Hoover 201M 5.00Kg Heavy DutyTop load leaks slightly . I cant see any easy way of removing the outer case to look inside to find out where the leak may be. there are only a few screws holding the control panel onto the machine body, but no other obvious fastenings of the outer case to the chasis/motor/tub/. inner bits Is there an instruction/workshop manual on the net ? thanks, tom hay
    President:
  • 1,654 Answers
  • Unplug the washing machine from the wall outlet.
  • 2
    Remove the plastic end caps on the left and right sides of the control panel using your fingers, and then remove the screws under the end caps.
  • 3
    Lift the control panel up and rotate it 180 degrees.
  • 4
    Unplug the wire connector from the top of the cabinet and then use a flat-head screwdriver to release the spring clips on the left and right sides of the cabinet.
  • 5
    Tilt the cabinet toward you, then lift and remove. Set the cabinet aside.
  • New top load machines all have the cabinet where it comes off forward and the screws only hold the control panel on.
    Posted on Apr 04, 2011
    How do I remove the agitator from my Hoover 201M washing machine. It really needs to be cleaned under there with all the muck thats building up. Thanks.
    if it is a top loader machine with an agitator that stands up in the center of the tub, try removing the dispenser and lint trap from the center ( normally just a pull up) and right down the bottom there is a 10 or 12 mm bolt that you undo and that allows you to pull the agitator up off the drive shaft
    talk with a service agent as to how to get the agitator out or down load a workshop manual from google by typing in --workshop manual for hoover model 201m washing machine -- and if there is a pdf version then down load it
    Feb 07, 2016 | Hoover Washing Machines
    Tip
    Water leak from door of LG front load washer
    First, clean off the bottom of the door glass where it contacts the gray tub gasket when the door closes. Any hair or other build up can result in leakage. Second, if that does not completely solve your leak, you can move the location of the spring which holds the tub gasket from the very bottom (6 O'clock position) to the hinge area (9 O'clock position). Third: Sometimes, the reason you get a leak is due to the installation. If the washer was pushed into place by applying pressure in the center front of the washer, the outer front panel can be slightly deformed (inwerd) resulting in leakage from the door. If that is the case, sometimes you can remove the outer clamp and outer part of the gray seal and pull out on the front panel to correct the situation if it is not too severe, rather than replacing the entire front panel.
    on Jul 03, 2009 | LG WM-2277HW Front Load Washer
    Lg 1370 slight clean water leak on left side of dispenser draw sometimes? solutions please ,
    Usually a sign that you are using too much detergent. Pull the drawer out completely and clean it out. The drawer and the casing
    May 28, 2014 | LG WM-2277HW Front Load Washer
    I have a leak in the front door of my washer
    Oct 20, 2009 | LG WM-2277HW Front Load Washer
    LG front load washer -- water leaks out the bottom of the door -- if I push on the door while its running, the water slows/stops leaking...
    Jun 25, 2009 | LG WM-1832C Front Load Washer
    Washing machine leaks
    Go to fixitnow.com to find out how to remove cabinet. If it's a big leak it's most likely a hose; if a little leak, more likely the pump. Both easy to replace once you have cabinet off.
    May 13, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Water leaks during drain cycle and the machine
    Hi
    If the water leaks during drain and spin only: A washer that leaks only during the drain/spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
    Please do rate this solution as "FixYa" if found useful.
    Thanks
    Rylee
    Mar 17, 2009 | Washing Machines
    Water leaking inside into the barrel when it is not in use.
    yep pretty easy remove the two screws from the end caps on the back of the control panel pull it slightly foward then tilt it back its on hinges then you will see two gold retaniers note how the fit pop the out then you can tilt the body foward and access the valves in the mean time just shut the water off till you get the part to fix it when unit not in use to prevent flooding ok
    Feb 11, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
    Water leak at rear of drum on Hoover Nextra HNF 3157 washing machine
    The outer plastic casing around the drum was cracked by change left in a pocket. I fixed it with a secondhand casing
    Jul 26, 2008 | Hoover Washing Machines
    Washing Machines Logo
    213 people viewed this question
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
