Question about MB Quart QL S1030 Speaker
I have a set of QL S1030's. The left tower tweeter hisses and chatters. There is a brown fluid leaking from inside the maganet on to the Ti speaker(must dissamble to see). I believe this speaker is destroyed. How may I get a replacement. Thanks, Ken Sanchez
    Top Expert:
  • MB Quart Master
  • 75,304 Answers
Hello
The brown fluid leaks out is from the twetter speaker. The twetter is liquid filled type and have a chance to get leaked, and it is not irreparable. MB Quarts is a German model as I knows. It will be very difficult to get the orginal one. You can replace it with an other companys' speaker of same size, coil impedence and power handling capacity. It wont effect the sound quality of the system. OK.
Posted on Apr 04, 2011
2014 dodge advenger radio wiring harness diagram
2014 Dodge Avenger Car Audio Wiring Diagram
Car Radio Battery Constant 12V+ Wire: Red/Brown
Car Radio Accessory Switched 12V+ Wire: N/A
Car Radio Ground Wire: Black
C
Car Radio Antenna Trigger Wire: Gray/Orange
Car Audio Front Tweeter Size: 2-1/2? Tweeters
Car Audio Front Tweeter Depth: 5?
Car Audio Front Speakers Size: 6? x 9? Speakers
Car Audio Front Speakers Depth: 4?
Left Rear Speaker Positive Wire (+): Dark Green/Tan
Left Rear Speaker Negative Wire (-): Dark Green/Gray
Right Rear Speaker Positive Wire (+): Dark Green/Brown
Right Rear Speaker Negative Wire (-): Yellow/Gray
Car Audio Rear Speakers Size: 6? x 9? Speakers
Car Audio Rear Speakers Depth: 4?
May 18, 2016 | Dodge Cars & Trucks
95 chevy blazer
The wires provided for a radio system are as follows:
yellow = hot with ignition key ON
orange = hot from BATT at all times
Grey = dimming power from instrument panel
Black = ground
Harness Wires provided for the speakers as follows:
Left rear speaker = +brown -yellow
Right rear speaker = +dark blue - light blue
Left front door speaker and tweeter = +tan - grey
Right front door speaker and tweeter = +light green -grey
Note: connection colors at the speaker location differ as noted:
Right front door = +brown -yellow
Left front door = +brown -yellow
All other speaker connections are consistent with their harness colors.
Sep 25, 2014 | 1995 Chevrolet Blazer
My 2006 hhr has a rattle when shifting in automatic transmission
What you are hearing is referred to as "chatter," and is a first warning of transmission trouble. If your vehicle has over 50,000 miles, and the transmission fluid and filter have never been changed, the fluid likely has lost its viscosity or has become contaminated, and the internal seals in the transmission have begun to leak. Check the fluid: It should be semi-transparent, the color of blood, and should have approximately the viscosity of lightweight lubricating oil. If it is gray, tan, dark brown, watery, or if it has the odor of kerosene, it bad. Eventually, the transmission will fail.
You may start by having a transmission "service" performed, where they will replace the fluid and filter/screen. If that does not eliminate the chatter, it may be time to consider having your transmission rebuilt.
Aug 10, 2014 | 2006 Chevrolet HHR
I need the wiring colour codes for 2002 santa fe car stereo
Basically the wiring of the large harness corresponds to the pins like this.
Starting in the upper right hand corner and working down the right side from A12 down to A1.
1=Left rear output-red
2=Left rear output-blue
3=Right rear output-black
4=Right rear output-yellow
5=empty
6=Left front input-black
7=Left front input-yellow
8=Left rear input-orange
9=Left rear input-green
10=Amp 'ON'-blue&orange
11=empty
12=Amp sensor-black&orange
Back up to upper left hand corner on the large plug
13=Right front tweeter output-red
14=Right front tweeter output-blue
15=Left front tweet output-red
16=Left front tweeter output-blue
17=empty
18=Right front input-red
19=Right front input-white
20=Right rear input-blue
21=Right rear input-red
23=Right front sub (+) output-yellow
24=Right front sub (-) output-black
The small harness is the same above with the upper right position being pin 1 going down to pin 4 then back up to the top for pin 5 down to pin 8.
1=Memory Power-Lrg White
2=Amp Ground- Lrg Black
3=Left front sub (+)output-yellow
4=Left front sub (-) output-black
5=Left front mid (+) output-white
6=Left front mid (-) output-brown
7=Right front mid (-)output-brown
8=Right front mid (+) output-white
Hope this will help you.
Thank you
Jan 04, 2011 | 2002 Hyundai Santa Fe
When a steering wheel is turned to the end of its travel, the power steering pump makes an objectionable hiss. But my Stratus makes this noise when I turn the wheel at center when fluid is cold....
early sign of the rack and pinion going bad if you look inside the inner tie rod boots you will see leaks starting. prepare to have it replaced sooner than later.
Nov 20, 2010 | 2000 Dodge Stratus
Stock audio wiring diagram
Car Radio Battery Constant 12v+ Wire: Green
Car Radio Accessory Switched 12v+ Wire: Green/Orange
Car Radio Illumination Wire: Red/Blue
Car Stereo Dimmer Wire: Yellow
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: Under the Driver Seat.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Tweeter Speaker Positive Wire (+): Blue
Left Front Tweeter Speaker Negative Wire (-): Brown/Red
Left Front Mid Speaker Positive Wire (+): Black
Left Front Mid Speaker Negative Wire (-): White
Left Front Low Speaker Positive Wire (+): Yellow
Left Front Low Speaker Negative Wire (-): Blue
Right Front Tweeter Speaker Positive Wire (+): Blue/Orange
Right Front Tweeter Speaker Negative Wire (-): Green/Orange
Right Front Mid Speaker Positive Wire (+): Black
Right Front Mid Speaker Negative Wire (-): Brown/Red
Right Front Low Speaker Positive Wire (+): Black
Right Front Low Speaker Negative Wire (-): White
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Blue
Left Rear Speaker Negative Wire (-): Green
Right Rear Speaker Positive Wire (+): Yellow
Right Rear Speaker Negative Wire (-): Blue
pls rate
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
May 11, 2010 | 2003 Kia Sorento
Channel 2 crackles
Make sure your speaker wiring does not come close to the 12v power cable running for your amplifier. If your amplifier's 12v power cable runs on the drivers side of the vehicle, run your speaker cables on the passengers side and make sure your tweeters have a high pass filter to stop any pickup of engine sound (When you are driving you *WILL* notice it at high RPM. a HPF (High Pass Filter) will also stop those nasty hissing sounds on S's.
Feb 11, 2009 | Alpine PDX-4.100 Car Audio Amplifier
Tweeter does not work in surround speakers
If you are trying to find out if tweeters are ok, place them to the mids
and listen. if good, then trouble lies in the individual amplifier inside ur set.
Good Luck
Dec 14, 2008 | Audio Players & Recorders
MB Quart QL S1030 Speaker Logo
177 people viewed this question
Top MB Quart Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a MB Quart Audio Player and Recorder Expert? Answer questions, earn points and help others
