Question about Acer Computers & Internet
I HAVE AN ACER DESKTOP, AM3100-U3401A, COMPUTER RUNS BUT MONITOR DOES NOT COME ON. THOUGHT MAYBE IT IS THE VIDEO CARD BUT DON'T KNOW.
  • Acer Master
  • 27,725 Answers
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections needs its connections continue its cycle and to have an end so any faulty leads will end up with a computer error
hope this helps
Posted on Apr 04, 2011
  • Rick Phillips
    Rick Phillips Dec 06, 2013
    already have done that but will run through them again just in case i spaced one thanx
  • Brian Sullivan
    Brian Sullivan Dec 06, 2013
    Check your RAM. The RAM is located in the middle of the motherboard. There are tabs that you can push to release the RAM. Loose RAM can cause your computer not to start properly where you want to see a video signal.Take the opportunity to clean the slots on the motherboards and the memory module connectors.Do not use solvent that may attract dust and never poke things like cotton buds in to slots, lightly rub an alcohol (Methylated Spirits) on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and allow the pins to dry then reseat them.Make sure your graphics card is securely seated with no dust built up or in the socket if you remove your graphics check the socket to make sure its dust free Restart your computer then reinstall it this should activate found new hardware wizard
Insert Lexar sdhc card nothing happens
Solution for Windows 7:
Note: Changing of this Group Policy setting applies only to Windows 7 Ultimate and Windows 7 Enterprise editions
1. Click Start and click Run...
2. In the box that appears type: gpedit.msc and click the OK button
3. The Group Policy Window will appear. In the left panel extend Windows Components and click AutoPlay Policies
4. In the right panel locate Turn off Autoplay and double-click on it to open the Properties window
5. Click on Disable. Click Apply and then OK
6. Finished.
hope this helps
Sep 05, 2012 | Computers & Internet
Monitor no signal acer M1640
Check the cable at the back of the monitor and at the back of the computer. If the cables are in tight and you still get the no signal error message you either have a bad monitor or a bad video card in the computer.
Try plugging another monitor into the computer (borrow one from a friend, neighbor or family member if you don't have one). If the monitor does the same thing and shows a no signal message like your original monitor, then the Video Card in the computer is bad. If the monitors works, then your original monitor is bad.
May 02, 2012 | Computers & Internet
No video
Hi
Check the VGA connections and probably replace the cable.
Try another monitor with the same desktop and see what happens.
Feb 22, 2012 | Acer Aspire M3100-U3401A Refurbished...
When i try to play games my computer blinks on different colours when i run the game. What should i do because last time i just format the whole computer,
maybe the problem is the video card try to upgrade it or maybe your monitor is to old, but try to isolate the problem if you have an extra computer, try first to switch it with other video if you have an extra one and play your favorite game maybe this will solve your prob. i hope this simple tips will help solve your problem : )
Sep 10, 2011 | Acer Aspire Z5600 PC Desktop
No video
Try connecting a known working monitor and see if you have video.
If you are connected to onboard video, you will need to get a video card, see which type you need, AGP, PCI Express or PCI and go buy it.
I hope this helps.
Good luck and have a pleasent day.
Jun 22, 2011 | Acer AM3100-U3300A Refurbished AMD Desktop...
Hey, my computer screen doesn't work when my computer starts ?
If you have hooked up the computer to another monitor and you still have no display, then your video might be bad. If you have display with another monitor, then you know your monitor is bad or the connection is bad. Be sure to check the connection, sometimes the video cable loosens and if that is the case you won't have any display.
I haven't looked up the "specs" on this system, but if you don't have any display with another known good monitor that works, you will have to determine if you have a video card or onboard video. If you need to replace the video, and have onboard, you need to have an open slot on the motherboard, there should be an open PCI or VGA slot available for a video card. In any case, if there is onboard video, you need to disable it in the setup after you install the new video card. Good luck hope this helps.
Feb 10, 2011 | Acer Aspire G600p PC Desktop
9 in 1 card reader not working on acer AM3100 computer. Where should I start?
for a start i would run a windows update. sometimes (not all the time) it will have a new driver for your hardware. if that does not work I would uninstall the card reader drivers and reinstall them.
Jan 27, 2011 | Acer Aspire E360 PC Desktop
Will an Acer AL1716 monitor work with a Dell 4600? Do I need a monitor card?
http://reviews.cnet.com/desktops/dell-dimension-4600-for/1707-3118_7-30529709.html
It has video card already, just make sure the video card driver is correct. Mkae sure to set the PC video resolution to the native resolution of this Acer, which is 1280 x 1024 @60Hz.
http://s807.photobucket.com/home/budm/allalbums
May 10, 2010 | Acer AL1716 17" LCD Monitor
Upgrading graphics card
Connect the monitor to the onboard video connector first. then
you need to disable the on-board graphics in the BIOS save the setting and shutdown. Then connect the monitor to the GeForce video connector and boot up then you will get a video signal on the GeForce video card.
Apr 29, 2009 | Acer Aspire M3201 Phenom X3 8650 PC...
Computer or Monitor problem?
Seems like you have a bad motherboard. Try a different keyboard, mouse, and VGA cable, and see if it works. I fnot then you deffinitely need a new motherboard.
Feb 28, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
586 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
