Question about Samsung SF-5100 Plain Paper Laser Fax
Machine keeps saying paper out
Hi, the fax machine's feeder roller keeps on rolling and the message on the lcd states "paper out" It won't stop and keeps on cranking the roller, wont stop ever and has to be switched off. It first started with this problem intermittendly but now it has this problem constantly
  • 161 Answers
You have one of the paper path sensors stuck, or broken. I'm afraid this is a repair center issue, unless you are familiar with the disassembling of the unit. Good luck.
Be blessed.
Posted on Nov 07, 2008
Trying to fax, scan or copy and anytime I try the erro message Document in ADF press OK to discharge document
Hi sdrnjen977,
Here's what you can do to address the issue and clear error message: Document in ADF.
If you press the Stop button during scanning, Document in ADF. Redo operation after checking document in ADF and pressing OK. appears on the LCD. Press OK button so that the remaining document is automatically fed out.
Removing the jammed document from the Document Tray:
1. If printing is in progress, press the Stop button.
2. Turn off the machine.
3. If a multi-page document is loaded, remove any pages other than the jammed page from the ADF, then open the Document Feeder Cover.
4. Raise the Paper Release Lever, then remove the jammed page from under the roller to the Document Feeder Cver side.
5. Pull out the jammed document from the ADF.
6. Press down the Paper Release Lever, close the Document Feeder Cover, then turn on the machine.
Removing the jammed document from the inner side of the Document Cover:
3. If a multi-page document is loaded, remove any pages other than the jammed page from the ADF.
4. Open the Document Output Slot.
5.Open the Document Cover.
6. Insert your hand into the Document Output Slot, then while pushing up the paper output rollers inside the Document Output Slot with your fingers, pull out the document from the inner side of the Document Cover.
7.Close the Document Cover.
8. Close the Document Output Slot, then turn on the machine.
Hope this helps.
Thank you for using FixYa.
Jun 30, 2011 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Suddenly, our Brother MFC 9840cdw keeps spinning its top paper feed rollers, forevier, and says Fax Only, Please Wait. When we press the Copy or Print buttons to get out of Fax mode, nothing happens. I...
It does sound like a paper sensor in the automatic document feeder may be stuck and the machine keeps trying to eject the paper that is not there. I have not seen this before, you may have to call Brother at 1-877-BROTHER to find the nearest service center.
Jun 02, 2011 | Brother MFC-9840CDW Laser Printer
Paper rolling up with the thermal film
The best thing you can do, short of launching the thing into inter-galactic travel, is to clean all of the plastic parts of the machine with an anti-static cleaner. Particularly, the roller that feeds the paper and the carbon roll. Remove all paper and carbon film and unplug the machine. Clean inside the paper housing and the feed rollers before turning it back on. It sounds like a build up of static electricity, a common problem on such thermal based fax machines. Remember, the paper has the propensity to curl because it is on a roll, so any extra help it gets will send it curling like mad. Good Luck.
Jul 20, 2009 | Panasonic KX-FP141E Plain Paper Thermal...
Paper jam in Panasonic KX-FHD331
from person who sending fax ' please eng. hany use it good
Jul 07, 2009 | Panasonic KX-FHD331 Plain Paper Thermal...
"Check Document" message
look for a switch trapped down in the document feeder
Jan 28, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
HP 7680 paper jam
I spent 21/2 hours with the HP tech support - with their recomendation to upgrade my 14 month old computer to the bigger model because the screen reads "paper jam". I have had this printer replaced once already, 1 week after I received it for a defective doc feeder. I decided to take things into my own hands - First of all, no paper was ever located in the paper jam area. Several soft resets by shutting down for 20+ seconds, then pressing #6 at start up resulted in any improvement - the screen continued to read "paper Jam....." the HP tech was unable to offer any practical suggestions.
I turned the machine upside down after removing the document feeder and examined the rollers at the back of the rear tray where the paper jam was supposed to be. I noticed that there was some black residue on the gears and although the machine was off and unplugged - the rollers / gears would not roll freely and seemed to get stuck. I cleaned them thoroughly with an old but clean toothbrush and water. (don't grease the gears - I've heard it eats the plastic) - until the rollers would freely roll when I moved the gray rubber rollers.
Returned the machine to correct position - and turned it on - "paper jam" message returned but the machine was sounding different than it had - so I did another soft reset (unplug from wall and printer for 20 seconds, then holding #6 for a few seconds while plugging back in and now I can print. The printer went through its maintenance cycle and did a realignment. I can print and everything is working fine at this time.
I hope that this will help someone. I couldn't find any information on how to repair the printer and HP seems to be all about producing junk and convincing you to "upgrade" at a cost of $2-300. When this one does finally go - I won't be buying an HP!
The 7680 jams a lot and the document feeder has a lot to be desired. It has trouble feeding straight and if there is a jam anywhere in the machine - it is always difficult removing the paper without tearing it and creating more problems and waste of time.
Oct 20, 2008 | HP Officejet Pro L7680 All-In-One Printer
Loading paper in fax machine
Relax ti mal- the rollers are not picking up the paper because they are dirty or worn out.
Try this clean the rollers with alcohol and try, are the rollers smooth or do they have a rough feel? if smooth replace and it should be good as new.
Good luck
Nov 29, 2007 | Philips PPF-575 Plain Paper Inkjet Fax
Paper Jam message
There are a couple of sensor flags in side the machine and also the document feeder area. Little black levers that flip and trip a sensor. Make sure they are all moving freely. There is one or two in the doc feed area. One inside the paper feed area. One or two in the ribbon area.
Apr 19, 2007 | Brother IntelliFAX 1270E Plain Paper Fax
The document feeder keeps trying to feed
You have a bad Document transfer sensor. Sensor is located under the doc. transfer roller.
Nov 15, 2006 | Sharp FO 6600 Plain Paper Laser Fax
Samsung SF-5100 Plain Paper Laser Fax Logo
48 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
