Question about Vacuums
I need to see the filtration system of a lumina bagless vacuum cleaner, Product # 3552. Model CP-CY4201. i DONT THINK THIS ONE HAS BEEN PUT TOGETHER QUITE RIGHT. rEGARDS Sue
  • 22 Answers
SOURCE: how to put on a belt on eureka uno bagless vacuum cleaner
Unplug the vacuum.
Turn it over so you have access to the bottom of the unit (you should see the brushroll)
At the base where the "head" attaches to the body there is a small silver button that you must depress to remove it from the body. Press the button in with a screwdriver or unsharpened pencil while pulling the "head" away from the body.
Use a #2 Philips screwdriver to remove all the large screws from the bottom. They are all the same size and type so you can collect them for safekeeping without worrying about which one goes where. There are 2 smaller screws (if I remember correctly) that are for the upright lock that you do not need to remove. They will be on the small plastic piece near where the bottom brush "head" attaches to the vacuum.
Remove the clear plastic clog cover.
Gently pry the gray cover off. This shouldn't be too difficult as the cover goes loose when you remove the screws.
Flip the gray side over and you should see the innards including the brushroll, the motor, wiring, etc. Facing the assembly like you were looking head-on at the vacuum the belt should be on the right.
Pull up the far end (non-belted end) of the brushroll and then the belted end.
The brushroll should now be free and you should check the teeth on the belted end of the brushroll to ensure none are broken.
Remove the old belt from the motor (also toothed) and replace with new belt (a second spare would be handy to keep around and this is a good opportunity to clean up the air path).
Put toothed end of belt into the belt loop and stretch it a bit to get the toothed end back into place. The belt should auto adjust but just in case you may want to manually rotate the brushroll a few times after replacing the far end (non-toothed end)
Repeat the rest of it in reverse order to put it back.
Posted on Feb 03, 2009
EwingElect
  • 276 Answers
SOURCE: vacuum cleaner won't go - missing a step
In between the filters there's an access panel that can be removed - there may be a blockage there. You should also check your hose for a blockage.
Otherwise you may need to take it to your local Electrolux Service Center. There may be a problem with the pressure board. The machines have a 2 year warranty, not sure what it'd be in your neck of the woods.
Posted on Apr 03, 2009
  • 33 Answers
SOURCE: download parts and operators manual
This owner's manual is available on the Eureka website. www.eureka.com Type in your model # down in the right corner, search & buy accessories.Click go, then choose either the 402A or 402A-1. It is the same owner manual for either one.
Posted on May 19, 2009
  • 21 Answers
SOURCE: Looking for the instruction manual for the Eureka
Go to http://www.eureka.com/service/manuals/80244.pdf this is a direct link to the owners guide for your model or you can call customer service at 800-282-2886 and request a hard copy
Posted on Jul 19, 2009
  • 16 Answers
SOURCE: My vacuum cleaner belt keeps burning up as soon as
CHECK ROLLER BRUSH PROBALLY HAS STRING WRAP UP AROUND THE ROLLER OR THE END BEARINGS ARE FROZEN IF SO SRAY WD40 IN BEARINGS TILL THEY FREE UP OR REPLACE ROLLER BRUSH
Posted on Nov 03, 2009
When you turn it on the lights on the battery come on and the brush roller will turn but the suction motor will not turn on.
Hoover Air Cordless Series 3.0 Bagless Upright Vacuum ...
www.amazon.com/Hoover-Cordless-Bagless-Upright...
Amazon.com, Inc.Hoover Air Cordless Series 3.0 Bagless Upright Vacuum, BH50140 ... The batteries come pre-charged, plenty to get up and running. ... The brush will stop as soon as the handle is in the upright position for like using the attachments. ..... and in need of charge, in carpet mode, the motor runs, but the brush roller won't spin.
Hoover Air Cordless Series 3.0 review - Best vacuum cleaner
www.vacuumsguide.com/hoover-air-cordless-series-3-0-review/
Rating: 4 - ā€ˇReview by Jason Roberts
Aug 4, 2014 - Hoover Air Cordless Series 3.0 is a new upright vacuum cleaner reviewed by ... power, 2 batteries - each lasting 25 minutes, good filtration system,light ... Just as in the case of the Linx, it filters dust particles, but doesn't come with HEPA filtration. ... Multi-Floor Cleaning - you can turn the brush roll on or off.
Dec 18, 2015 | Hoover Air Cordless Series 3.0 Bagless...
Manual for bissel upright bagless vacumn cleaner
Not knowing what needs to be put back together I am giving
you this phone #....Bissell Consumer Services !-800-263-2535
Make sure you have the Model Number available.
Regards,
Dennis.
Aug 24, 2014 | Bissell ProHeat Turbo Deep Cleaner Upright...
I PURCHASED A DYSON DC39 ANIMAL CANISTER VACUUM CLEANER ON 1/14/13 AND HAVE NOT BEEN VERY HAPPY WITH IT.
Why do you put your opinion about things we don't sell on this site? Would it not be better if you went to the firm who sold you the product, or the firm who made it, or the firm that does not want to support your system.
We are only volunteers trying to help people with most technical questions. We don't sell things or services, so we don't need to support anything. I don't think it is fair to blame volunteers here, for things that went wrong somewhere else.
