Question about Maytag Refrigerators
Have a maytag french door fridge on top freezer on bottom, fridge is not staying cold, frezzer works just fine?
    Brigadier General:
  • 3,917 Answers
Hi
Check the back wall or floor of the freezer section for frost. Check the freezer (evaporator) fan to see if it is running. Check the condenser coils (under the unit) for blockage from dust. Check the condenser fan (under the unit) to see if it is running.
If you have frost in the freezer there is a problem with the defrost system and the freezer will start to warm eventually as well as the fresh food section. If that is the problem you can check the defrost terminator, defrost heater/s, and the defrost timer or adaptive defrost control If used on your unit or the main control board if so equipped. These things usually require dismantling the freezer and other areas of the refrigerator to be checked.
You could defrost the freezer by disconnecting the power to the refrigerator and letting it sit for at least 24 hours with both doors wide open to allow the frost to melt completely but it will build up again in 1-2 weeks and start the warming up again.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Apr 04, 2011
My Maytag MFF2558VEM Bottom Freezer French Door Refrigerator doesn't keep cool
What you should be looking for is a blocked air flow. The fan in the freezer will push air up to the fridge and cool it off. Look for a dead fan motor in the freezer or a blocked air vent Good luck
Sep 08, 2012 | Maytag MFF2558VEM Bottom Freezer French...
Model # MFF2557HES Top refrigator section stoped cooling freezer is working
You may have Ice buildup in the freezer. You freezer has a fan in the bak that sends the cool air to the fridge. Your fridge dial determines how muh cold air comes from the freezer. Try defrosting the freezer. You may have to pull the back panel off of the inside of the freezer to get the ice thawed. The ice build up is likely causing the air to not get to the fridge. Hope it works.
Aug 16, 2012 | Maytag MFD2560HES Bottom Freezer French...
I have a model MTB1956GE Maytag Fridge, Frezzer
Can you feel air moving or hear the fan running in the freezer section? You said the freezer section is freezing well, but is it freezing really hard?
Regards,Richard
Dec 12, 2011 | Maytag MTB2156GES Top Freezer Refrigerator
My refrigerator is not staying cold...this just started to happen yesterday...it is warm today? The freezer is working fine? Help
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 24, 2010 | Maytag MFD2561HE Bottom Freezer French...
My fridge quit working.Freezer still works,cold air just not making it up top to the fridge.any ideas??
Most likely you have a defrost problem. The frost is building up on the evaporator coil causing a restriction to the flow of cold air from the freezer to the refrigerator.
Dec 17, 2010 | Maytag MFD2560HES Bottom Freezer French...
Maytag refrigerator isn't cold.
if freezer is working and ice mker is working . and fan / then only other is the damper in top center is not working . very common . mm
Apr 18, 2010 | Maytag MFD2560HES Bottom Freezer French...
My freezer works fine but the refrigerator does not
check to see if your fan in frezzer is working if not u need fan if it. is see if there is frost on back wall of frezzer if there is u have a defrost problem .u can unplug and let thaw with draw open for 4 or 5 hrs will work fine till u get service ther if it is defrost
Mar 18, 2009 | Maytag MFD2560HES Bottom Freezer French...
Maytag french door bottom freezer: Fan not working.
very easy the fan cover snaps into place and make sure you get the new motor that is metal not the plastic one they are the problem
Dec 11, 2008 | Maytag MFD2560HES Bottom Freezer French...
Warm Fridge Section
sounds like the evaporator fan in the freezer is not moving the air. also there is an air damper door at the top center of the fridge that controls air flow from the freezer to the fridge. check those two components and you will find your problem.
Sep 26, 2007 | Maytag MFD2560HES Bottom Freezer French...
Refrigerators Logo
66 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
