Question about Dell Computers & Internet
When i put a blank cd in the cd rom of a dell computer it spins a couple times and makes noise when it spins like it is hitting something and then it stops spinning!!!!!! PLEASE HELP!
  • Dell Master
  • 27,725 Answers
make sure all leads that are attached to your cd/dvd floppy drives have secure connections and are not faulty or just replace them they are probably old and faulty ?
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on Apr 04, 2011
How can i boot my dell studio from cdrom so i can reinsall from external drive?
Turn on the machine, press F12 once the Dell splash screen is displayed, the boot menu will show up. From the Boot Menu, use up-down arrow keys on the keyboard and highlight the CD/DVD/CD-RW and press Enter.You will see another menu, select "Boot from Cd-Rom" and press enter to select it. The system will boot up from the CD-Rom. Please note that this settings is only for one time boot, once the system is restarted, the boot sequence will be restored to the previous saved settings. If you wish to set it from the Bios, enter the Bios settings by hitting F2 or Delete (should be shown at the bottom of the Dell splash screen) while you see the Dell Splash Screen. In the Bios settings menu, go to Boot options and make the changes with the boot sequence.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
May 21, 2011 | Computers & Internet
Cd rom makes clicking noise and ejects cd
THis happens because (a) the disk you entered is scratched, or not a recognised format or (b) your cd rom is broken. try insertin another disk. if the problem persists, try cleaning it. if all else fails, buy a new drive.
Feb 10, 2010 | Dell Studio 17 Laptop
CD drive clicking sound
Hello my friend please try to insert 2 new CD. and then try to observe the sound if it is still sounds like the weird. Then if you notice that the 2 new CD you insert produce same sound as your old one then i recommend that if you can find computer technician in your place to verify if your DVD/CD Rom is defective or not cause as of now if the 2 new cd inserted produces same sound as your old cd inserted then DVD/CD Rom has something to do its either defective or has a serious problem that needs assistance.
Thank you
Jul 30, 2009 | Computers & Internet
Cd rom not working and computer keep on freezing
try with other disk if all disk getting same issue then you have to first clean your cdrom or dvdrom lense.
For that you need disk cleaner disk pur chase it and put in rom then play it.
then it clean lense.then check.
if still face problem then you need to repair or replaced lense if it in warrenty replace it.
Jul 29, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
When i put a disk in the cd rom keep getting message please insert disk
Try known good disk. Other than that the unit has probably failed. Make sure disks can be read on a buddys computer?
Jul 28, 2009 | Dell XPS 400 PC Desktop
If i open the laptop the illuminated lines appear on the screen and i cant see a single thing and i hear the sound of hard disk which is spinning but the blank screen irritates me what i do
It's possible your laptop screen is going bad. Here's something you can try. Get an old monitor from a desktop. Power it up and hook it into the video port in the back of your laptop. Hit the Fn key and the F7 key at the same time. This tells your laptop to send the video signal to the port in the back of the laptop. If the computer works with this new monitor you may want to take your laptop into a computer repair store to have the screen replaced, or if you want to replace it yourself I can give you some advice on how to do that. If the computer doesn't work with the new monitor you may have a hard drive or mother board problem. The first thing I'd try then is to reboot the computer from your CD rom drive using a recover disk. If you can get it to boot ok from the CD rom it's probably a hard drive problem. You might be able to fix this problem by reloading windows.
Jul 04, 2009 | Dell Latitude D630 PC Notebook
Wiping computer
if you have a xp cd.... you can put the cd in and read ..its easy.... best thing to do is make the computer boot from cd rom.... hit f12 or f2 ... then go to the bio's and make the cd rom the first boot
Jun 30, 2009 | Dell Inspiron 6000 8x DVD/CDRW Combo Drive...
Dell 4700c
take off the side panel of the computer and listen to it a little closer when its on. there are very few actual moving parts so i should be fairly easy to isolate the noise. if it's a fan anywhere in the computer it can be replaced for less than 20 dollars and shouldn't be left till it dies, replace it , it's protecting something.
If it's a cd drive making the noise , it can be replaced for 25 dollars.
If it's the hard drive, then you need to back up your important files AS SOON AS POSSIBLE, because when it crashes, you generally have a hard time retrieving stored information from it.
hard drives can be replaced for 50 to 150 dollars depending on type and how large it is.
Most times the noise from a computer comes from the fans and power supply, then the cd/dvd roms , then the hard drive : so check them in that order. post here again if you need further assistance.. Regards
Mar 31, 2009 | Dell Dimension 4700C PC Desktop
Computer does not boot
O.k. so I gather your trying to reinstall windows. There's a few possible solutions the first of which is to reseat all connections checking for dust or anything else which might be between the connections. Second is to check your bios (by hitting usually f1,f2,f10,f11, or delete or esc keys) and making sure its set to boot from your cd\dvd rom. Also make sure your cd\dvd isn't scratched or dirty. If those fail try another CD\DVD rom drive to make sure it is the drive that has the issue. Don't be so quick to trash good hardware ;) good luck
Mar 26, 2009 | Dell Dimension 4600C PC Desktop
CD-R making loud noise, not reading anything
This problem seems to be with the alignment of lens, which can be done by opening the cd rom drive and change the alignment, but if its under warranty replace the drive bay
Dec 26, 2006 | Toshiba Satellite A1O A15 A20 A25 A30 A35...
Computers & Internet Logo
66 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
