Question about Hitachi CP-X328 Multimedia Projector
Casting a blue tint - Hitachi CP-X328 Multimedia Projector
  • 21 Answers
This could be for a variety of reasons.
First, check all your connections to make sure everything is connected properly and undamaged. If you are using a VGA cable/computer cable, make sure the pins are not bent.
Next, check the cables themselves. I do this by flexing the cable back and forth, starting at one end and working my way to the other. Go slowly and make sure to do this every few inches. If there is a damaged wire, this will cause the image on the screen to flicker or change color. Any damaged cables found should be replaced.
If this does not work, try removing individual cables and using a different one. Do this one cable at a time in order to try and identify where the problem might be. This is assuming you have spare cabling.
If everything is connected properly and nothing appears to be damaged, go into the projector menu and check all your color settings. You'll see you have a variety of options. If these are set to default and you still have discoloration, the problem is most likely internal and may require a technician.
One additional option is to check the data source to make sure all the settings on that are correct as well.
Posted on Apr 06, 2011
I need to get rid of the blue tint on all my pictures
Have you checked your camera's white balance setting ? Try setting it to 'Auto' and see if that helps. If not, then there may be a fault in the camera's electronics, which would indicate repair or replacement.
May 30, 2016 | Cameras
What would make my pictures and videos come out with a lot of blue tint?
Regarding Blue tint of Photos and Videos - This is tied directly to your White Balance Settings. When you White Balance is set to Auto, the Camera determines the best setting to use to for White Balance (How much Blue or Orange needs to be added for best White). To get a Blue Tint, the Camera's White Balance is most likely set manually to something like Incandescent or Indoor. First you will want to see that your White Balance is set to Auto - If it was not, then Auto should fix your problem. But If it is alrready on Auto, and you are still getting Blue tint both Indoor and Outdoor, then the Camera's Software may be faulty.
Hope this helps!
Jan 12, 2016 | Cameras
Red tint right side mitsubishi hc7900dw
first try doing a factory reset through the menu. if it persists and the tint has a relatively hard edge to it, you may have a broken light tunnel and it's casting a bit of a shadow on the image. you might need to bring it in for repair, especially if it's under warranty
Feb 25, 2014 | Office Equipment & Supplies
Red and blue tint
Often "grayscale" is achieved by mixing some of your colors (CYM) to form composite black and gray - not necessarily just black from your black cartridge. Often there is some yellow used beneath the black -- so if you are getting a red or blue tint, it could mean something as simple as being low on yellow ink.
Jan 26, 2014 | Office Equipment & Supplies
Backlight is blue and screen has a blue tint. no
Reset the tv back to factory setting.By unplug and replug the tv an hour later.This should work,not than ur tv Tuner board it dead.
Apr 10, 2010 | Sony KDS-60A2020 60" HDTV
GL2 drops in blue tint or yellow blocks
Your GL2 has a case of clogged heads. If the clogging is minor, you can clean by using head cleaning tape. 1.Open the tape door and blow out any dusts present. 2. run tape cleaner for about 10 seconds but NO MORE. Hope it works. -James. For further assistance by email, go to www.camerarepairjapan.com
Feb 28, 2009 | Canon GL2 Mini DV Digital Camcorder
Have a lumex dmc-tz3 worked great until 1 month ago now pictures have a blue tint/hue
July 13, 2009
Panasonic TZ3
Did you ever find a solution to the blue tint that shows up on your pictures? We have the same camera and also have this blue tint
thing going on. Wonder if we have a menu setting wrong?
