Question about SanDisk Cruzer Micro 4GB USB 2.0 Flash Drive
4 Gb Sandisk flash drive won't read and won't format. When I put it in Win7 comes up and says that it must be formatted before it can be used, but when I try to format it, Windows gives one of its usual cryptic and unhelpful error messages that the format attempt failed. The disk was working fine until I tried to make a Linux boot disk out of it.
  • 1,606 Answers
I've had some luck getting this to work again by using the linux ext2 format utility to format it back to the windows fat16 format, then use windows to format it again. There is something that windows doesn't like about the fat table when ext2 does it so you need to do this double format. Doesn't work all the time but does quite a bit.
Posted on Apr 04, 2011
How i format 8 gb usb sandisk
Usually, it comes formatted. However, you can re-format it (e.g. on a PC or Mac) using the usual disk format utilities, if you don't need any special/specific (SDHC) format features.
For instance, on a PC ... insert the USB SanDisk into a USB port. It will show up as a (storage) device on your "My Computer" window. Highlight that icon ... (put the cursor over it) ... and put your cursor on the FILE (menu) tab and click on it. It will display a drop-down menu with "Format" on it.
Click on the "Format" and it will guide you through the formatting process.
On a Mac, when you insert the USB SanDisk into a USB port, it will show up as a device on your desktop. You can use the "Disk Utilities" software (usually in the Applications - Utilities folder), to format it.
Jan 19, 2014 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Andiyi had a memory card of sandisk 8 GB in which the windows was unable to format?
never don't use windows utility for flash drive formatting. use only manufacture's format utility. http://kb.sandisk.com/
Aug 17, 2011 | SanDisk 4GB microSD High Capacity Memory...
This Disk is write protected
Hi!
if you use Windows XP or earlier, then - right click on your flash drive, goto "properties" -> uncheck "read only" checkbox.
If you use Win 7 or Vista - then use administrator account to run format (shift+right click on program, choose "run as administrator" ). the easiest way in Win7/Vista to format your flash drive is: Start -> all programs -> Accessories -> shift+right click on command prompt -> "run as administrator" -> type fromat driver_letter /q /y and press enter (e.g. if your flash driver has letter z, then you need to type format z /q /y and press enter). This will quickly format your flash drive.
If you use Linux/Unix/MAC OS, then you can use GParted or following command in terminal:
1. su
2. Enter password when asked
3. fdisk /dev/your_flash_drive_name (e.g. dev/sda/)
mkfs -t vfat /dev/your_flash_drive_name
Hope that will help :)
Jul 02, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
2GB Cruzer Micro USB Flash Drive (SDCZ62048A10) Hard Drive: i just bought a 16 gb sandisk flash drive. i took...
go to my computer, plug the drive in, right click the flash drive icon on my computer and click format.
May 18, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I just purchased an 8 GB flash drive sandisk and when I went to download my outlook, which is a little ver 4 gb, it is telling my I don't have enough space on the flash drive. I literally just opened it....
Try doing a full format of the drive. (Right-click on drive => Click format).
If you have the option format using the NTFS file system (default in vista/windows 7) and make sure to uncheck "Quick Format". Remember to back-up your data on the drive beforehand.
If this doesn't solve your problem the flashdrive itself may be faulty. Return it and have it replaced.
Hope this helps,
-LL
Feb 24, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
How format SanDisk cruzer Micro 8GB
copy the files to you're pc, and if you use windows just go in my computer and right click on the flash disk icon and click format check the quick format box and the press format.
Jun 14, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Can't open my sandisk cruzer 16gb
i have a 16 gb pendrive which is detected in my mac but not in any windows...............help me out here
May 10, 2009 | Electronics - Others
Hello, i have an 8 GB flash drive (Sandisk micro Cruzer U3) and the light will pulsate at about 3 flashes per second and it will not be recognized by my computer. then ifi short circuit it to fix it then...
hello i have a solution for you
go to
start menu>
all programs>
run>
type cmd
if your pandrive is g then
type in dos window
format g:
in case your drive is f then
format f:
follow the process
if you are using windows vista then you can also solve by another process
right click on my computer>
manage>
disk management>
right click your drive and click on format
Apr 11, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Sandisk 4gb memory card w/adapters
oh! too sorry for that..you have formatted your card and you cannot put the files back.. but after you have formatted it is the problem had been solved?
Feb 23, 2008 | SanDisk Memory Media
SanDisk Cruzer Micro 4GB USB 2.0 Flash Drive Logo
1,165 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
