Question about LG WD-3243RHD Front Load Washer / Dryer
Drying problems I have the LG Washer/Dryer all in one and it works fine, except for now when it is drying, the unit will intake water for a few seconds and then it makes the clothes soggy and then I have to spin them again. The only way it does not do it is if I turn off the water valve before drying. Can you please give me some advise?
  • Anonymous Mar 12, 2014
    my gas dryer lights fine for a few seconds, there is flame, it goes out and a few minutes later lights again. it takes too long to dry clothes
    Novelist:
  • 116 Answers
This usually indicates that the fill valve for the drying cycle is faulty. In short you need a new cold water valve assembly. (this will fix this issue 90% of the time) Otherwise you may need a new control board.
Inside of the machine (you will have to remove the top cover from the machine) is a valve assembly attached to the cold water line. This valve assembly consists of 2 or 3 individual valve bodies . The one on the right hand side of the assembly usually controls the cold water inlet for the drying cycle(this is necessary for proper condensation drying to take place). There is a black hose which attaches this part of the valve assembly to the wash drum. With the water shut off and the power removed from the machine, remove this hose from the valve and look to see if it has a small red (usually) plastic insert. This is a restricter insert which limits the water flow into the tub. Without the insert the tub will fill with cold water in a short amount of time.
Posted on Aug 05, 2008
My lg tromm DLG69885 gas dryer is not heating; otherwise it works fine. Dry light flashes cooling light stays on solid
I am using LG Tromm DLE2514 washer dryer. It 's running but didn't dried the clothes. I clean it's lint but still it's not working. The one thing i notice now is it's drying light is blinking and cooling light is turn on all the time during the cycle. So what's the problem with my dryer?
May 20, 2010 | LG DLG5932W Gas Dryer
LG TROMM WM3431HW(?) soaks clothes in Dry Cycle
LG says to unplug unit. Or remove power by tripping circuit breaker. Wait a minute and plug back in. Good luck.
Mar 25, 2017 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washer-dryer # wm3677HW will not dry,heats up, run, on and on
You're a moron. This unit washes and dries. That's the whole point of it. Perhaps you should do some research before answering the question. the most likely cause is the water lever sensor.
Aug 09, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG Senseclean washer dryer combo won't dry
The problem is likely due to lint build up in the condensing unit. I found a solution here:
http://www.motusconnect.com/blog/2009/1/5/lg-washer-dryer-drama-%E2%80%93-diy-fix
I also had a softball size ball of wet, packed lint in the condensing unit. I found that the unit can be cleaned without tools or dis-assembly by:
  1. draining the water.
  2. laying the washer on it's back.
  3. removing the hose clamp on the rubber bellows that connects the drum to the condensing unit (right hand side of machine).
  4. digging the lint wads out with your fingers and a small screwdriver.
Happy drying!
Jan 15, 2009 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
Washer/Dryer
weak pump...but remember in the drying cycle water is ment to come in and flush out lint and produce air flow for drying..it also cools drum..
Dec 16, 2008 | LG WD-14124RD Front Load Washer / Dryer
WM3988HWA Pumps Cold Water in Drying Mode!
Replace the 5 way valve. get the old flow restrictor out of the drying cold water line before reconnecting. It came out of the valve to cause the problem.
Oct 17, 2008 | LG WM3988HWA Front Load Washer / Dryer
LG all in one washer dryer fills with water on the drying cycle
the unit is made to bring water in in the drying cycle ,,the water dont touch the clothes..the water is to take the lint away and to cool the drum,,you must remember that you can was 22 pounds but you can only dry 11 pound..so you must dry about half of what you wash..and drying the 11 pounds it will take 3 to 4 hours,,no exhaust...
Sep 21, 2008 | LG WD-3274RHD Front Load Washer / Dryer
Washer Dryer
washer dryers work by using a fine jet of cold water to condense the steam from your clothes drying. therefore, water has to be turned on when in the drying mode. make sure water is on.
after that, if water is in fact turned on, then the fault will probably lie in the valve being open circuit
Jul 06, 2008 | Washing Machines
LG DLE2532W Electric Dryer doesn't allow adjustment of drying options
it may be possible the contol is bad can you change the settings at all
Feb 07, 2008 | LG DLE2532W Electric Dryer
LG WD-3243RHD Front Load Washer / Dryer Logo
207 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