Jan 14, 2009 | Cameras
Picture calibration settings for 42lg70
Picture Menu
Picture Mode: Expert1
*Backlight: 16
*Contrast: 83
*Brightness: 53
Sharpness: 50
*Color: 55
*Tint: 0
Expert Control
  • Fresh Contrast: Off
  • Noise Reduction: Medium
  • Gamma: Medium
  • Black Level: Low
  • Real Cinema: On
  • TruMotion: Low
  • Color Standard: HD (N/A w/HDMI)
  • White Balance: Warm
  • **Method: 10-Point IRE
    • 10 IRE
      • **Red: 1
      • **Green: 2
      • **Blue: -16
    • 20 IRE
      • **Red: -6
      • **Green: 0
      • **Blue: -7
    • 30 IRE
      • **Red: -5
      • **Green: 0
      • **Blue: -4
    • 40 IRE
      • **Red: -8
      • **Green: 0
      • **Blue: -4
    • 50 IRE
      • **Red: -4
      • **Green: 4
      • **Blue: -4
    • 60 IRE
      • **Red: -6
      • **Green: 6
      • **Blue: -5
    • 70 IRE
      • **Red: -8
      • **Green: 3
      • **Blue: -10
    • 80 IRE
      • **Red: -8
      • **Green: 7
      • **Blue: -16
    • 90 IRE
      • **Red: -9
      • **Green: 5
      • **Blue: -18
    • 100 IRE
      • **Red: -10
      • **Green: 4
      • **Blue: -9
Color Management System
  • Red Color: 0
  • Red Tint: 0
  • Green Color: 0
  • Green Tint: -15
  • Blue Color: 0
  • Blue Tint: 11
  • Yellow Color: 15
  • Yellow Tint: 2
  • Cyan Color: -15
  • Cyan Tint: 0
  • Magenta Color: 0
  • Magenta Tint: -1
lg70 nice tv excellent processor just to bad there is no intensity control on color management oh well still better than what the three s are pushing block out the hype lg will be number 1 in a few years haters are starting to come around and well leds coming,
p.s. i dont work for lg just tired of losers bashing stuff because they dont own it.
im isf certified those settings are right on the money straighter than a ruler
Oct 05, 2008 | Televison & Video
Picture settings
Colorimetre HCFR software
AVC HD 709 calibration disk
Spyder2 colorimeter (I know most prefer the Eye-One meters, but the Spyder2 was available from my job at no cost)
Here are the settings:
PS3 Blu-Ray player
Output Format (HDMI): Y Pb/Cb Pr/Cr (important!!! NOT RGB output)
BD 1080p 24hz Output (HDMI): On (this TV can reproduce video at 48hz for accurate 2:2 pulldown)
Y Pb/Cb Pr/Cr Super White (HDMI): On (not sure if this matters)
42LG50 Settings
Aspect Ratio: Set By Program (Personal Preference)
Picture Mode: Expert 1
Backlight: 50 (Personal Preference)
Contrast: 54
Brightness: 54
Sharpness: 40 (Personal Preference)
Color: 50
Tint: 0
Fresh Contrast: Off
Noise Reduction: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 10 Point IRE
10 (-3,8,-16)
20 (15,24,-21)
30 (20,36,-22)
40 (3,19,-40)
50 (8,34,-41)
60 (10,50,-20)
70 (-5,50,-8)
80 (-16,50,18
90 (-14,50,30)
100 (-22,38,21)
Red Color: -3
Red Tint: 0
Green Color: 10
Green Tint: 0
Blue Color: 14
Blue Tint: 0
Yellow Color: 0
Yellow Tint: 1
Cyan Color: -11
Cyan Tint: 0
Magenta Color: 0
Magenta Tint: -2
Take time to get used to the settings, you may think the screen looks dull at first. The truth is most people have way too much contrast on their TVs.
These settings will also work for Cable or Dish hookups, in which case you may change the Noise Reduction option to Medium to reduce signal noise.
OR....
2POINT IRE
Backlight: 65
Contrast: 55
Brightness: 45
Sharpness: 50
Color: 45
Tint: 0
Fresh Contrast: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 2 Point
Red Color: 3
Red Tint: 0
Green Color: 9
Green Tint: 2
Blue Color: -1
Blue Tint: 0
Yellow Color: 6
Yellow Tint: 5
Cyan Color: -1
Cyan Tint: 1
Magenta Color: 2
Magenta Tint: -1
Sep 15, 2008 | LG 42LG50 42 in. LCD HDTV
Monitor is blue-evrything has a blue tint-i can see colors,they just have a ble tint
I've found that strange color tints are usually the result of a loose cable connection, either at the computer end of the monitor end.
Try unplugging both ends, and then replugging both nice and securely (might even try reversing the direction of the cable, if it is a simple VGA-VGA cable).
Feb 27, 2008 | Computers & Internet
Hitachi CP-X328 Multimedia Projector Logo
96 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
