Question about Samsung Washing Machines
My samsung diamond drum model no. WA90V3 7.0 kg washing machine is now currently not working but still with power when you put it on. The control for washer, spin, and dry is not working anymore, Pls. assist us and advise as to where is the nearest service center that we can call for home service. Our location is in Makati City, Philippines
2 Suggested Answers
  • 489 Answers
SOURCE: Sir, I would like to
It should be fine but I'm not sure how it will work with the 220v. Be sure that the power there is 110v red to white and 110v black to white. If the power is not, it probably won't work. Good luck
Posted on Jun 18, 2011
Please how do I resolve error code UC on my Samsung diamond drum washing machine?
Washing machines have computers. They are literally designed for no ''DIY.'' Error code would likely mean ''new computer needed.'' Either way, you need a laptop with a factory testing program installed in it That's how these guys work nowadays. The laptop tells them what to do next, and you (and I) can't have one.
Aug 15, 2015 | Samsung Washing Machines
Got a Samsung Diamond Drum WA80V3 after I put in on quick was and start it goes 22 minutes and when at 15 it goes toe rinse but then the machine just stop doing anything. Water still inside drum. Maks n...
The drain pump is either blocked or failed. Check the filter if it's clear then you are most likely up for a new drain pump. Here is a link to the part you need and a video on how to do it. Samsung DC31 00030E DRAIN PUMP B20 3 120V 60 NEW ORIGINAL
Mar 15, 2015 | Samsung Washing Machines
How do i make my samsung diamond washer model WF8500NHW use more water in the drum when washing a load
The amount of water in a washing machine is measured to be the optimal amount. If the clothes do not clean, perhaps you should reexamine the powder.
Feb 14, 2015 | Samsung Washing Machines
My samsung washing machine 8.0 kg diamond drum model WA104F does not function and no water comes out from the source but power supply is ok
Turn off the water going to the washing machine, and disconnect the hoses at the machine (put a pail under each hose to catch drips or leaks from the shutoff valves). Inspect the strainers at the hose connectors on the machine - they may be clogged with lime or sediment. If so, use a wet-or-dry vacuum cleaner (e. g., ShopVac) to clean the strainers, or if they are easily removed, you can back-flush them under a faucet.
Even if one valve is plugged, the machine may shut down until the problem is corrected. Some models flash an error code indicating a water supply problem - see your owner's manual.
Dec 02, 2013 | Washing Machines
8.0 kg wa10f4 samsung diamond drum
I NEED TO KNOW WHAT SHOULD I DO WITH MY SAMSUNG 8.0KG WA10F4 DIAMOND DRUM IF THE WATER FROM THE TUB IS NOT DRAINING..AS IF THERE'S SOMETHING STOPING THE WATER TO FLOW
Jun 02, 2012 | Samsung Washing Machines
Sir, I would like to ask if this samsung washing machine model Diamond Drum WA80V3 220V - 50Hz - 330W can be use in Cebu City, Philippines where the electricity power cycle running is 60Hz?
Jun 17, 2011 | Samsung Washing Machines
My Samsung Washing Machine (Diamond Drum model) problem
You probably did not save the mode you want. See the information booklet provided on how to set the mode.
May 25, 2010 | Samsung Washing Machines
Washing Machines Logo
363 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
