Question about GPS
I have a fan from a BMW with Bosch 1137328118 fan which I want to fit to a different car and cant figure out the wiring. There are two thick wires and two thin wires. If you could identify what colour wires go where ie.red = pos+ve etc. it would be appreciated.
  • 625 Answers
SOURCE: stereo wiring
test all gronds and powers then the remaining cables use a AA batterie and conect one cable on each end on the baterie like on of on of like toching at times and that will make the speakers to sound for a little then you will identify every speaker then read the diagram on the radio and plug it in acording to the radio diagram
Posted on Jun 01, 2008
Eagleeyes
  • 199 Answers
SOURCE: wiring colour code
what is your email i will email you the diagram
Mark
Posted on Jul 21, 2008
SOURCE: Lost in the wiring :(
http://www.msicomputer.com/product/p_search.asp.Go to msi for a mother board manual or wiring diagram?see support.richardm69
Posted on Jan 03, 2009
  • 262 Answers
SOURCE: Wiring Wrong
REDS ARE THE 2 HOT 11O VOLTS EACH AND BLACK IS THE COMMON FROM THE CIRCUIT BOX .THE RED ON THE STOVE SHOULD BE 1 HOT AND THE GRAY MAY BE THE COMMON BUT YOU ARE MISSING A HOT LOOK FOR YOUR WIRING DIAGRAM ON THE STOVE AND IT WILL SHOW YOU THE COLOR CODES FOR WIRING IF YOU CANT FIND IT SEND ME THE MODEL NUMBER AND I WILL SEE IF I CAN GET IT FOR YA.......BILL
Posted on Jan 11, 2009
crayzeetrayn
  • 837 Answers
SOURCE: Replace a 1999 Lexus LX470 headlight
My information shows that your vehicle has High beam lamps and Low beam lamps .. they are different . which one did you buy?
1) If you bought 1 that is looks like this
It is the High beam lamp
2) If you bought 1 that looks like this
It is the Low beam lamp
Posted on Mar 29, 2009
Why does red thick wire keep burning on 80 series kenmore dryer
Sound like you might be talking about the heating element
May 26, 2014 | Dryers
I have a Bosch SHU4322uc/u12 dishwasher remove wires from control module, should have taken picture, but did not,need to know where to plug wire into control module thx
Look at the notches in the control and on the wire connections. They are all different and only fit in their own spot.
Dec 30, 2012 | Bosch Dishwashers
Driver door on 2003 z4 bmw wont open
Sometimes the connection behind the door panel causes this problem. It is a wire that fits into a hole on the inside of the door handle. Be careful when you pop the door panel off. Use the tool, which is a flat thin pry bar. The wire looks like a thick metal coat hanger and fits in the hole.
Dec 01, 2012 | 2003 BMW Z4
Will a saloon petrol pump fit a compact
They are so close to the same wiring and mounting and only a couple pounds different in pressure it should work out from my calculations
Jun 09, 2012 | 1998 BMW 318ti Compact
Something is draining the battery at night. in the morning the battery is dead and the car wont start. at the moment i just disconnect the battery at night and re connect in the morning and it starts away...
try a tester on the alternater when the car aint running or if you have recently fitted a radio maybe you got the wires wrong way round and its on power all night
Jan 25, 2011 | 1997 BMW 318
I am restoring a 1984 BMW 323i model E30. I am replacing the Bosch main wiring loom with a Siemans wiring loom. I plan to use the original bosch engine wiring loom and connect it to the multi-plug of the...
your asking me something now ,havent seen one in years but the cables can be connected over with time and patience and a bit of solder is good as it doesnt corrode ,now the ballast resistor fitted with the siemans was a different type of circuit and as it was a bosch then wire it as the bosch was wired ,because the ballast resistor was used in conjuction with a 9v coil and when you cranked the engine it allowed full 12v voltage to the coil to give an increased spark under crank load ,never did work that well to be honest and the resistors often packed up so use it as the bosch system .On the siemans you had a wire from starter connection on ignition switch to coil and the ignition feed went through the resistor to the coil ,Simple enough but them resistors were a right pain in all honesty
Jan 03, 2011 | BMW 3 Series Cars & Trucks
Cant figure out where the thick red wire goes
buy the amplifier wiring kit from Walmart and let me know if you can not follow.
Jun 08, 2010 | Legacy 2CH 800W AMP Car Audio Amplifier
1988 bmw 325is heater keeps blowing 30amp fuse, tried to find a short but me heater blower fan isnt working what could be the problem. cant keep a fuse without blowing
More than likely the fan motor its self is short to ground try to unhook the wires to the fan motor and install a new fuse and then turn the fan on with the wires removed and if the fuse is still good you know it is the fan motor its self
Feb 12, 2010 | 1988 BMW 3 Series
GPS Logo
150 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
