Question about Dometic NDR 1062 Refrigerator
Work on gas but not on electric. - Dometic NDR 1062 Refrigerator
  • 132 Answers
This is an absorbtion type of refrigerator and it relies on heat to produce a secondary cooling cycle.
The electric heater element has probably open circuited or rust has formed an insulating barrier around the heater prevrnting heat transfer. It is best to get a technician to check it for you
Posted on Apr 04, 2011
Why doesn't my dometic refrigerator work on gas, but works with electric?
if works with gas but not electric bad heater element if doesn't work on gas but ok on electric clean out LP burner
Feb 24, 2016 | Dometic Refrigerators
I have a gas dryer is it also electric dryer also
Up to my knowledge, GAS dryers work with gas
Sep 11, 2015 | Dryers
I have a DLG6988S LG dryer. It can work but didn't heat up. Can it work in only electrical environment?
a gas dryer needs a gas hook up to work. based on your model number, you have a gas dryer. the electrical plug is only for the motor and electronics, not for heating. sorry
Mar 01, 2015 | LG Dryers
Suburban sw12 water heater will not work on gas or electric
Both gas and electric wtr htrs require electricity to work. Check your breaker or fuses to see if that may be the issue.
Sep 19, 2014 | Suburban Gas and Electric Water Heater, 12...
Our Dometic RM2193 cools on gas but does not work on electric
It could be as simple as a blown fuse at the fridge. Also check to make sure you have turned on the electric switch that allows the fridge to run on AC. Note, you can only operate the fridge on EITHER gas OR electric, but not both sources at the same time, thus, you have to turn off the gas switch before you can run on electric.
When this unit is running on electricity, it has to have the thermostat set for it to run.
Here's a link to the Dometic manual for your model.
http://www.alcovr.com/DATA/MANUEL/DometicRefrigeratorModelsRM2191&RM2193.pdf
Just follow the steps for running on electric and you should be OK.
Hope this helps.
Jul 30, 2009 | Dometic RM2193 Compact Refrigerator With...
Admiral gas stove model 68-253440. All electrical will not work.
all is off, power supply is good, pop the top lil lid (normaly very top) and look for fuses
Jul 24, 2009 | Kitchen Ranges
Oven won't work on gas with electric ignition stove
The glow bar for the bake burner is bad, needs to be replaced. Remove oven bottom to get to it, and also the utility drawer.
Feb 17, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Electric or Gas?
Pressure washers are either electric or gasoline powered. Electric pressure washers are low maintenance and quiet. These generally are for light duty. They are handy where you need to work on small confined area, however you need to run power to them and have a pressurized water source. Also the National Electrical Code and Underwriters Laboratories now require ground fault circuit interrupters (GFCIs) be use when operating an electric pressure washer. Gas models are recommended for tasks that require more power, such as paint prep, heavy vehicle cleaning, or cleaning heavily soiled concrete.. Gas models start with PSI of 1750 and go as high as 4000. They also offer more portability, as they are not limited by electric cords. Also some gas models can draw water from a source other than the garden hose, which allows you to work away from a water line. All gas models have 4-cycle engines and run on regular unleaded gas.
Aug 27, 2008 | Briggs & Stratton Power Products 1539...
Will my gas boat fridge work with out power
Power to drive a gas refrigerator comes from one of two places. Electrical or LP gas. That is if your system is dual powered. It must be shifted over to gas if the electrical is turned off or disconnected.
A separate thermostat controls the gas end and an electric thermostat controls the electrical end. You must manually change the operating mode from one to the other. When in the gas mode no electrical power is necessary.
Apr 29, 2008 | Refrigerators
Dometic NDR 1062 Refrigerator Logo
166 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
