Question about Electrical Supplies
Ryobi weed eater 30cc
Put in 4 cyl. oil mix instead of my 2 cyl. accidently , it starts but shuts off in a few seconds , i also notice the spinner gets stuck too it rolls and then stops. I ran it for a while it was fine , then i notice it was not giving enough power the spinner , so i stop to check and clean the excess grass around the spinner , started up again and it would 'nt stay on . thats when i also notice i put in the wrong oil mix . What can i do to fix the problem ,help please . Any advice would be helpful , thanks rich ..
  • richard rivera Aug 05, 2008
    please help , i would really appreciate it thanks , grass looks funny looking the way it is , anything would help thanks again ..
Drain all the gas/oil mix out of the system. Press the red prime bulb several times until there is no fluid in the line. Pull the spark plug and clean it with a soft dry rag. Reassemble and fill tank with 2 cyl/gas mix. Prime it, then pull several times on the start cord. That should work.
Posted on Aug 07, 2008
I have a Ryobi 4-cycle S430 weedeater. Do you use regular gas? If so,what type of oil do you use?
A 4-cycle engine requires regular gasoline whereas a 2-cycle engine requires oil to be mixed with the gas.
A 4-cycle engine requires regular gas in the gas tank and engine oil in another tank. Your owners manual will tell you what grade of oil to pour into the oil tank compartment of the weed-eater.
A 2-cycle engine requires regular gas plus a certain amount of 2-in-1 oil mixed with it. The oil that is mixed into the gas container and shaken together to "mix" the gas and oil before pouring into the gas/oil tank helps to lubricate the moving parts of the engine like the piston movement between the piston and the pistons' wall known as the cylinder wall. Also the oil aids in the creation of a tight seal which causes compression to occur that is responsible for optimum operation of the engine itself. It also provides lubrication to the piston rings and reduces friction as the piston rings push against the cylinder wall.
4-cycle engine oil can be purchased at any oil store like Canadian Tire/Sears/Napa Auto Parts. Just ask for oil for your weed-eater and let them know that your engine requires 4-cycle engine oil. I am sure the service clerk will point you in the right direction.
I hope this helps!Have a great day!
Apr 01, 2017 | Ryobi Garden
Fuel mixture ratio for Ryobi SS300 weed eater
Are you sure about the model number? I see several 30CC engine string trimmers by Ryobi. Two are the Ryobi RY30040B (SS30) and a RY30544 (SS30).
For both of these models, mix a high quality 2-cycle engine oil at 2.6 oz. per gallon of gasoline to pour into the gas tank. This ratio is used in several other Ryobi string trimmer models. Many Ryobi product manuals are available here: https://www.ryobitools.com/power-tools/support/manuals . Most Ryobi gas powered and 40V battery-powered tools will have a model number that starts with RY. The 18 V battery powered models often start with a P.
I hope this helps. If you add a comment with the actual model number, I may be able to provide more information.
May 20, 2016 | Ryobi Garden
I have just bought a Ryobi Expand-it 30cc multi tool 4 stroke. Using it for the first time I filled the oil as instructed, put the petrol in as instructed and then started the machine after 2-3 minutes I...
This may sound like a dumb question, but did you mix the fuel and put it in the machine? If so, you shouldn't have. 4 strokes don't take mixed fuel. You must put the SAE 30 Oil (Not 2 cycle Oil) in a different chamber. Let me know, PLEASE!
Jim
Aug 15, 2011 | Ryobi 30cc 17" String Trimmer Zrry30530...
What kind of oil do i use to mix with gas for my Poulan gas trimmer. Can i use WD30 motor oil or does it have to specifically say its for 2stroke engines? the ratio on the trimmer says 40:1 so i assume...
DO NOT USE MOTOR OIL!!!
There is a special 2-stroke engine oil mix that you can purchase at various stores that have outdoor equipment or you can also find mix at Walmart. There are instructions for proper mixing on the bottle.
Remember not to put 2-stroke mixed fuel in your lawn mower unless it is also 2-stroke (rare). And the converse is also true, do not put your 4-stroke lawn mower fuel in your 2-stroke weed eater.
If this is really helpful, please rate.
Jul 10, 2011 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
I am looking for a Ryobi weed eater manual. Need to know how much oil to put in my weed eater. Can you give me an answer or where I can get a free manual. Thanks
You did not list which model Ryobi you have, however...
If your Ryobi has a silver or black shaft, then it is an older model and requires a 32:1 fuel mix. In the USA, that is 4 ounces of 2 cycle mix per gallon of gasoline. If your Ryobi has a yellow shaft, then it was made by HCP and uses a 50:1 mix or 2.6 ounces of 2 cycle mix per gallon.
Sep 23, 2010 | Garden
My TP30 Ryobi weed eater turns and stays on while
You have a hairline leak in one of your hoses or a small gasket under primer bulb.
Jul 05, 2010 | Ryobi Factory-Reconditioned 30cc 18" Gas...
I guess he needs to know what kind of oil he needs also
you shouldn't need to mix oil with gas on a four cycle engine. this is for two strokes.
Aug 23, 2009 | Garden
Need to know how much oil to mix with gas for a 4 cycle ryobi weed eater
You only need to mix oil with gas when it is a 2 cycle engine. 4 cycle engines run on straight gas. Since you didn't post your model number, here is a site you can hopefully find your owners manual at. Hope this helps.
http://odref.com/pdf/Ryobi/
Aug 23, 2009 | Ryobi Garden
Do you use mixed gas for a ryobi weed eater??
Unless it has a tag or decal on it saying it is a 4 cycle then it uses mixed gas/oil at about a 50:1 ratio. Straight gasoline will freeze the piston in the cylinder in mere minutes.
May 23, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Electrical Supplies Logo
510 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
