Question about Garden
The piston on my tanaka string trimmer has an arrow embossed on top of it. Which direction does the arrow point?
3 Suggested Answers
slohry
  • 87 Answers
SOURCE: Homelite Mightylite String Trimmer Piston removal
Homelite shows the short block assy ($84.02) but no breakdown of the top end. I've never taken one apart, not cost effective. Here's the link to their parts site. Have the UT number available
http://www.homelite.com/service_support/order_parts
Posted on Apr 12, 2009
  • 246 Answers
SOURCE: Need to find Tanaka tbc Grass Trimmer,carburettor service manual
Hello
If the Carburetor OEM is a Zama, then
>>You can View a Breakdown/IPL of the Carburetor and Get Technical Information on Zama Carburetors at this Site Addy; http://www.zamacarb.com/tips.html and Select the Technical Guide.
If the Carburetor OEM is Walbro, then
>>You can View a Breakdown/IPL of the Carburetor at this Site Addy, http://69.16.165.8/ and Select Service & Aftermarket. Now Select Aftermarket Parts and Service. Now Select the OEM (Tanaka). Now Select Trimmer. Now Select your Carburetor (?) from the List Provided.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
How do I restring a Tanaka TBC 4000 string trimmer?
Hi Gilbert,
Here's a link to your manual. Just download it and it should give you directions on how to restring:
http://www.manualslib.com/manual/976965/Tanaka-Tbc-4000.html
Good Luck!
Jim
May 28, 2016 | Garden
How to restring drum on Echo 210 gas trimmer
Pull the head off by turning the inner hub counter clockwise while holding the outer head still. Once the inner head pops out, turn it over and look for the string rotation arrow. If you can't find the string winding directional arrow, start the trimmer and determine shaft rotation direction (generally counter clockwise) and wind the string in the same direction as the head rotates when installed.
Pull about 5 arm lengths of string out of a string spool and cut it off. Place the inner trimmer head on an object that will hold it while you pull the string to even lengths through the winding hole (the support brackets of a pickup truck tail gate work well for holding the inner head while doing this).
Begin wrapping the string double wraps in the proper direction, laying them evenly and closely to the previous wrap, working it back and forth as the string begins to build up. Avoid crossing the string over itself more than necessary, the string can weld itself together if the strands cross to awkwardly. Once the string is wound, hold the head with one hand and slide the string through the outer head holes, avoid letting the string come unwrapped.
Carefully place the inner head down into the outer header. Avoid letting the string get caught between the inner and outer head. Once the heads are together lock the inner head onto the outer head by turning it and locking the round knobs into the outer head slots.
You can trim the string or let the trimmer guard do it. If the string doesn't feed it is either wound the wrong way, tangled between the inner/outer head or welded to itself.
Aug 19, 2014 | Echo Garden
Replace trimmer head
Most trimmer heads unscrew clockwise. Watch the video which shows how to remove most trimmer heads.
How to Replace Trimmer Head
May 30, 2014 | Tanaka Trimmers Tbc-230sf String Line...
Stihl Repair Manual
arrow points towards exhaust, direction of gasses http://www.mediafire.com/download/56zr9s967sf9a98
Oct 22, 2013 | Stihl Garden
Craftsman model 138.74503 12 inch string trimmer
Loading the line is confusing because there is no arrow on the spool (despite what is written in the directions) but there is an arrow on the cap that points counterclockwise. However, disregard the arrow on the cap. As written in bold letters on Figure 15 in the manual, both lines are wound CLOCKWISE as seen looking down on the top of the spool. This works.
Jul 18, 2012 | Craftsman Garden
Homelite trimmer, gas, string - y is the string wrapping itself around the head of the trimmer?
The line on my new 26cc Homelite would also feed out by itself. That started me thinking the line was wound backwards. I wrapped the line in the opposite direction as was shown on the bump feed reel and now the dang thing works although the bump feed needs to be "bumped" pretty hard to work. Is it possible that the reel was manufactured with the (string direction) arrows pointing the wrong direction? The new 26cc unit is also underpowered compared to my older 25cc trimmer.
Jul 20, 2010 | Homelite Factory Reconditioned 26cc...
The moter starts and the line wraps around the head before I can start trim.
Did you wind the string backwards? Check the head it should show which way the string shold be wound.
Jul 02, 2010 | Tanaka Commercial Grade "Inspire" Design...
How do I replace the string correctly on the weed trimmer?
If it is like most trimmers, there is an arrow on one end or the other. The arrow shows you the direction to wind the string. There should also be a size shown. It will be in a decimal:.065, .080, .095...etc. That is the diameter of the string. Good luck...Lee
Nov 09, 2009 | Husqvarna 28cc Gas Line Trimmer
I need information on how to re thread a homelite string trimmer 155 i have not got a manual can you help
When you pull off the spool, look at the end of it. You will see an arrow pointing in the direction you wind the string. If you have two strings, they both wind in the same direction. Look on the body of the spool between the edges, on the barrel. You will see a hole or holes to start the string in. Good luck...Lee
Oct 20, 2009 | Garden
No directions on how to re-string the spool on my TB-720
On the bump mechanism, line up the two arrows, then unscrew the bump, this will release the spool, then you wind the two strings in the opposite directions, the arrow on the spool will tell you the direction to wind the string, replace spool, spring, bump feed, and you are good to go. I hope this has helped you.
Jul 06, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
