Hello i have a Sansui G9700 reciever It seams that every thing is fine however no sound comes out of either speaker ,any ideas what to replace or where I can trust to send it. thanks Bob 7155736143.
  • barnetzke Apr 10, 2011
    All fuses were not blown. I could not trace back from the fuses to the transistors so we checked the ohms from the top side of each fuse to each speaker terminal. The left channel measured around 50 to the positive of both left speaker terminals and the right channel only measured to 20 at most. What is a high and low rating for the ohms for these? And do I measure the ohms to both the positive and negative speaker terminal? Also, do you know which fuse goes to the transistors? The safely operate light is still on when turning on the reciever, is there a type of reset for this? Or is it possible that with the right side being a lower ohm, it is making the reciever go to safely operate? Thanks Bob
    We have a Sansui g9700 reciever that turns on however the green "safely operate" light is lit when the reciever is turned on. We have checked all of the fuses and ohmed each fuse to each speaker terminal (we could not trace an individual fuse to the speaker terminals, so we tested all of them) the left channel ohms out at around 50 and the right around 20. We're not sure which wire comes from the fuses the speaker terminals, which is why we tested all fuses. All lights come on and reciever seems to be functioning fine, but with no sound coming out. Thank You.
    President:
  • 1,961 Answers
Posted on Apr 10, 2011
  • Danilo Baraquiel
    Danilo Baraquiel Apr 10, 2011
    recievers have a fail safe operation system it activates whenever an error in the circuit occurred to prevent fire and further damage..In your reciever first thing to check is the output transistor/IC.You can replace them immediately.then you also check for any relay switch output to the speakers.This relay switch holds down when it detects any shorted in the system like a shorted speaker,shorted diode,transistor etc.you can test the speaker with a multimeter if the coils are shorted.speaker resistance reading is from 4-8 ohms beyond this reading speaker is defective.perform first this steps and lets see whats next just post back...please also state your actual address so I can provide you a service center near to you...Thank You!
  • 1,606 Answers
The speaker protection relays may not be turning on or a power amplifier fuse may be blown. The most common cause for this is a shorted transistor in one channel. Look inside for fuses and check them with an ohmmeter. If one is blown, trace the circuitry from the fuse clips to the power transistors mounted on the back. When you identify which fuse terminal goes to the transistors, measure the resistance from this fuse clip to each speaker terminal. It should be a very high value or open. If it reads a low value (generally a fraction of an ohm), one or more of the transistors in that channel is bad. In that case, you should also check from the other fuse to the speaker terminals to make sure the complementary side transistors for that channel are still good. DO NOT replace the fuse until you are sure there are no shorted transistors. The preceding tests are done with the receiver unplugged.
Likewise, if the amplifier remains in standby mode when you turn it on but the fuses are good, it may have an offset detection circuit that locks out the speaker relays if an output transistor is shorted.
The next possibility is the audio source switch has a problem, but it seems unlikely that would knock out both channels on all sources.
Posted on Apr 04, 2011
Sansui G-5700 protection light wont go on
Try checking the speakers and connections. Those symptoms occur if there is a short. Disconnect all spkrs, turn it on and if it stays on connect one speaker at a time until it shuts off.
Jan 19, 2013 | Sansui G-5700 Tuner/receiver
I have a sansui G9700 receiver/amp. The volume control works intermitantly. Must play with it to get volume. I believe I need to replace the potentiometer F3085. where can I get one? Erick G
The potentiometer doesn't need to be replace, it has collected dust inside causing the intermittent operation. Buy a contact cleaner/conditioner to spray inside it and move the potentiometer clockwise and counter clockwise a few times until the dust inside it is gone.
Check this link to find a contact/conditioner cleaner or you can try spraying rubbing alcohol but this could because alcohol doesn't not lubricants properties.
Let me know if you require further assistance.
Nov 27, 2010 | Sansui Audio Players & Recorders
I have a Sanyo DCTS760 surround system. A couple of weeks ago i got a loud static noise coming from the front left speaker. I tapped gently but forcefully on the top of the reciever cabinet and this ,...
if the left front channel is not working, first test the speaker with the right channel that is working to make sure the speaker is still good.
If the speaker is good, then it means the fuse of the left channel has burnt. Open the receiver and check the left channel fuse.
Good luck.
Jul 21, 2010 | Sanyo Televison & Video
Right front channel not working
try to check balance adjustment if working.
Apr 16, 2010 | Sony STR-DE475 Receiver
Distorted, cracked sound coming through to the speakers
is it possible your new reciever has a built in phono pre-amp?
If so, you need to switch off the pre-amp inside the turntable (lift up the rubber matt, and rotate the plate untill you see the switch at the back)
Try again now?
Feb 12, 2010 | Aiwa PX-E860 Turntable
Have new LG 42" LCD and no sound on the 5.1 Surround Sound
Try running a set of audio cables(Red/white) from your audio out jacks on the back of your TV to your reciever's audio in?
Feb 01, 2009 | LG 42LC2D 42 in. LCD HDTV
No Sound when I play DVD's
The optical connection on the TV is most likely an input, not an output. You need to connect the Xbox to the receiver, then the TV. If the receiver does not have a HDMI input, use another audio or digital out from the Xbox to the receiver.
Sep 19, 2007 | Yamaha HTR-5940 Receiver
Denon 2902 No Sound
REPLACE MUTING TRANSISTORS IN DSP PANEL
Sep 04, 2007 | Denon AVR-2802
Denon reciever avr-487
If your tv is putting out mono you will only get the center and sub speakers. This can be because the tv is only mono, or the output is set to mono in a menu of the tv. If you have cable or sat run the digital audio out to you receiver; it usually sound better that way anyhow. Set your receiver to Dolby mode for best sound.
Aug 27, 2007 | Denon AVR-4800 Receiver
297 people viewed this question
 Grubhead
Grubhead
