Question about Maytag MDBH975AWS Stainless Steel Dishwasher
I have a Maytag dishwasher model# mdbh985aws that is not responding. The touch panel will only let you access the delay wash button. It will light up the options for the delay and then you try to set it, it will not work. Can't get any of the the other buttons to work. Any help?
jsrock516
  • 5911 Answers
SOURCE: maytag dishwasher mdbh950awb
Sounds like you have a control panel and/or control board issue. Normally when operator functions fail or "halfway" work the main control board, associated keypad, or wiring are the likely suspect. Now...another remote possibility could be the door latch not closing properly. However, this would affect ALL functions. I hope this helps you.
Posted on Jul 31, 2007
futureloginn
  • 734 Answers
SOURCE: dishwasher will not do anything
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch
Replace if defective.
3. Timer
Replace if defective (note: uncommon problem).
4. Selector switch
Posted on Dec 02, 2008
SUPERMAN_B_1
  • 294 Answers
SOURCE: Maytag dishwasher cannot choose cycle on light panel
hello hmm ok so no lights it sounds like your control panel after unplugging your dish washer check the panel for loose wires the panel is the part behind were your buttons are located will have to remove your back cover to access this if that's all good then try your power cord again make sure its not got any loose wires were it attaches into the dish washer have a nice day and good luck let me know if you find anything.
Posted on Mar 20, 2009
  • 132 Answers
SOURCE: maytag dishwasher MDBH940AWW. ''Touch Panel'' is not working.
Hi There,
Try just replacing the Keypad. It is cheap and is usually the cause. Hope this helps and thank you for using FixYa!
Posted on Mar 30, 2009
  • 457 Answers
SOURCE: MDBH985AWS, I just purchased new-er dishwasher
if you want to see what it looks like you can see a diagram at sears parts direct .com . let me know if this info was helpful
Posted on Feb 27, 2010
Maytag dishwasher will not start
REPLACE THE DOOR SWITCH.....NOT GETTING RUN COMMAND CAUSE SWITCH N DOOR NOT BEING MADE
Oct 15, 2013 | Dishwashers
The auto wash/start/delay start touch controls will not respond...all other control panel area's are working, but I can not get it to start.
It is possible the button contact has moisture or some contaminent. Best to open the control panel and check under the button. Take photos as you go along to make sure it all fits together. You can check the part locations in this diagram.
Feb 11, 2011 | Maytag 24 in. MDBH955AW Built-in...
I have a maytag dishwasher model # mdbtt70awb quiet series 300 when you push any of the wash cycle buttons nothing works. the only button that lights up is heated dry so there is at least power there....
I had the same issue try hitting delay 1hr and start the 1hr was solid not flashing and an hr later it's running just fine. Think I need a new control panel but for now this is working.
Sep 04, 2010 | Maytag Dishwashers
Wont start..light wash lights up and delay wash lights up but start button wont work. replaced handle and it worked one time
There are two micro-switches just inside the handle mechanism that apply power when the door latches. You need to remove the interior panel to access. Hope this helps!
Jul 26, 2010 | Maytag Dishwashers
Feb 25, 2010 | Maytag MDBH985AWB / MDBH985AWS 24 in....
There is a 3 with shape around and a light. it is
I wish I could solve it have same problem Its just maytag junk paid 750 feb 2008 last maytag I buy
Nov 06, 2009 | Maytag MDBH985AWB / MDBH985AWS 24 in....
Maytag Quiet Series 300 Dishwasher not working (Model MDB5601A)
While I am not directly aware of the controls on the dishwasher I'd unplug it for a minute or two to see if the control reboots (for lack of a better term) I've seen many electroic devices that on occasion have this type of problem and simply taking the power from it may correct it.
I hope this helps,
Tom
Aug 22, 2009 | Dishwashers
Contol panel not working
do all your buttons work on the panel? if not, replace the user interface, if they do, replace the main control.
Jun 25, 2009 | Maytag 24 in. MDB7751AWS Stainless Steel...
Mar 19, 2009 | Maytag MDB9600A Jetclean II Built-in...
Control buttons don't work, Help.
donnson, sounds more like the touch panel shorted or stuck keypads. You can remove the touch panel ribbon from the control board and try to clean it with an eraser. You will need to remove the torx screws and remove the inside panel. See if it comes back to life. Behind the toe-panel on the bottom, there should be a tech sheet showing how to check the key pad. The key pad and control board are warranteed for 5 years on this model, parts only. Catriver..post back.
Jan 07, 2007 | Maytag 24 in. MDB7600A Jetclean® II...
Dishwashers Logo
100 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
