Question about HP Officejet 5610 All-In-One InkJet Printer
My scanner did work at one time but all of a sudden I am getting this msg No Scanner Options refer to device documentation! I dont have my documentation!
  • HP Master
  • 5,481 Answers
Did you get this message when you pressed the button on the scanner? Usually this message means that either the full software (HP Solution Center) isn't installed, the software isn't completely set up (the destinations for the scan buttons must be set) or the monitoring software isn't running.
I recommend you try to scan from the computer using the Solution Center. (Start > All Programs > HP > HP Solution Center for your Officejet if the icon isn't on the desktop). Set the buttons if needed. Check if the monitor program is set to run on startup of the computer. (If you have Windows XP, try Run msconfig.exe ; for Windows 7, Start > Control Panel > System and Security > Administrative Tools > Component Services . Click on Services and see if the HP programs are set to manual or automatic.)
If the HP Solution Center is corrupted you need to uninstall it, unplug the USB cable, reboot the computer and then reinstall. There are tools at the HP site below to help fully uninstall the software.
The documentation is available here: http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&lc=en&dlc=en&product=441125 . See the link for manuals. For other tools, try under the Solve a Problem then Scan and No Scan Options.
I hope this helps.
Posted on Apr 04, 2011
  • 23 Answers
User guide is here:
http://h20000.www2.hp.com/bizsupport/TechSupport/CoreRedirect.jsp?redirectReason=DocIndexPDF&prodSeriesId=441142&targetPage=http%3A%2F%2Fbizsupport1.austin.hp.com%2Fbc%2Fdocs%2Fsupport%2FSupportManual%2Fc00461378%2Fc00461378.pdf
Although I did not see anything in there about that specific error in there.
I do know of a scanner utility that can diagnose and fix more scanner issues on HP all-in-one products. Worth giving it a try.
http://h10025.www1.hp.com/ewfrf/wc/genericSoftware DownloadIndex?softwareitem=oj-45265-1&cc=us&lc=en&dlc=en&dlc=en&lang=en
Instructions for use:
Scroll down the webpage and in option 3 we have the 'Download Only' button. Click on "Download only" button in that page. When prompted, click Save and save it to the desktop of the computer.
Download and install the HP Scan Diagnostic Utility to the desktop and double click it.
After downloading the file, we need to run the file " Scan Diagnostic Utility_ver_1.5" to install the utlity.
After few seconds, below screen will be displayed along with HP Scan Diagnostic Utility will appear on the desktop.
Double click on "HP Scan Diagnostic Utility" icon and select the printer.
After running the utility, we need to select the All-in-one from drop down list, then we need to select "Diagnose" option.
After running the utility, we need to select the All-in-one (if multiple Printers are installed, we need to select appropriate one) and we need to select "Diagnose" option.
If an error condition is identified with any of these components, a Red 'X' displays next to the item. If there are any Red X marks, click on Fix button.
If there is no error condition, a 'Green' check mark displays next to the item. The utility is equipped with a FIX button to correct the error conditions. If there are any Red X marks, click on Fix button.
Then you will receive dialog box with green and red checkmarks. If there are any RED X marks , we can select "FIX" option. And all red checkmarks should change to green checkmarks.
Can't scan- Refer to device documentation to
Try using widows paint. Look in windows accessories off the start program menu. If you open windows paint, look for open file from "Scanner or Camera". Most likely you can get the scanner to work again in Vista. Otherwise...try Vuescan scanner software. I think you can get a free trial period online and it should also work. You'll have to pay for that if you like it.
May 19, 2010 | HP OfficeJet 6310 All-in-One Printer...
Will not Scan. Gets message..
Is it installed in windows as a scanner? Dont use scan button on machine try using scanners or document imaging software that needs to be in place on your computer, ie Document imaging in office or scanners and camera in windows, one sends scan signal from the PC, can use the scan button on scanner only when configued to do such. Scanner has software as does the printer both can found at HP web
Nov 07, 2009 | HP Photosmart 3210 Printer
I can not scan. it said "No scan options" and referer to device documentation.
At first delete your scanner software, then restart ur machine, at that time the machine required the scanner driver. insert ur scanner driver cd and instal it
Sep 16, 2009 | HP J3680 Officejet All In One Printer
My HP J5780 will not scan.
you document was place in a different direction, try to place the document in the right place and scan again.
hope this helps
Aug 06, 2009 | HP Officejet J5780 All-In-One InkJet...
Unable to scan pic to computer
Im not sure of this ..maybe the scanner driver has been corrupt ...uninstall all existing printer driver on your computer...and install a new compatible one..^_^.
May 11, 2009 | HP Photosmart C6180 All-In-One InkJet...
Unable to scan 0n my HP3110 photosmart since changing to vista
Download Vista drivers for your HP scanner and install the same.
Apr 02, 2009 | Office Equipment & Supplies
Scanner not scanning
u will need to download the installation driver from the cd to make the scanner work properly. as the printer drivers r loaded but the scanner drivers did not got loaded. check out this and reinstall the drivers.
Jan 05, 2009 | HP OfficeJet J4580 All-In-One Laser...
HP Officejet 5610 All-In-One InkJet Printer Logo
115 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
