Question about Dryers
Whirlpooldryer LEN2000PW1 when you shut the door turn the dial you hear a clicking sound and doesnt tumble. Belts not broke and you can turn motor manuelly.
    President:
  • 1,554 Answers
This is a symptom of a blown thermal fuse located on the blower housing. It is wired in series with the motor and therefore cuts power to the motor when it blows and results in the motor not running. No dryer function works when the motor is not running. Remove the rear access panel and locate the thermal fuse. Replace it if found blown open including the cycling thermostat. Click on the link below for the detailed troubleshooting procedure.
Troubleshooting Not Starting Whirlpool and Kenmore Dryers
Posted on Apr 04, 2011
The belts are fine but it just doesnt switch on
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=sTRP6kHqAFs
Hey GOD IS GOOD !!!! WHICH IS WHY MY ADVICE IS FREE
What to Test When Whirlpool or Kenmore Dryer Won Start or Run
Nov 05, 2016 | Dryers
Dryer won't tumble.
check the belt............if ok then could be the motor ..........cheers
Apr 15, 2014 | Whirlpool WED9600T / WED9600TA / WED9600TW...
My wife left on my air compressor it is a Ingersoll-rand and now it turns on but doesnt sound like the motor is running but one of the belts in broke any ideas
The motor turns the belt that drives the actual compressor portion of the system. Replace the belt, make sure there is oil in the compressor pistons and try it out.
Nov 21, 2013 | Ingersoll Air Tools & Compressors
My engine doesnt turn over
Before you start pulling the motor down, just check the ignition unit has not come loose and is hitting the flywheel
May 12, 2012 | Garden
When I press the start button, it hums but won't turn on, I hear clicking behind the cycle setting dial?
f you hear the motor humming and not starting at all it most likely has a severe friction problem with the drum or motor. It could possibly have some type of garment jamming the blower wheel preventing the motor from starting too.
Open the dryer door and manually rotate the dryer drum counter clockwise (CCW). It should take very little effort to rotate the drum. If it's hard to rotate that could explain why the motor hums instead of starting up. If it turns freely, shut the door and see if will start. If it still hums and not start it may have bad motor or a low voltage supply to the motor.
Jan 17, 2011 | Maytag Dryers
In my Maytag dryer model SDE305DAYW the heating element works; however, the tumble drum stopped moving. What's wrong?
This sounds like the drum's drive belt broke. But also ensure there isn't a problem with the drive motor. Do you still hear a motor running when you turn it on? If so, you'll need to replace the drive belt.
I hope this helps! :)
Dec 15, 2010 | Maytag HYE3657A Electric Dryer
My whirlpool lgn2000jq2. Had an incident where the drum kept turning after I opened the door. I turned the cycle dial to turn it off. Now the light inside comes on when I open the door, but with thedoor...
Sounds like your door switch is bad. When you open your door the the door switch is supposed to shut off the motor to prevent someone from breaking an arm, by reaching into a rotating drum. First check to make sure that your switch actuator is not jammed or broken. This little arm is usually behind the door at the top of the recessed area. When you close the door it actuates the switch. When you press on the arm you should hear a click. Replace the switch or check the actuator if you don't hear a click. (some switches come with the arm and some are seperate from the actuator arm.) Good luck, Appliance Specialists
Dec 01, 2010 | Dryers
ELECTRIC DRYER WON'T TUMBLE
Possibly the belt assembly. if you open the door and try to turn the drum does it turn with a little resistance, noises? this model has rollers, pulley, and a four groove belt 92 1/4" , sometimes the pulley sticks after yrs of use, belts wear, drum misaligns. the humming should be the motor trying to work.
Feb 03, 2009 | Whirlpool LER7646E Dryer
My hotpoint vtd20 tumble dryer will not start. I was using it then when I put a second load in and pressed start - nothing happened. The power light is on but no tumbling!
If you can hear the motor running but no tumble action then belt has come off.
Make sure the door is shut properly..
If it gets hot at the back, then you are difinately getting power to everything.
If you can hear a slight buzzing noise, then the motor is failing to start, probably due to a faulty start capacitor.
Dec 08, 2008 | Dryers
My Dryer Heats but won't tumble
do you hear a humming noise? and is air coming out the rear if so the belt has broke if not the motor has gone bad let me know what you find
Jan 08, 2008 | Whirlpool GEQ9800P Electric Dryer
Dryers Logo
51 people viewed this question
Top Dryers Experts
