Question about GE Bright Stick 25" Fluorescent Tube Instant Lighting with Mounting Kit 6' Co
How do you replace the bulb on the bright stick?
Need to adjust the brightness. The projection is too dim to see clearly in a classroom.
Appears bulb is burning out ?
If this is a replacement bulb, is it a proper replacement ?
Not all bulbs are dim-able.
May 12, 2014 | NEC NP100 Projector
Dashboard symbols mean
It is the defective bulb warning light. It is a warning that a bulb has failed and needs to be replaced.There is a similar symbol that is an automatic transmission warning light but from your description I believe it is the bulb warning light. Hope this helps.
Jan 12, 2014 | 2003 BMW Z4
BRIGHT BULB LIGHT NOT SHOWING WHEN ON OR OFF BRITE
Try replacing the bulbs, I believe it should be #1157.
Jan 12, 2010 | 2003 GMC Safari
My brights do not work. I replaced bulbs,
I would go to an auto parts store and get one of those cheap ground detectors [looks like a little screwdriver with a bulb at one end and a wire withe an alligator clip on it].Test the wiring circuit by starting from the bulb and working toward the firewall until you find the issue [the point where the bulb lights up on the detector].
Dec 31, 2009 | 2001 Toyota Camry
I have a Mitsubishi Eclipse 2000 Gt. I recently been having problems with the right headlight. I thought it it went out. So i went to auto zone and bought a new bulb. But it still won't turn on. So i tried...
Did you check the socket that bulb plugs into.I hav seen where they melt for, the hat produced by the bulb.If that isnt the issue,I would suspect the headlight switch.But first stick to basics.Check all the fuses.
Dec 12, 2009 | 2000 Mitsubishi Eclipse GT
2005 Jeep Liberty Sport. Headlights. Passenger Side is dim
TEST
remove both bulbs from the lamps but leave them on their wires switch on and see if the bulbs are still different brightness if not they the passenger side lamp housing has damaged mirror is dirty or missalined and needs adjustment. if they are different brightness then this may be a earthing problem.
Nov 13, 2009 | 2005 Jeep Grand Cherokee
No high beams on 1999 Dodge Caravan; low beams work fine
replace the switch in the column i had the same problem on a 1996 caravan when i replaced the switch the problem stopped
Jan 02, 2009 | 1999 Dodge Caravan
GE Bright Stick 25" Fluorescent Tube Instant Lighting with Mounting Kit 6' Co Logo
520 people viewed this question
Top GE Home Experts
Douglas Dinnebeil
Douglas Dinnebeil
Gene Haynes
Tom Chichester
Are you a GE Home Expert? Answer questions, earn points and help others
