Question about Vizio 42 in. LCD TV
I have an rca surround sound system and how do I install of to my vizio
  • 961 Answers
Your best option would be to connect all your components requiring video to be hooked directly to tv through HDMI in or component in. With a component hook up, you will have to provide audio with either digtal optical or composite cables. You then would want to provide sound to your surround sound by a digital optical out or composite out to the input of your surround sound.
Posted on Apr 04, 2011
How do you connect tv audio from vizio wv26l through panasonic saht 680 surround sound?
The SAHT680 only has RCA analog audio inputs. I don't know the WV26l. However, there are a couple of possibilities based on other Vizio models. 1) The audio out is a headphone jack. Use a 3.5 mm M to RCA F/F adapter and then an RCA audio cable to the surround sound system. (You can also use a cable that has the 3.5 mm M and RCA M/M ends or a 3.5 mm F and RCA M/M adapter with a 3.5 mm audio cable.)
2) The audio output is a digital audio out. In that case, you need a digital to analog audio converter. There are a number of models available. One example is here: http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10423&cs_id=1042302&p_id=6884&seq=1&format=2 . You will also need the correct digital audio cable between the TV and the converter and the RCA audio cable between the converter and your SAHT680.
The manual for the SAHT680 is available from Panasonic here: service.us.panasonic.com/OPERMANPDF/SAHT680.pdf . See page 25 for the picture of the audio inputs.
I hope this helps.
(The only other option is to upgrade the main unit of the surround sound system to one with digital audio inputs if your TV only has digital audio out.)
Nov 19, 2012 | Audio Players & Recorders
What amplifier do i need to connect 4 speakers to my vizio P50HDTV10A TV
Check the back of your set there are 2 Audio RCA Jacks, You can't do it with an amplifier alone because that won't split the channels to 4. You have to go to a surround sound receiver.
Jul 14, 2012 | Vizio P50HDTV10A 50 in. Plasma HDTV
No audio out for surround sound on vizio e472vle?
I would check the owner manual and call Vizio but if the set does not have the correct outputs it will never work for that.
Jun 11, 2012 | Vizio VL Televison & Video
E320VP LED HDTV just purchased. How to I hook up to a home theater system if it has no optical input jack? Thanks.
You should be looking for an optical output on the TV and an input on the home theater. if you mean the home theater has no optical input then you will have to resort to using RCA cables, they wont provide surround sound but most TV channels wont use surround anyway. They are the red and white sockets on the TV. If you need further help please respond with the brand and model of home theater system
Jan 11, 2011 | Vizio Televison & Video
I just bought an rca surround sound rtd315w - mp3 won't work
You must select that input with the RCA surround sound
Apr 20, 2010 | Televison & Video
Can i connect a coby 5.1 dvd home theater system to a 32 inch vizio and be able to watch tv with the surround sound on. I know the surround sound can play while im watchin a dvd but i would rather just...
you need a logitech sound adapter or game adapter that costs 4-10$ on ebay.
Connect LR channels using an RCA cable and hook up the speakers on the other end of the game adapter
Jan 10, 2010 | Vizio VW32L 32 in. LCD HDTV
Picture but no sound on my Vizio L37 Flat Screen
i have a 50 in vizio and the sound just went out. the picture still works but no sound anyone have any ideas on how much to repair it?
Jan 10, 2009 | Vizio L30WGU 30 in. HD-Ready LCD...
Hooking up video
I am assuming that you are using a surround sound system?If so on the back of the satellite receiver you will have RCA cables labled yellow ,red,white uuse an rca cable to run from the output on the back of the sat box to an rca input on the surround sound unit.the inputs should be labled on the back of the surround sound unit.once you have the sat box plugged in look for the output on the surround sound (rca cables) run one set of rca cables to the rca cable input of the Tv.on the original tv remote select the tv input that is the cable from the surround sound is plugged in to . make sure the surround sound unit input is selected to the input that the sat box is plugged into.this will give you surround sound from your satellite receiver,repeat with your DVD player plugging the DVD rca cable output to another empty input on the surround sound.to switch between the sat box (satellite TV) to DvD select another input on the surround sound unit.Try to correspond the units you are plugging into the surround sound to the correct name of the component on the back of the surround sound unit to avoid confussion.any questions,Im here to help.If this works rate me FIXYA! if it helps.GOOD LUCK!
Nov 18, 2007 | Panasonic SC-HT40 System
Vizio L42HDTV10A sound problems
In my case, turning the surround sound OFF is what fixed the problem. The bass contibutes most to the perception of the location of a sound. If surround is ON without surround speakers connected, the internal TV speakers can only take the place of what would be the front speakers in a surround system. So turn surround OFF and set your bass preference wherever you want it. That worked for me.
May 29, 2007 | Vizio L37 Television
Open Questions:
See all Vizio 42 in. LCD TV Questions
Vizio 42 in. LCD TV Logo
245 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
