Question about Kenmore 25.1 Side-By-Side Refrigerator with Dispenser Lockout
Locked dispenser Kenmore Elite Model 106 556 164 00. Noticed lock light dim this morning and over the last few weeks. Pressed it and it got brighter and now can't unlock after pressing for 30 seconds to unlock.
  • jds31 Aug 06, 2008
    I resolved the problem by removing the drip tray, taking out two screws that hold the panel, and disconnecting and reconnecting the wires from the panel to the board. Unplugging the refrigerator did not work.
SOURCE: Kenmore Elite Fregirator
my kenmore freg.is not working but the light inside is on,also power indicator not showing useually its on no. 1-6 depend where you set up.
Posted on Mar 30, 2008
  • 6 Answers
SOURCE: Kenmore Elite - Interior water dispenser stopped working
Frozen water tank, some of these had an insulation kit that will prevent this from happening. Make sure you have water coming out of valve to tank, if so it will probley be a frozen tank. Make sure fridge is on factory settings. If it doesnt thaw out, check into the frozen tank kit...
Posted on Aug 07, 2008
SOURCE: Newer kenmore elite trio refridgerator not cooling
The repair person came and in my case it was a start capacitator connected to the compressor. When he replaced the start capacitator the compressor came on immediately and started working. The charge $ 240 (Flat Rate) for the fix. The repair person told me its a universal start capacitator which I found online for $29. Worth trying to fix yourself before paying $240 if your a handy person.
Posted on Feb 10, 2009
  • 3 Answers
SOURCE: My kenmore dishwasher 665-15817 has a blinking ''Lock On'' button
- To clear the flashing light you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Posted on Jun 20, 2009
SOURCE: Replacing the Ice dispenser motor on Kenmore elite refrigerator?
I had the same problem with our Whirlpool Gold. Which by the way was just out of warranty. The guy who repaired the problem told us that since there were so many replacement dispenser motors at different supply locations that there must be a problem. I think that the root cause is the arm in the ice holder is hard to move, and it burns the dispenser ( #2252130) motor out. Whirlpool should get to the bottom of this and offer free or reduced repairs. Motor # 2252130
Posted on Jul 29, 2010
Hello, I have a Kenmore Elite Oasis washer model
On this washer, the dl code indicates a failed lid lock mechanism. Pressing pause/cancel should reset the controls.
You may have to unplug the unit for 20-30 minutes, then restore the power.
If that doesn't work, the only other solution would be to replace the door lock assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!!!!!!!!!!!!!!
Jun 16, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
KENMORE MODEL 110 WASHER WONT DO ANYTHING, JUST DEAD
you need to make sure you have power comeing out of your wall socket first. then let me know. also is any of your lights on your display lite up?????? control lock?????
Jul 24, 2009 | Kenmore Elite 45986 Front Load Washer
i have the same fridge, you have to press and hold the Lock button and it will unlock the ice/water for you.
Sep 15, 2008 | Kenmore 53642 / 53644 Side by Side...
Ice and water dispenser lock light stays on and comes back on quickly after pushing and holding. No water or ice dispensed while light on. Kenmore Elite 23.1 ft side by side refrigerator
I resolved the problem on my Kenmore Elite model 106.55616400 by removing the drip tray, taking out two screws that hold the panel, and disconnecting and reconnecting the wires from the panel to the board. Unplugging the refrigerator did not work.
May 28, 2008 | Kenmore 25.1 Side-By-Side Refrigerator...
Kenmore elite microwave oven displays "Locked" and will not respond
My Kenmore Elite microwave (don't have the model number in front of me) also mysteriously locked its own keypad (we were sitting in an adjacent room, heard a strange beep, and got up to find the LED reading "Locked."). I pressed and held down the Stop/Clear button for ~10 seconds and it returned to normal.
Mar 01, 2008 | Kenmore 62622 Microwave Oven
LOCK BUTTON ON
I think on this model you hold the lock button down until the light blinks off, about 3-5 seconds. If it locks by itself when you open and close the door it may be within the serial number range that had a recall on the dispenser board. Most of these were upgraded about two years ago but I still run into a few that were missed occasionally. If it is one of these units, as far as I know the recall is still open and it would be repaired free of charge. The most likely thing is that some one held the lock button down without realizing it though.
Sep 26, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
DW won't drain and "lock" light is stuck "ON"
Joe, see if you can reset the board by pressing heated dry-normal-heated dry-normal..(new board). Old board is high temp wash-air dry-high temp wash-air dry. See if it goes back to normal. If not you probably have a stuck or shorted keypad on the overlay..not the board. Catriver...post back
Sep 09, 2006 | Kenmore 15892 Built-in Dishwasher
Kenmore 25.1 Side-By-Side Refrigerator with Dispenser Lockout Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
