Question about Healthometer Health o meter Digital Lithium Hdm753dq 95 (Health O Meter)
Healthometer doesn't work.Teminals clean,batteries good. Where to now?
I need a battery for my Model 840 Healthometer scale. Date on back Dec 15 02.What size battery fits as I don't have the old one.My battery place doesn't have one.
the hole for the battery will give you the clue
if it has a single groove with a spring at one end it will be either AAA or AA battery ( depending on the groove width
2 grooves will again be AAA or AA battery
a square hole with the terminals together in a plastic cap will be a 9 volt battery
a round hole with a metal finger will be a button battery possible a 2063 size
the owners manual will have the right battery listed or it will be listed on line in the manufacturers specifications for that model
Jul 15, 2017 | Healthometer Health & Beauty
I have a 1999 bobcat 763 that will not keep the battery charge i had the battery tested and it was good and the teminals were good. i have to jump it everytime. what do i need to do??
This indicates that you either have something draining the battery when the bobcat is off, or that the alternator is failing.
Nov 01, 2015 | Bobcat Garden
Jeep starter
first try and go back to unhooking battery and cleaning teminals real good with wire brush and put them back on tight you might have good enough contact to light up dash but not enough to start
Jun 06, 2012 | 1995 Jeep Cherokee
GE A35 Digital Camera will not power up
The only other suggestion is check the battery and camera teminals make sure the contacts are clean, if no! the problem is more than likely in the systems control board "the brains of the camera"
Mar 17, 2012 | General Electric Cameras
Car clicks once when key is turned. battery checks fine.1995 dodge caravan 3.0 engine. car was fine before. No signs of problem.
Just disconnect the clamps at the battery teminals. Clean the battery post of dirt deposits, as well as the battery clamps. After the cleaning job, reconnect the clamps tightly back at the battery terminals.
Now you can test your car, by turning the key. It should
start unless the battery is discharged.
Nov 29, 2009 | 1995 Dodge Caravan
1999 Silverado V6 Starting issues
If you are sure your battery is good (11 volts is not a strong battery unless you have a bunch of stuff running from it when you measure it), check your battery teminals. Sounds like when you clamp the jumper cables to the battery, the calmp tightens the terminals, giving you a better connection. All connections should be clean and tight.
May 04, 2009 | 1999 Chevrolet Silverado 1500
Automatic zoom
recharge battery after full charge install it what are changes ,does it works? If not clean battery teminals.
Dec 26, 2007 | Olympus FE-280 Digital Camera
Healthometer Health o meter Digital Lithium Hdm753dq 95 (Health O Meter) Logo
241 people viewed this question
Top Healthometer Health & Beauty Experts
StormERage
Level 1 Expert
Tom Chichester
Bill Boyd
Are you a Healthometer Health and Beauty Expert? Answer questions, earn points and help others
