Question about AudioBahn A1300HCT Car Audio Amplifier
I have a Audiobahn amp A1300 HCT.A while back i took off the plate where battery,ground&remote go.inside of amp their is a blue wire that looks like a ground wire maybe, didnt know where it belong when i took the plate off...not sure why I don't have power?
I have a audiobahn a4002t. it will not power off when the key is off and removed. i have even tried disconnecting the remote wire and this does not help. i have tested the radio for functionality of the...
More than likely the amps internal relay that is powered by the remote lead has shorted open, allowing the amp to connect power and ground regardless of the remote signal.
Should be a relatively inexpensive fix at an electronics repair shop.
Jan 03, 2011 | AudioBahn A4002T Car Audio Amplifier
A2300HCT Car Audio Amplifier: i have a audiobahn a 2300 hct amp and it has stopp...
Well, sounds like you have an internal damage since it smokes, if it smokes as soon as it kicks on, and blowing the fuse right away, I would have it fixed. But my guess would be something with the ground that is making this happen, or some how your power is grounding on the amp. When ever smoke comes into play, thats never good any way at this point you gotta admitt that thiers internal damage.. blowing fuses can also be cause by over working your amp. along with the sub load at 1 ohm make sure your amp can do the same.. hope this was helpful in some way
May 16, 2010 | AudioBahn A2300HCT Car Audio Amplifier
Amp blows main power fuse..
No "fault" lights? If not it HAS to be a connection...whether they look bad or not, Redo them, ground FIRST.
Good Luck
Jun 21, 2009 | AudioBahn A8002T Car Audio Amplifier
Audiobahn 2300hct red led light comes on when engine revs up at idle amp goes blue and works fine. volts are running at 13.5 to 14.0 when reved and 12.4 at idle. what going on? amp worked fine when car was...
this is happening simply because your ground wire is either going bad, or it has a bad connection to your vehicle. check the spot where your ground wire connects to your car, and look for corrosion or a change of color in the wire. if you find anything like this, i would recommend replacing your entire ground wire. if the wire looks fine, just tighten your connection point, or move it all together.
Jun 06, 2009 | AudioBahn A2300HCT Car Audio Amplifier
I need a installation manual for audiobahn a8002t amp.
very simple run a ground from gnd on amp to a good ground spot on car run 12 volt power cable from back of fuse relay by battery to 12v+ on amp then splice blue wire on back of stereo splice in another wire about seven feet run that to remote on amp then hook up speakers its pretty simple to hook up an amp hope this helps
Apr 18, 2009 | AudioBahn A8002T Car Audio Amplifier
I am trying to instail my audiobahn amp and dont know how.
you can go to crutchfield.com and they will show you step by step but all you need is a long enough power wire from your battery but make sure you have a inline fuse about 12" off the battery. run a remote wire off of your head unit to the back of car, make sure you have a good ground bout 3' wire that's about it then run your wires for your speakers
Apr 03, 2009 | AudioBahn A2002T Car Audio Amplifier
Power
BATTERY CABLE TO AMP B+
GROUND CABLE TO AMP GROUND
REMOTE WIRE CABLE FROM AMP CONNECTS TO BLUE REMOTE WIRE ON BACK OF CD DECK.
RCA JACKS GO FROM REAR OUTPUT OF CD DECK TO LOW FREQUENCY ON AMP INPUT.
Check Power cable fuse, check ground is grounded to non painted surface.
This is all you need to get it to work. If you still have a problem, then it is a bad capacitor inside the amp
Jan 30, 2009 | Car Audio & Video
Audiobahn ATB8AT
try radioshack, walmart, or try ebay
Jan 06, 2008 | Audiovox BA200 Car Subwoofer
Audiobahn A1500HCT in Protection Mode
try just hooking up a power wire and ground wire only. disconnect your subs from your amp along with the remote wire and RCA's. if you have some jumper wires or run a wire from the power terminal to the remote wire. YOUR amp should come on, if it still stay's in protection mode it might be shot... hope this was helpful, i couldn get my a2300hcx to come on and tryed this and it came on turns out it was my remote wire was bad of the head unit...
Nov 13, 2006 | AudioBahn A1500HCT Car Audio Amplifier
Audiobahn A2300-HCT
bring it to a hifi or tv repairstore
Nov 04, 2006 | AudioBahn A2300HCT Car Audio Amplifier
AudioBahn A1300HCT Car Audio Amplifier Logo
73 people viewed this question
Top AudioBahn Car Audio & Video Experts
Tygh Duval
Tygh Duval
Colin Stickland
Colin Stickland
Jerry Naidoo
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
