How can i install PL-SP426 Multi Media Speaker?
2 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: bose companion 3 series 2 multi media speaker system
Hi and welcome to FixYa,
Appreciate the direct "Ask Me".
Initially, the 14 seconds interval is significant. This is indicative that whatever fault it is, it is coupled to a time-based circuitry. The time-based circuitry need not be complicated. it can actually be a simple resistor/capacitor network. The capacitor takes a certain amount of time to charge and then discharge (14 seconds, 'whoomp'). Having said this, then the foremost suspect would be an electrolytic capacitor, probably low value (1~4.7uF), probably a coupler/decoupler. Of course the capacitor serving other functions could very well be the culprit as well.
Corrective measure would entail, identifying/determining which capacitor and replacement. Tedious as it may sound, each capacitor would then have to be tested for capacitance and leakage out of circuit or at least 1 leg un-soldered.
Good luck and Thank you for using FixYa.
Pls be informed that due to my current rank and rating, even a Helpful would be detrimental to my status. Should this solution not address your concern, it would be appreciated if you could just not rate it at all. Cheers.
Posted on Dec 27, 2008
Onkyo HT S3300 center, left front and rear speaker not working.
check your speaker wiring, make sure both terminals are connected properly. or could just be left speaker is disconnected. and is set in stereo mode which will only play left and right front and Sub, if you have one. try chaning the surround mode to play in multi channel speaker which will send sound to all speakers. i trust your using a Digital audio cable from your source ( cable box, DVD player) if your using analog audio cable you will only get stereo sound, and nothing will ever come out of the rear speaker unless you change the surround mode to multi- channel speaker. also in the setup menu you should be able to perform a speaker setup, make sure all your speakers are able to produce sound. follow speaker setup mode in menu, make sure you have checked the boxes or Yes to speaker you have in your system. then perform calibration and a test tone will come out of each speaker as you select them.
Apr 28, 2011 | Audio Players & Recorders
My pc not acsept c media ac97 audio driver
Go here
http://www.softwarepatch.com/utilities/cmedia-9738.html
This download contains AC97 Driver and control panel for C-Media 9738 Sound cards or on-board chips. The setup program will install version 5.12.01.0039 onto most Windows systems. The driver features multi-speaker surround sound and the ability to set your sound card controls, input and output jacks.
Jan 24, 2011 | Computers & Internet
Hi, i hv nokia n95 8gb. it shows a speaker problem.... dere is 2 speakers for multi media progrms. bt d problem is dat d right side speaker emit sound with sm noise...like ZZZUUZUUUU. so wat can i...
when a speaker makes that kind of noise ,it means that the speaker is damaged,and you will need to replace the speaker for clearer sound production.
Take care.
Aug 07, 2010 | Nokia N95 Cellular Phone
I have a HP computer and I Installed a set of Multi Media speakers and only get sound from the left speaker the one withoou the controls , can you help?
First thing make sure the wire is plugged all the way in on the computer. And if that doesn't work make sure the balance control on the speakers is centered. If that doesn't fix it, it could be the wire connecting it to the comp., or the right channel is blown in the right speaker itself. I hope this helps.
Aug 22, 2009 | Audio Players & Recorders
My Altec lansing multi media ada 745 just stopped working all of a sudden. It doesn't work for all media ie. ipod, tv, computer. We can hardly hear it. I changed the fuse but it still doesn't work. Wh
unplug the power from the speakers, reseat the all the connections for the satellite speakers, ensure the power switch on both the subwoofer and the Right Front Speaker are in the ON position.
If that doesn't resolve the issue, then you are most likely going to need to replace the speakers, as the fuse is the only serviceable componet.
May 20, 2009 | Dell Computers & Internet
COMPUTER SPEAKERS
Is there a volume icon in the bottom right hand corner of the screen? If not you need to reinstall the sound card drivers. You can usually download and install these from your PC manufacturer's website (in the suppport section).
Sep 04, 2008 | Audio Players & Recorders
I don't know how to put pictures on my SA9200/17 Philips Gogear mp3 player.
Photos are transferred to the SA9200 using Windows Media Player 10.
Make sure you have installed the software from the product CD. This will install Windows Media Player 10 and Windows Media Plug-In. If you haven't installed the CD, then the Plug-In will not be installed because it doesn't come with the standard Media Player 10.
You cannot transfer photos using Windows Explorer (although you can transfer songs).
The software is not compatible with Windows Media Player 11. If you have version 11, then you'll need to uninstall it, to roll back to version 10, and then install the CD content.
If you are running Windows Vista, then you'll need to check out this article:
https://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?slg=ENG&cat=MP3_PLAYERS_CA&sct=FLASH_AUDIO_PLAYERS_SU&grp=PORTABLE_ENTERTAINMENT_GR&ctn=SA9200/17&mid=Link_FAQs&session=20080508082804_82.5.155.87&hlt=Link_FAQs
The manual covers photo transfer in detail. If you don't have the manual, then download it from here:
https://www.p4c.philips.com/files/s/sa9200_17/sa9200_17_dfu_eng.pdf
If you don't have the product CD, you can also download the drivers and software from here:
https://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?slg=ENG&cat=MP3_PLAYERS_CA&sct=FLASH_AUDIO_PLAYERS_SU&session=20080508082804_82.5.155.87&grp=PORTABLE_ENTERTAINMENT_GR&ctn=SA9200/17&mid=Link_Software&hlt=Link_Software
May 08, 2008 | Audio Players & Recorders
Bus for audio device for laptop
Try downloading yamaha drivers for your media
May 02, 2008 | Dell Inspiron 630M Notebook
42 people viewed this question
 Grubhead
Grubhead
