Question about Peavey Escort 3000 300 Watt Portable PA Speaker System
I can only get sound out of 1 speaker - Peavey Escort 3000 300 Watt Portable PA Speaker System
  • 1,606 Answers
This can be speakers, cables, connectors or the finals in your amp. First is just switch the speakers. That rules out the speaker etc. Just swap the leads from right to left etc. So the working setup is on the suspect bad output. If it works then the problem is something towards the speaker. If not its the amp. You can then try switching just cables to rule those out. Should take just a few minutes to figure out what the problem is. If it is the amp end check for dumb stuff like switches or the volume ;-] If not its a trip to your repair shop. Cables and contacts can be easily damaged and are the first suspect. Speakers are usually bullet proof unless you do everything maxed out. Amps will have issues due to age or heating etc. Just make sure to check out the amp value before telling anyone to fix it. You don;t want a big repair bill to fix a inexpensive amp, just replace it.
Posted on Apr 04, 2011
I was just given a Kustom Sienna 65 Amp and it powers up but no sound coming out of speaker. I plugged a line from the ext speaker 1/4" out into a practice amp and got sound through the practice amp.
You may have a blown voice coil in the speaker. Can you see the back of the speaker? Then, First Check the connections to the speaker and make sure they are well connected. If they are, then the speaker is probably at fault. If you are handy, then you can get a replacement speaker, 12 inch?, and swap it out.
Jan 08, 2018 | Kustom Music
The Clip LED on Channel 1 of my SA220 is on continuously even with nothing plugged in the XLR or 1/4 inch inputs. Not getting amplification when inputs are used. Why?
That light is showing that there is power to amp in that speaker but there is something wrong with the amp or the speaker inside and nothing is coming out. You will have to troubleshoot the amp and check the resistance of the speaker to see what the problem is.
Nov 12, 2014 | Fishman SA220 Solo Performance System...
My Peavey Bandit 112 is only working with an
It could be the wire[s] to the internal speaker or a dirty contact on the 1/4 inch female speaker output jack. Try pushing a 1/4 inch male plug in and out of the jack a few times. Or, you'll need to remove the chassis to look inside. My email address is computerlen@hotmail.com if you have any further questions.
Oct 17, 2014 | Music
No sound coming out for my hartke amps?
Are the internal speakers properly connected via the rear-mounted 1/4 inch "Speaker Output" jack? If so and still no sound, try connecting a separate external speaker (floor monitor, pa cabinet) for a "low volume" test.
The OM says the internal speakers are 4 ohm so it's unlikely that a wiring problem with speaker connections would cause all four to stop working. With AC power disconnected from outlet check for an internal speaker protection fuse BUT be careful. Charged capacitors can hold a charge for weeks!!!
Oct 25, 2012 | Hartke VX3500 Bass Guitar Combo Amplifier
I dont know how to set up a mixer Gemini 3610 to my laptop and my powered speaker i want to know what cables i need
There are several possible solutions for this. The cheapest and easiest is to do the following:
Solution 1:
1. Get an RCA stereo plug to 3.5 mm plug. This will go from your mixer to your computer. This will not be the highest quality, but will work.
2. Get an XLR cable of the length you need. I would guess a standard one with a male connection on one end and a female on the other. Connect this to your powered speaker. Also, this is a guess as you didn't include the type of powered speaker, so I can't tell you for sure which cable to use.
Solution 2:
1. An alternate idea for better sound quality would be to run a D/A converter similar to this one: http://www.sweetwater.com/store/detail/USBMix/It would give you a much higher sound quality for everything. You would run from your Gemini to this. From this device, you would run a USB cable to your computer, and a 1/4" cable to your powered speaker.
Jul 19, 2012 | Gemini Sound Products Gemini Cdm-3610 Mp3/...
Just bought a Harbinger HX121M 2" Monitor, from Musicians Friend it did not come with a booklet on how to wire into my sound system it has two 1/4" jacks and a strange round plug about the size...
If you don't know how to connect this... well we don't either because you did not tell us what your sound system is. The larger plug is what is known as a "Speakon" connector and is a fairly reliable speaker connection that is used now. For your use you will PROBABLY use either of the 1/4 inch jacks with a cable from the amp that will drive the monitor(s). If you have multiple monitors you will daisy chain them using the 1/4 inch jacks and SPEAKER rated cables creating a string of speakers with input going into one and an output from the same one to the next speaker and so on...USUALLY you will be limited to two speakers per amp output...
Aug 15, 2011 | Harbinger HX121M 12" Stage Monitor
I have been using two Peavey Pro 15 Mk ii 300 Watt Passive 15" Speakers with two additional speakers on the output side and i notice one of the peavey speakes wasnt working! i then realised i had the...
Passive speakers with 1/4 inch jacks do not define either as input as they are wired in parallel...
Assuming the speakers you added were each no less than 8 ohms this should NOT have overloaded your amp.If you have no sound you have probably blown your amp some way.
Note some amps can be blown if they are on and EITHER side of the speaker cable touches a ground. If the amp is running and a 1/4 inch plug is pulled, it shorts and can blow the amp.
Jan 17, 2011 | Peavey PR15 400w PA Speakers
I have a Roland FP 1 digital piano, serial #AL21141N. It has gradually quit putting out sound through the speakers. At the onset of the problem, I could fit it by jiggling the 1/4" speaker plugs,...
I first would suspect the switches on the eadphone jack. Normally these cut off the speakers when headphones are plugged in. These jacks and the switches are really weak, poorly made, and easily broken, especially if headphone cord gets yanked.
Jan 14, 2011 | Roland Digital Piano FP4 Black With Stand...
Hi, I would to say thanks a lots to let put some words on yours email box. It's just regarding about how to set up a live band gigs @ outdoor stage in to mixer system. In a mixer setting, i wana know how...
You will need at least a 24 channel mixer to give you spare channels. You also need an active crossover and a snake. The advice you need is too much to include here so I am including some links:http://mixonline.com/live/FixIts/, http://en.wikipedia.org/wiki/Live_sound_mixing, http://mixinglivesound.com/blog/tag/outdoor-concerts/,http://mixinglivesound.com/blog/, and http://www.scribd.com/doc/11435651/Beginners-Guide-to-Mixing-Sound. You may need more monitors than you are planning on and you might consider in ear monitoring.
Aug 22, 2010 | Music
No sound
1. plug in some headphones into the jack.
2. connect to an amplifier or external source.
3. connect midi to a midi-compatible device and determine if device receives signal by pressing keys
If #1 or #2 passes, your speakers are bad.
If #1 & #2 fail, but #3 passes, your setting are set so that there is no sound, but the keybourd still recognizes input.
If all three fail, the keys do not send a signal at all, you should replace the keyboard.
Dec 19, 2008 | Korg Pa800 Synthesizer
Peavey Escort 3000 300 Watt Portable PA Speaker System Logo
75 people viewed this question
Top Peavey Music Experts
Michial Gueffroy
Ben Armstrong
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
Are you a Peavey Music Expert? Answer questions, earn points and help others
