Question about Carrier TSTATHCP Programmable Thermostat Air Conditioner
My carrier thermostat ,stopped working and i have no screen.what does this mean
    Brigadier General:
  • 4,736 Answers
If it's a 24 volt system, the line transformer has failed. If it's a battery operated T-Stat, the batteries need changing.
Posted on Apr 04, 2011
Digital carrier thermostat reading P- on display. Any idea what this means
Some thermostats run on their own batteries, but some need power from the furnace to display, check this first. "P" may mean power.
Nov 22, 2016 | Carrier Heating & Cooling
I have a Carrier Debonair 450 Thermostat. The back-light of the LCD screen does not work. Neither do the buttons for the thermostat glow red or blue respectively. What could be causing this problem?
The t-stat needs a common and a hot. I know that is simple but it doesn't hurt to ask. Do you have the 24 volts needed to operate the t-stat? If you have 18 volts that may affect the lights.
Dec 14, 2015 | Carrier Heating & Cooling
I HAVE A CARRIER GAS FURNACE APPROXIMATELY 10 YEARS OLD. IT WAS WORKING FINE LAST FALL. I JUST STARTED USING IT AGAIN AND NOW ITS STARTS UP AND THEN STOPS, STARTS UP AND THEN STOPS? IF I PLACE THE HEATER...
you may need to replace the thermostat or the thermostat batteries if applicable. To replace the thermostat follow the instructions on the new thermostat. Make sure to set the thermostat to the gas setting(see instructions) this should cure your problem. Good Luck on the repairs
Dave
Jan 05, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier Comfort Zone 2 flashing E2
the e2 error on your thermostat is a problem with the return temp sensor on your system, the only thing you can really do is call a company and replace it, you can't bypass it or remove it cause the system wont run properly
Jun 29, 2009 | Carrier 38CKC060 Air Conditioner
Carrier Infinity Control Programming Issue
Open the flap, and press and hold the advanced button for 10 sec. you will be in the Installer setup screen. scroll down to the setup subfolder and select thermostat and it will be in there.
Feb 27, 2009 | Carrier Heating & Cooling
My programmable "Carrier"
blown fuse on circuit board, or transformer dead, or hot (red) wire disconnected or broken somewhere in circuit.
Feb 16, 2009 | Carrier BCA101R Air Conditioner
Run(heat) for a certain minutes then it stop.
You may have a durty evaporator coil do to a durty filter, the heat is cuting off by the limit control sensor
Feb 04, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier air conditioning unit #38ckc042
Yes, the wires for your thermostat are low voltage 24volts, and there is a fuse that protects it, now if the fuse is gone, nothing will work until you separate the wires and put a new fuse, the fuse is inside the ac unit, if you cant find it, that means it doesnt have one. there for need to check voltage at the transformer.
May 08, 2008 | Carrier 38CKC042 Air Conditioner
Heating & Cooling Logo
462 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
