Question about Kenmore 20.3 cu. ft. / 575 liter Upright Freezer 23024
Kenmore Elite Freezer 253.240-92102 display on front shows -3F but food inside is thawed
  • 1462 Answers
SOURCE: kenmore upright freezer
reason is that the evaporator is blocked with ice and hence no air circulation.
either
switch off for 24 hours with doors open
or
remove back panel inside freezer and melt ice off with a hairdryer
Posted on Oct 16, 2008
TheMobilian
  • 8220 Answers
SOURCE: food thawing in freezer
You may have a small leak in the evaporator. You could try to get a replacement freon with stop leak from the automotive store and give it a shot. If it is a R12 unit then it is too old to repair. But it is worth the gamble to shoot it with freeze 12 or an equivilent before you condemn it.
Posted on Apr 11, 2009
Maytag317
  • 1136 Answers
SOURCE: frozen drain line from top freezer to drip pan
Hi, Remove everything in the freezer. Get as much ice out as possible with out using sharp object. You will need to remove the rear evaporator panel inside the freezer and locate the drain hole below the evaporator. The safest way is to use a hair dryer. Once you can get to the drain hole and get the ice down inside the drain thawed (a few glasses of hot water usually gets the job done) Try and run a wire (I use a hose or biasting seringe) and get that drain hole flushed out real good. Sometimes it takes 45 minutes or so. After that is cleaned out, put the rear panel back on and you should be all set.
I hope I have helped you. Please let me know if I can be of more assistance.
Thanks
Vic
Posted on May 13, 2009
  • 363 Answers
SOURCE: Food in freezer is thawing, compressor very hot to the touch
It sounds like the motor to the circulating fan is wearing out . This fan is hard to diagnose as it will spin the blade , but as you said it will not spin fast enough to circulate air thru the freezer and refrigerator. The motor is DC non brush type. It will cost a minimum of $300.00 to repair/replace this fan assembly, but it is worth that compared to replacing the refrigerator
Posted on Jul 28, 2009
  • 97 Answers
SOURCE: FREEZER MAKING ICE, BUT FOOD IS THAWING
If you have a Freezer on the top model Kenmore, with warm temps in the fridge, AND water dripping onto the top shelf of the lower fresh food compartment (FFC), this is usually caused by a clogged defrost drain. Since Kenmore is not an actual manufacturer of anything, they take other brands, i.e. Kitchenaid, GE, Frigidaire, etc., take their names off and put on a shiny Kenmore nametag. This is a common problem with Kitchenaid refrigerators. You can determine if your Kenmore is made by kitchenaid by looking at the model # tag. the first three digits will indicate the manufacturer, Kitchenaids begin with the sequence, 106.*.If this is indeed how your model # begins, keep reading. Since the water cant go down the drain tubing to the pan at the bottom of the unit, it builds up on the freezer floor, eventually blocking the air return vents from the fridge to the freezer, and the vent from the freezer to the fridge. YOu can check this very easily. Look at the ceiling of your FFC, near the back. toward the sides you will see two square holes, about 2" square, stick your finger and feel around the inside of those holes, do you feel any ice/frost, or do you just feel styrofoam, you might even see frost/ice below the level of your ceiling? This drain usually gets clogged with defrost water that does not completely drain, then of course it freezes, eventually plugging up the drian hole located at the level of your freezer floor, behind the back wall. The water keeps accumulating, and freezing, on the freezer floor, eventually filling in and clogging the air vents..no air flow , the fridge wont cool. The easiest way to resolve this, empty out all contents and store someplace cold for 24 hours...a 2nd fridge, outside in a cooler if its cold like here in chicago. After its empty, unplug, open both doors and blow a fan for 24 hours. Prepare for an abundance of water due to melting ice.
After you defrost, you can plug it back in and it will be fine, HOWEVER, I suggest you take the back freezer wall off, you might have to take a floor cover off first, likely 2-4 screws in both the floor and the back wall. When you have the evaporator exposed, you will see a black cal rod defrost heater underneath the evaporator, as well as your drain hole just to the right of center underneath both heater and evaporator. Take a piece of 12-14 gauge solid, not stranded wire, removing the insulation and exposing the entire 6-8" piece of copper wire. wrap the wire around the diameter of the cal rod heater, 3-4 turns should be sufficient, and stick the other end of the wire down that drain hole. This will melt any ice that will build up in the future, everytime your unit goes into defrost cycle, so this wont happen again.
If air vents are clear of frost/ice, next thing to check is the back wall of your freezer, does there appear to be frost/ice/snow on the back wall? If so, your unit is not defrosting. On most Kenmores, this is usually caused by your defrost timer, located in the canopy mounted at the top of the FFC on Top freezer models, or your defrost thermostat, which is clipped onto the evaporator coil inside your freezer. Again, if its a 106 model Kenmore, this thermostat will have a pink and a brown wire coming into/out of it. My suggestion, if it isnt defrosting, change both. tjhe defrost control will connect with a plug, but you will have to hard wire the thermostat, ( cut wires from old, strip wire, and connect using wire nuts and electrical tape.)