Thanks
Jul 21, 2014 | Dyson DC31 Bagless Handheld Vacuum
Bissell pet hair bagless instruction manual
Do you mean the Bissell Pet Hair Eraser bagless vacuum cleaner? The user manual for this vacuum is available from the product page: http://www.bissell.com/pet-hair-eraser-vacuum/ . Look on the right hand side of the page. The direct link to the English version of the manual is: http://www.bissell.com/assets/0/132/134/228/e5babada-7240-40ea-93c0-90427ed32741.pdf . Note: you will need Adobe Reader or a similar product to access (read/print) the manual.
Bissell has a number of vacuums for cleaning up after pets. Look for your vacuum here: http://www.bissell.com/pet-vacuum/ . The manuals for most are on the product page. For example, there is also the Bissel Pet Hair Eraser OptiClean Cyclonic vacuum. The manual is here: http://www.bissell.com/assets/0/132/134/228/dd4a7280-504f-4483-84a1-bfcc3a239f45.pdf . Older product manuals may be available here: http://www.bissell.com/customer-support/ . Scroll down to the Users Guide search box.
I hope this helps.
Feb 07, 2013 | Bissell Vacuums
I have a Bissell powerfoforce Bagless. A friend just gave me her older one, she is off to buy a newer model. I have been through every vacuum cleaner you can image, dirtdevil , kirby, etc and on and on. Sh...
There are at least 18 different models of Powerforce. There are too many parts and pieces to be able to describe what you need without seeing it. I suggest paying your local vacuum shop to put it back together. It may need a new belt, brushroll and/or filters. Do scrimp on these things if you want it to work properly.
Mar 14, 2017 | Bissell 6594 PowerForce Bagless Upright...
Is there a diagram/picture to help me visualize how to put cleaner belt back in vacuum? I was taking base of vacuum apart so I could get rid of hair that were wrapped on the roller. The cleaner belt came...
Sorry to hear your belt fell out. Not good if you've never replaced a belt before...
Here is a website where you can read a detailed description of how to change a belt: http://www.ehow.com/how_8034505_eureka-belt-replacement-instructions.html
I don't think you'll need a photo, it's pretty straight forward. However, there are schematic diagrams for vacuums but they don't show how they go together.
If you have trouble, reply back to me and I'll try to describe for you.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Apr 21, 2011 | Eureka 431A Optima Bagless Upright Vacuum
What filters do i need for the eureka the boss bagless vacuum w/widetrack modal 4495
There is a Cassette Micron Filter 60696.If you have a HEPA cartridge filter you need EUREKA's HEPA part 61500.In earlier models there is a micron filter instead of a HEPA filter--for that you need EUREKA's Micron part 60801. But if you have that HEPA filter, the manual says you have to use the HEPA filter to achieve the closed HEPA filtration system again.
Dec 10, 2010 | Eureka 4495A Bagless Upright Vacuum
HEPA Filter
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618630&thid=730623
HEPA Filter
Posted by jenski66 on Jul 02, 2008
My vacuum came with a sponge over the filter and the directions said I could wash the filter. Do the directions mean to wash the black sponge or the actual filter? Is the sponge part of the filter or is it trash?
Filter F27
Dirt Devil Purpose Cleaner for Pets
Upright Bagless Vacuum
Model #1LY2108-000
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Typically the top filter of which is the sponge is washable but the HEPA filter is not, it can be brushed off and vacuum off with another vacuum, but the best filtration is to replace the HEPA filter and to wash the sponge filter, if the sponge filter get to bad then replace the sponge filter as well. Or, you can check with your local vacuum cleaner dealer in your area or to contact the manufacturer’s website and or phone #. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://royalvacuums.com/ Customer Service 1-800-321-1134
Hours are: 8:00 AM to 7:00 PM (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 02, 2008 | Dirt Devil 12 Amp HEPA Filter Vacuum...
Need instructions to reassemble Eureka vacuum
http://geeksquad.fixya.com/ThreadView.aspx?prdid=12503&thid=680704
Posted by TamiLynn on Jun 18, 2008
I had to completely disassemble my Eureka Whirlwind Lite Model 410 bagless vacuum due to an excessive amount of debris that collected in an inconspicuous spot and now that I've reassembled it sounds like something from the motor is rubbing inside somewhere as if I put it together incorrectly. Do you have any schematics on what the insides should look like so I can put it together properly?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The best way to get the schematics is to contact the Eureka Factory @ the listing I will give you below. Sometimes the owners manual have the schematics in the owners manual but if not they might be down loaded from the factory website or to contact them by phone
And ask for cust serv or the serv tech support or parts for the schematics. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.eureka.com Customer Service 1-800-282-2886
Customer Service Dept
Electrolux Home Care Products
P.O. Box 3900
Peoria. IL 61612
Hours of Operation
Monday thru Friday 8:00am to 7:30pm CST
Saturday and Sunday 10:00am to 6:30pm CST
Go Ahead. Use Us.
Jun 18, 2008 | Eureka WhirlWind 4381 Upright Vacuum
Changing belt on vacuum cleaner
If you can't see the motor shaft then you will have to take the top cover off. Some have a couple of scres to remove from the bottom. Then is a slot on each side, from the bottom put a flat blade screwdrive in the slot and push out and up to release the locking tabs. The knob may pop off so watch for that coming off. Put the belt on the brush roll, then feed the belt up thru the opening and stretch it to go over the motor shaft. Put back together.
Jan 20, 2008 | Vacuums
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
