Question about KitchenAid KUDD01DSSS Built-in Dishwasher
Top drawer of dishwasher will not turn on says its locked. Could you please tell me how to unlock.
    New Friend:
  • 3 Answers
You have to push the pro cycle for about 10 seconds and that will cancel lock message.
Posted on Feb 07, 2013
2 Suggested Answers
mikelpoynter
  • 77 Answers
SOURCE: I have a top drawer and a bottom drawer type. My
1. Locate the "Energy Saver/Dry" button on the dishwasher. The location of this button will be different depending upon the specific model number of the dishwasher, but should be easy to spot. If you have trouble finding it, you can check the diagram in the manual of your dishwasher for the exact location for your specific model.
2. Press and hold down this "Energy Saver/Dry" button for at least four seconds. Make sure that you do not release the button until at least 4 seconds have passed, otherwise the lock will not become disabled.
3. Check to make sure that the child lock indicator light has turned off. If this light is no longer on, this means you were successful at turning off the child lock. If the light is still on, repeat the process, but try to press and hold the "Energy Saver/Dry" button for a few seconds longer. If it still doesn't work, there may be a more complicated issue with your dishwasher. Consult your manual, or call to the manufacturer or repair man to determine if there is another problem with your dishwasher.
Posted on Oct 29, 2009
Can i disable the bottom drawer on a Fisher and Paykel dishwasher and only use the top drawer
You cannot disable, as in turn off, permanently, but you can turn off with the power (left most) button and then lock the control (right most button) by pressing and holding it for approx. 3-5 seconds. The lock symbol will illuminate. Now the lower drawer cannot be operated - unless the lock is released. You cannot disconnect the lower drawer as this will cause a U4 or similar error and both drawers will shut off.
Oct 03, 2016 | Fisher and Paykel 24 in. DD603H W Built-in...
My top drawer of kitchenaid dishwasher lock light is on. I can't get it off?
It's a child lock. To turn off the child lock on a Kitchen Aid dishwasher, locate the Energy Saver/Dry button. Press and hold this button for at least four seconds.
Jun 20, 2016 | KitchenAid Dishwashers
Fisher Paykel D603 f1 code top drawer only, bottom one has no power and locked
Check out www.ApplianceRepairLesson.com. I hope this is what you needed, and it works for you. Good luck!
Nov 07, 2014 | Dishwashers
Top drawer can not be open
If this is a double drawer dishwasher and bottom drawing is functional but top drawer won't open means the controller on top drawer is faulty or power circuit is locked. If turning the mains power off and back on makes no difference then controller could be the problem. One way to test is to take the controller from bottom drawer and replace that in the top drawer. This requires a lot of patience and experience with electronic stuff. If you are not brave enough to test then call the technician. The controller is about $200 to buy. Make sure the mains power socket is taken out before working on the dishwasher internals.
FISHER PAYKEL DISHWASHER DD603 Parts
Feb 10, 2014 | Fisher and Paykel Dishwashers
Dishwasher won't open top drawer or turn on--
Wonder if you tried to turn the power off at the mains and back on. If that does not release the drawer then most likely the lid seal has locked up.
I am assuming the bottom drawer is operational.
Turn the power to dishwasher off and take the bottom drawer out from its housing carefully without tugging the hoses etc at the back. This will expose the power module at the base. This supplies the power to the lid seal actuator motors on both drawers. Disconnect the leads going to top drawer and turn power back on. This should free up the lid seal - might need a little pull to get drawer to open. Connect everything back in (disconnect power first) and see if it works.
If this is unlclear then drop a comment otherwise rate the solution to help fixya help you better in future.
Oct 24, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
Top drawer would not open. I got it open unplugged unit and now it opens and closes fine but the lock indicator is on and the drawer will not turn on. When i press the Lock button nothing happens.
The child lock has engaged. Press the lock button for 4-5 secs and hopefully it should disengage.
Please post a comment to say if this helped.
It would also be helpful to know under what conditions the drawer lid locked up in the first place.
Sep 16, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
F1 fault
Hi . F1 means your machine has triggered the flood alarm. either you have a leak on one of your drawers or water or soap suds has escaped throe the overflow. now the 1st thing to do is turn your machine off at the wall. then leave it for a couple of days to let it dry out. then turn it on and try the lower drawer throe a cycle,if it doesn't go to F1 then try the top drawer. if it doesn't go to F1 then it might be fixed.if it does go to F1 on any drawer then please reply and tell me which drawer it is and i can help you further.
Jun 03, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Oct 28, 2009 | KitchenAid Dishwashers
Fisher & Pykal Dual Drawer Dishwasher. Suspect after young child played with control buttoms on top drawer the power won't come on. Bottom Drawer works perfectly. Have tried turning unit off at power...
Press and hold the key or lock button for 5 sec or till you here a beep to unlock. Or till the light goes out above the lock button. You can get your manual here just find your dishwasher.
http://www.fisherpaykel.com/dishwashing/
Good luck and please rate
Sep 16, 2009 | Fisher Dishwashers
Bottom drawer locked (stuck) open
fisher and paykel sent me a solution - turn off at wall and unplug then turn back on. The dishwasher reset itself and the drawer unlocked.
Nov 24, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
KitchenAid KUDD01DSSS Built-in Dishwasher Logo
121 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
