Question about Garden
Mower started and ran great for about 50 mins. and then stopped. I added gas as it appeared to run empty. It started back up, but would only stayed running for a few seconds, before turning off again. Repeated again where it starts, but shuts off after about 3 secs.
    Scholar:
  • 44 Answers
You did not mention whether your mower has a 2-cycle or 4-cycle engine. 2-cycle engine may require 2-cycle oil mixed with the gas to lubricate the pistons/cylinders.
4-cycle engines do not require mixing gas & oil as they have a separate sump for oil. These engines are quite easy to maintain and will last for many years. The most common problem is the fuel delivery system. If you allow the fuel to run low, debris sitting at the bottom of the tank is picked up and can clog the strainer (if so equipped). Check for a clogged in-line fuel filter and replace as needed. Occasional cleaning of the fuel inlet and strainer may be necessary; some disassembly is required. The carburetor jets also suffer from blockage usually caused by varnish residue from gasoline if the mower was allowed to sit for long periods of time without the fuel being drained or at least treated with some type of fuel stabilizer (Sta-Bil is one). If you have time, open up the carburetor and spray all the fuel passages with Gumout Carburetor cleaner to dissolve said varnish. Jiggle the choke mechanism while spraying to dislodge carbon build-up at the butterfly valve. And if you have a compressor, blow out these passages with pressurized air. Poking them with wire is a NO-NO. If it has a paper-element filter and it looks like you can plant grass on it, it is time to replace them. Does it have a re-usable/washable air filter? Clean the filter element with an air filter cleaner solution (or dishwash detergent) and re-oil (I use K&N filter oil) once dry.
Always use clean gas (your gas container may be contaminated over the years) and an ounce of STP carb cleaner per gallon of gas usually keeps things clean.
Posted on Apr 04, 2011
  • LouieBenz Apr 04, 2011
    Spark plugs could also get fouled and misfire. It only takes a few seconds to replace one, especially if you went through all that trouble to clean the carburetor and gas lines...and it doesn't cost much. I recommend bringing the original plug for the parts store to match. More often than not, parts stores may not have the capability of looking up the correct spark plug for lawn equipment but are able to cross-reference a part brought in by the customer. Replace the spark plugs once a year.
Key will not work on ignition.
it has and oil safty switch on it you will have to push it to some flat ground to start it you will have to wait to start it let the oil settle down to level dont leave lawn mower on a hill it will happen every time
Aug 16, 2014 | M T D Products Mtd Gold 50"" 25 Hp Zero...
Need to do anything special after mower emptied of gas?
You probably have a dirty fuel jet. If there is a fuel cup on the bottom of your carb take it off and clean it as well as the fuel jet. when you empty the tank you stirred up the dirt in the tank bottom.
Jun 10, 2014 | Husqvarna Garden
My john deere push mower starts fine mows for 10 min quits wont start so I took the the gas cap off looked at it put it back on push the prime bulb 1 time it started ran for 10 min quit did the gas cap...
I'm not sure of the model number of your mower or engine to know the fuel and carburetor set up. I do have one easy thing to try though as it sounds as if a vacume is building up in the tank. Try putting a half of tank of gas in it, leave the gas cap off, and see if it continues as it was or if it runs ok. If this stops the issue your cap vent is pluged up. I hope this helps
If you need further help, I’m available over the phone at https://www.6ya.com/expert/steve_f5a6ca85b5d1ffc9
Oct 03, 2013 | John Deere Garden
10 min. run time
Sounds like the vetilation hole in the gas cap is plugged, so fuel feeding out pulls a slight vaccuum in the tank. Flow stops until some air leaks in. Clean the cap or leave it loose.
Dec 02, 2017 | Garden
1989 Ford 150 4cly truck will run fine then starts cuting off and dies out . . no one can fix it. in shop now. shop owner pay labor can not fix. in shop 50 days
Hi, Check fuel pump that it is running properly. Sounds like an electrical problem with the pump. Good luck.
Oct 29, 2012 | 1996 Dodge Ram
Lawn-Boy 20" mower stalls when hot and blade clutch engaged
probably the valves have unseated the hotter it run the worser it get warranty defect take to dealer tell what it doing tell him you think its un seated valves and cover under warranty
May 20, 2012 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
I bought a john deere riding mower less than a year ago. i used it last season without any problems. I think the last time i used it, was in august 2010. winter came about, the grass wasn't growing, so...
First, I've had a motorcycle for almost 50 years and have never drained the gas. At one point it was not used for 3 years. It started, I added gas and it ran fine.
Second, next time you are running the machine and it begins to stall, immediately loosen the gas cap. If it starts to run good again, drill out the air vents on the cap.
Gary
Mar 09, 2011 | Garden
Garden Logo
55 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
