protect mode, try linking a different speaker to each terminal on your amp (left) then (right). If you get sound through a different speaker, more than likey your speaker wire to your kickers has came loose (due to vibrations) or there is a break in your speaker wire.
Hope this helps. If any more info is needed I'd be happy to help more. Please rate if helpful
Mar 18, 2011 | Car Audio & Video
Im just hooking subs. to my amp , so do I run my woofers to the terminal that say's sub or to just the other speaker terminals.the thing is I have two ssubs. and one sub terminal
If you want to use two Kicker Coaxial or Component Speakers on a single
channel of your amplifier wire the speakers in series. This will improve the sound quality, lower the total harmonic distortion and
lessen the thermal load at the amplifier. This may prevent an amplifier from shutting down, due to over-current protection circuitry.....so definetly on the SUB terminals as this channel provides the better bass response........
Oct 06, 2010 | Kicker KX700.5 Car Audio Amplifier
Only one of four speakers puts out sound!
Check all your RCA"smake sure they all have output..Then use a fluke metere, or any meter you can get that tests ohms, and measure each speaker..they should all read arround 4. If the outputs from the deck are good, and the speakers measure correctly, then you have got yourself a bad amp.
Jul 29, 2009 | Kicker (ZX350.4) Car Audio Amplifier
I have a 2channell FE-402 fusion amp,with a fusion sub,and a set of vibe k-series 69's that have a max power of 525 watts. I tryed wiring the sub with the speakers and the speakers sound fine but the sub...
Hello jackstephens,
It's an either/or situation. The FE-402 can be set up to drive normal speakers in stereo, OR drive a sub when both channels are bridged. When the LP filter is on, it benefits the sub at the expense of the normal speakers. And with the filter off, the subs get the full range of frequencies and try as best they can to reproduce them. You might try running it with the LP on, in stereo with the 6X9's paralleled to one channel (2ohm load), and the sub connected to the other channel (?ohm load).
But my recommendation would be to use the Fusion amp the drive the 6X9's and get a dedicated monoblock for the sub.
Hope this helps.
Jun 06, 2009 | Kicker KX500.2 Car Audio Amplifier
I need an override code to unlock my kicker sx700.4 amplifier
you will have to call Kicker, and let them know the serial number, and explain the problem to them. cause there is no generic code for that amp. they will have it in the computer at kicker.
May 26, 2009 | Kicker SX700.4 Car Audio Amplifier
Kicker 6 x 8's
This is Caused by the Connector on the Back of the Speaker Contacting Door Metal. Wrap Black electrical tape around the Connector and it should stop. Please Rate My Response! Thanks!
Jan 31, 2009 | Kicker KX600.1 Car Audio Amplifier
How to wire a kicker 15 cvr
175W x 2 @ 2 ohms
350W x 1 @ 4 ohm
Your amplifier is not stable @ 2 ohm bridged. So you will have to wire them independantly on each channel.
+/- on sub to +/- on L channel
+/- on sub to +/- on R channel
Wiring the subwoofers in paallel will result in a 2 ohm load, which your amplifier is not rated to do. Doing so will cause heat buildup, and damage to the amplifier.
Dec 23, 2008 | Kicker CVR12 Car Subwoofer
Kicker amo in my old vette
If the amp is in protect mode, it probably has shorted output transistors. To eliminate other possible problems, do the following.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage drops below ~11 volts, you need to check the wiring feeding whichever line is dropping too low when the amp goes into protect.
If the voltage is OK, you need to check the speaker wiring and the speaker(s). Try it with a known good speaker if possible to see if the amp works normally.
Nov 07, 2008 | Kicker KX600.1 Car Audio Amplifier
Kicker kx 800.4
Generally, if a Kicker amp has the power light lit and the protection light isn't lit, it's working. Are you sure that you have signal feeding the amp?
Are you sure your speakers are OK?
Nov 04, 2008 | Kicker KX800.2 Car Audio Amplifier
Kicker kx800.4 sounds without power
check to see if theres a gain port plug on the amp. It looks like a phone jack sometimes. If so make sure nothings in that port and make sure none of the prongs are touching one another. Thats the only thing i can think of the top of my head. It also could be a bad gain switch or something wrong with the radio and the line drop volts.
Sep 18, 2008 | Kicker KX1200.1 Car Audio Amplifier
Car Audio & Video Logo
79 people viewed this question
Top Kicker Car Audio & Video Experts
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
