Question about Briggs & Stratton Briggs Stratton Lawnmower Lawn Mower Short Block
Stanly Riding Mower model 525607X692 with 22 hp Briggs & Stratton eng. eng will only running on the left carb, have adjusted valves, compression is good, spark is good, have swapped coils, either in carb throat does not change anything, intake manifold has been removed to check for blockage---????? any hints or clues. thanks Dean
  • 18 Answers
SOURCE: wanted briggs and stratton 92908 manual
Find the B&S website and you should be able to download a parts or service manual.
Think it is briggsandstratton.com.
You will also need your type number (after the 92908).
Posted on Apr 18, 2010
  • 225 Answers
SOURCE: I have a 20 Hp briggs & stratton motor it will
have you checked the oil ?some units have an oil sesor,that if oil level is to low shuts the unit down to stop damage to unit.
Posted on Jun 21, 2009
  • 225 Answers
SOURCE: Engine starts but won't stay running
an easy way to know that is to start engine and give it a shot of starting fluid ,if you can keep it running by this method I would replace diaphragm.
  • 583 Answers
SOURCE: briggs and stratton miss fires on one cylinder.22hp intek
possibly a commpression test might throw a little more light on the situation ,that will eliminate alot of speculation, and make it easier
Posted on Oct 25, 2009
  • 583 Answers
SOURCE: Briggs & Stratton Briggs Stratton Intek V -
these are common for doing this ,if you dont want to pull it down and hone the cyl. then i would use a heavier oil say 20w/50and that will probabley solve your problem
Why would i have oil/gas combo coming out of the valve cover on my 17.5 hp briggs/stratton riding mower. what should i look for?
check for gas in oil remove dip stick if does replace needle and seat in carb put in new oil replace fiter if have one try this ,let me no what happend
Sep 03, 2014 | Garden
I have oil/gas combo coming out of the valve cover on my 17.5 hp briggs/stratton riding mower. what should i look for?
check for gas in yuor oil if does replace needle and seat in carb then chang oil filter if it has one make sure to clean bowl well on carb let me know what happen
20.0 HP 502CC B&S engine, riding mower - stopped going full speed, black smoke from muffler, "misses" ALOT - model number looks like a backwards E followed by 1P977
Carb flooded or extremely out of adjustment and or completely malfunctioning.
Disassemble carb and inspect Float and needle valve.
Hope this provided some ideas for your repair.
r/
David
Jan 13, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Walbro Carburetor on Briggs & Stratton Model 28R707
If the float don't float, the needle valve stays open and gas runs into crankcase.
If float floats (has no gas inside) then the needlel is probably worn and needs replacement.
Sep 06, 2009 | Garden
Murray riding mower 12.5 hp briggs & stratton spitting oil & gas out of carb & muffler when trying to start
Drain oil... it is full of gasoline due to a bad float pin and rubber gromet in your carb. When your float pin and gromet fail, gas just keeps flowing into your carburetor, eventually flooding your motor with gas and oil mix.
Jul 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Gas coming out of exhaust is it the carburetor and why
carb. float stuck open
Need to remove carb. replace float needle valve and possibly the needle valve seat,
change your oil also
saturated with fuel
May 23, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Briggs & Stratton Briggs  Stratton Lawnmower Lawn Mower Short Block Logo
242 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
