Question about Western Digital My Book Essential 1TB External USB 2.0 Hard Drive
I want to rebuild my book essential 1tb... it fell apart accidentally but the software is not damaged... where do u put each little accesory?
I want to do the same thing I wanted to know if there is a blueprint so that I can put the pieces back in the same place as well the connector that goes into the harddrive was pulled out of the harddrive the wrong way i wanna put it back onto the harddrive but i know i can't tape it or glue it
Posted on Aug 30, 2012
    Sergeant:
    Champion:
  • 329 Answers
GoodDay!
it is very easy! just follow where it go, check each holes on it.
Thanks and God Bless!
Posted on Apr 04, 2011
How to recover data from a broken Western Digital My Book Essential
Remove the HDD inside the case,If the HDD inside is working, remove data with a usb to IDE/SATA Adapter. If the HDD is damaged, which is likely, It ,most likely, can be read, but I don't think you are going to like the bill for that service.
Dec 19, 2012 | Western Digital My Book Essential 1TB...
I accidentally plugged in my 19v toshiba laptop adapter to my 16v 1tb external hard drive it started up but then i plugged it out soon is it possible that the hard drive will work or is it dead, if no
The electronics in the hard drive is damaged and cannot be repaired by us mortals.
There are companies that can recover data from damaged hard drives BUT it will cost you an arm and a leg for their services.
May 12, 2012 | Western Digital WD My Book Essential 1TB,...
I have 1tb western digital external hard drive. It fell at the usb port got broken, so I went ahead and took it out of it's orginial casing. Placed it in a docking station and all i get is a blinking...
these have software in them for the board in the factory case ...you will have to use a data recovery software to recover contents then reformat the drive OR try installing it as a second drive inside the pc directly to the sata/ide cables not usb. good luck
May 08, 2011 | Western Digital My Book Essential 1TB...
Hello my wife accidentally tripped over the cord of my WD My Book Essential Edition external harddrive and now it no longer works. I could understand if it fell from an elevated posistion but It was...
It could be that the data cable separated somewhere not visible, however, it is much more likely that the hard drive its self is damaged. The platters inside the drive spin at very high speeds, the read/write heads pass between the moving platters( very close, but not touching). If a read head does come in to contact with any of the platters while they are spinning, the usual result is a ruined hard drive. Laptop hard drives have systems built in to enable them to survive a certain amount of shock while they are on, but drives meant for use with desktop machines normally have no protection. So, unfortunately even small shocks, like being kicked over while sitting on the floor, can cause a ruined drive.
Apr 28, 2011 | Western Digital My Book Essential 1TB...
How can I specify files to specifically backup? My Book essential - can I just drag files to the drive?
i thnk 1tb my book has an own software to backup 1 touchy backup and it will begin to backup ur files to a drive u wnat
Apr 07, 2010 | Western Digital My Book Essential 1TB...
I have a WD my book essential external HD which 1T. I accidentally pulled the USB cable while it is still running. When I plugged the cable again the device is detected but it is not visible in 'my...
Unfortunately if these drives are unplugged while running the structure of the drive can be damaged, normally if they show up in my computer there is a simple fix that works about 1/2 the time but if it is not showing up that will not work.
The two remaining possibilities are that the enclosure circuit board was damaged or that the structure was damaged as expected just worse than usual.
If you right-click 'My Computer', then select Manage, the MMC will open. Now click on the Disk Management utility and maximize the window. When it's done reading the drives and displays them scroll through the list and see if your 1TB drive shows in the list, if it does report back the exact wording and partition sizes showing as this may indicate a problem you can solve with inexpensive software.
If it doesn't show up this indicates that either the drive enclosure circuit or the drive itself is damaged. Report back including your Country, State and City and I can point you in the right direction for the professional assistance you will need on this issue.
Hope this helps FixYa
Sep 12, 2009 | Western Digital My Book Essential 1TB...
Partial format of WD 1TB external hard drive
Look on the Internet for a "file scavenger" program.
Compare it to reconstructing the table-of-contents of a book,
by reading each page & chapter of the last 93% of the book,
and recording what you found & where you found it.
You'll need another 1TB drive, if you find anything to "recover".
Sep 10, 2009 | Western Digital My Book Essential 1TB...
Western Digital My Book Essential 1TB External USB 2.0 Hard Drive Logo
97 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