Since y ou mentioned the water accumulation, more water recently, my diagnosis would be the former versus the latter, as the lack of actual defrosting coincides with lack of defrost water, however I'll never say never.
If your unit is a side by side model, check for ice on freezer floor...clogged drain. Check again for frost/ice on back wall, not defrosting, check same two parts, (the heaters rarely go bad on Kitchenaids, but never say never) You should also check for air flow into fridge, even if no frost / ice visible on back wall. Open the FFC door, and locate the air vent near the top, back of the fridge, on the left wall. While depressing the door switch, AND WITH THE FREEZER door closed, put your finger/hand near that vent. Do you feel any cold air? If you dont, you could have a bad door damper, not uncommon, or a bad damper control--> the temperature control WITHOUT the off or "0" position.
If any of this seems a bit overwhelming, I suggest you have a reputable repair technician check your fridge.
Oh, and lastly, you WILL NOT have two compressors, one for each compartment, nor will you have two sets of defrost heating elements, one for each half.
ALL cooling for 99% of refrigerators made in last 25 years takes place in the freezer, with the fridge being an empty box, except for an air intake vent, and an air exhaust vent which leads directly back into the freezer. When a refrigerator unit seems to still be cold in the freezer, but not cold enough or not cold at all in the FFC, its ALWAYS going to be caused by lack of air flow. But as you can see, there are a few things that can cause that lack of air flow.
Posted on Apr 05, 2010
With deluxe Electronic Temperature Control Freezer control panel shows "OF" and I can't restart the freezer
Search Results
    Freezer electronic temperature control manual... ' Sears ...
    www.searspartsdirect.com > Ask an Expert
    Jul 5, 2012 - I have a Kenmore elite freezer with electronic temperature control. ...my freezer was delivered yesterday, the control panel is stuck on of, ... an electronic control on front. the display is showing hi temp and door ajar. also an l in ...
    Control Panel is not working right - Samsung
    www.samsung.com/sa_en/support/skp/faq/239315
    Samsung ElectronicsSep 3, 2015 - In case of wrong temperature display, possibly door opens so inside ... If the control panel is still not lit up after you plug the refrigerator back in, it may ... When initial installation, Temperature will show current temperature for a ... When the refrigerator/ freezer reach the set temperature, the blinking will stop.
    Adjusting Side-bySide Refrigerator Temp Controls - Actual ...
    ? 3:50
    https://www.youtube.com/watch?v=DFzTGKVo79g
    Jun 27, 2010 - Uploaded by GE Appliances
    CAN I TURN OFF THE DIGITAL CONTROL ON FREEZER AREA ONLY. ... I need to know How to reset this kind of refigirator, same front panel ... When you try to set the actual temperature, does your control show your new ...
    Electronic Temperature Controls - ManualsLib
Feb 03, 2016 | Freezers
Door seal not tight on upright freezer
Check the door sits straight and square on the front. You can "adjust" with the heel of your hand to make it sit flat against the frame. Even a poor seal shouldn't make frozen food thaw - check and clean the condenser and fan
May 08, 2012 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Frosts up at front then food starts to defrost
It would appear to me the system has a leak. Allow me to explain. When a fridge/freezer is "lo" on gas it causes the compressor to run far longer than usual. As a consiquence the motor overload shuts it down, potentially for a very long time, hence the contents thaw. The major clue to this a frost pattern on just one wall. Have a tech visit to confirm, but I suspect you'll be out of luck as far as a repair goes. Chest freezers are not easy to repair "lo side" leaks, which is likely what you have, because the evap. coils are in the walls. sorry, but I hope that helps in some manner. good luck
Sep 28, 2009 | Kenmore 19.7 cu. ft. / 558 liter Chest...
Mu upright freezer door seal was loose and it is leaking from door would this cause domw food to thaw and can it be fixed
a leaking gasket can cause food to thaw and it can be fixed if a new gasket is avaliable from local appliance parts place..the gasket is held on by the liner which is removed by gently lifting the gasket and removing the screws..the reverse to install the new gasket
Sep 16, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Alarm goes off and freezer not cold
The light indicates the need for a new battery (9V)
Jul 21, 2009 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Freezer Not Freezing Food
there is a circulation fan and also a vent. Either the fan is blowing, or there is a cloged vent.
Feb 11, 2009 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Defrosting???
your food should not thaw in a frost free freezer. but I can not tell you why it is thawing, sorry.
Apr 25, 2008 | Frigidaire 13.7 cu. ft. Upright Freezer...
Kenmore 20.3 cu. ft. / 575 liter Upright Freezer 23024 Logo
51 people viewed this question
Top Kenmore Freezers Experts
AJMAL KHAN
Dan Webster
Dan Webster
Jay Finke
Jay Finke
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
