Question about Baby Gear
Items PY86992, how do u lock the short size? - Baby Gear
  • 396 Answers
Pack N Plays have a rule. The bottom floor MUST BE UP to raise OR lower the sides.
Raise the floor using the teather or round locking mechanism on the floor. Now raise the sides
up to locked position and then push the floor down. This is a safety for ALL Pack N Play play yards.
That should do the trick.
Posted on Apr 04, 2011
Everytime i try to replace a fuse it keeps blowing
Isolate that circuit you have a direct short someplace. Without additional information you need to find a wire broken or the item its powering might have an internal short. I'm assuming your replacing the correct size fuse. These can be tough to find but start by unplugging whatever the fuse is energizing
Jan 18, 2016 | Cars & Trucks
Why won't the lock disengage?
Most likely, the electric lock mechanism is jammed and/or shorted out and it must be replaced.
Jul 30, 2015 | Kenmore HE3t 4.0 cu. ft. Front-Load King...
Control lock light is on , toke door lock off once cleaned it put it back on and it worked now its on aagain and washer wont work
1 close washer door and dispenser drawer
2 select Clean washer cycle
3 Press start/ pause
The basket will rotate,then the door will unlock,lock again,then the cycle will continue
Water should come in and run a short sensing cycle about 3 minutes
4 This will determine item in the washer
a if no items are detected it will move to step 5
b if item are detected wash any control lock light will stay on door will unlock open and remove any garments
If b pessnpower to cancel f code then repeat 1,2,3
Once cycle begins allow it to finish
5 after cycle is complete leave the door a jar to allow for venting and drying of interior
Only use HE high efficiency detergent
Jul 05, 2015 | Whirlpool GHW9100L Front Load Washer
03 dodge stratus my stereo interior lights and door locks quit working
firstly check the fuses it sounds like all of those items may share a fuse. replace fuse and one by one turn appliance on att a time to try and work out which item is creating the short out. always replace fuse with same value fues
Jun 29, 2014 | Cars & Trucks
Tube size seatpost cruiser
Take this to your local bicycle shop for the exact size and placement/position. Do not guess or else you will only spend money on items you do not need.
Feb 27, 2014 | Genesis Gx7 astra
Electrical problems
there is a loose connection somewhere..start at the battery and work your way through each item..it may be the cab connection under the brake booster..
Dec 15, 2013 | Oldsmobile Cutlass Ciera Cars & Trucks
Icon short cuts doubled in size. How do I get them back on my desktop to normal size??
Windows XP Right click on an empty spot on your desktop and choose properties then click on appearance then click on advanced option, there you can see one tab named items select icon ,same tab right hand side you can select size of the icon(normal size-32), after that click on OK on both windows this steps should change your icon size.
Windows Vista or windows 7
Right click on an empty spot on your desktop and choose Personalize, now choose the first item on the list Windows Color and Appearance, and then click the last link Open classic appearance properties for more color options,
then click on advanced option, there you can see one tab named items select icon ,same tab right hand side you can select size of the icon(normal size-32), after that click on OK.
Regards,
Shibi P G
Jul 17, 2011 | HP Computers & Internet
My interior dome lights do not work and neither do my power locks, i am sure this is the same fuse, i open the fuse box in the engine and there is a fuse missing and it is labeled done, i read my owners...
Are you putting in the right size fuse? Your owners manual should direct you to what size fuse to place in there, and be sure to use this size. don't use a higher size, as it could cause a short and/or fire.
If you are using the right size fuse.. then you have a short in that system... somewhere.
Jan 07, 2011 | Lexus ES 300 Cars & Trucks
Image on screen cropped. can't find menu items to adjust screen size.
on the back side of set should have a control that says vertical size/ sweep. it is recessed into a small hole or has protruded knob, if so used a small flat tip common screwdriver for the adjustment. make sure you can see the control knob or slot clearly otherwise you could short out something!!!!!
Sep 21, 2009 | Zenith A27B33W 27" TV
Door locks are shorted out in the open position and the horn is shorted out in the honk position and they are draining the battery. i had to pull the large accesory fuse in the power distribution center to...
You possibly have a bad switch. The one in the driver's door has 6 switches on it. Unplug it to see it your problems stop with the door. Your horn relay is shorted, replace it to stop the honking. Could also be the switch plate is in the short position. Unplug your horn, under front driver's side. Pull black splash guard behind/under front driver's bumper to access it. Unplug wire from horn. Relay should be under driver's side dash. Take off knee guard screws and you should see it in there. Unplug/replace it.
Jul 24, 2008 | 1995 Jeep Cherokee
Baby Gear Logo
91 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
