Question about Belkin (F5D8235-4) Wireless Router
What is the WPS security code for Belkin model f5d8235-4 v2
3 Suggested Answers
Tom Marvolo
  • 708 Answers
SOURCE: Can't turn on WPS on Belkin G model #F5D7230-4router
The version number of the router is not specified ???
Step 1 : Open RSP by typing 192.168.2.1 on the address bar of internet explorer
Step 2 : Check if there is the option Wi Fi Protected setup under wireless
Step 3 : If it is there Enable it and click apply changes
Posted on Jan 07, 2010
SOURCE: Belkin wireless router model F5D7634-A-v2 How
Access the web interface of the router using your internet browser (type 192.168.2.1 in the address bar and hit Enter).
Click on the Wireless tab
You should either have a Key, or a Passphrase in there.
Posted on May 13, 2011
Where is the wps button on a N 1 Belkin route?
Using Wi-Fi Protected Setup
WPS uses WPA2 (described below) for encryption. It does not
provide additional security, but rather, standardizes the method for
securing your wireless network. You may use either the Push Button
Configuration (PBC) method or PIN method to allow a device access to your wireless network. Conceptually, the two methods work as follows:
PBC: Push and hold the WPS button located on the back of your
Router for three seconds. Then initiate the WPS procedure on the client device within two minutes. Refer to your client's documentation on this procedure. Pushing the PBC button will automatically enable WPS. The client has now been securely added to your wireless network.
PIN: The client device has a PIN number (either four or eight digits)
that is associated with WPS. Enable WPS through the GUI shown
below. Enter the client's PIN into the Router's internal registrar
(accessed through this GUI). The client will be automatically enrolled
into your wireless network within two minutes.
Oct 04, 2014 | Belkin (F5D8231-4) Wireless Router...
Where is wps on Belkin n1 vision?
Before you will be able to use this function, you will have to log into your router and enable WPS push button in the security settings.
PBC: Push and hold the WPS button located on the back of your N1
Vision for three seconds. Then, initiate the WPS procedure on the client device within two minutes. Refer to your client's documentation on this procedure. Pushing the PBC button will automatically enable WP
Aug 21, 2013 | Linksys WRT160N Wireless Router
My belkin G+ wireless router model: F5D9231-4 v2 security is lock and i cant log into my laptop
If you have forgotten the password, reset the Belkin by pushing and holding the reset button for 30 seconds or so and release, this will reset to default settings. Connect and reconfigure the SSID and Security Key. You may want to write down the password and store for future use. Belkin Support: http://www.belkin.com/us/support-article?rnId=6939
Dec 27, 2012 | Belkin (F5D7231-4) Wireless Router
How can i connect my psp to my belkin wireless router.... My psp cant seem to detect it , other networks get detected but when I use my belkin it says no access point detected. Plsss help thanks.
Your PSP does not support the WPS feature on the Belkin router. The solution is to turn WPS off. WPS can be disabled in the configuration program for your router.
You do not need WPS it is simply a protocol to make conection to some modern devices simpler.
Feb 09, 2011 | Belkin F5D7234-4 Router
Can i connect belkin to belkin through dsl modem and how
Yes, you can connect:
DSL modem WAN/Internet port on Belkin #1
LAN/network port on Belkin #1 WAN/Internet port on Belkin #2
LAN/network port on Belkin #2 your computer
If the two Belkins are in different rooms, and there are more than one computer in the room with Belkin #2, it makes sense to run ONE (not MANY) Ethernet cables from Belkin #1 to Belkin #2.
Nov 19, 2010 | Belkin Basic Wireless Router
HOW CAN I GET THE WPS ACTIVATION ON MY BELKIN G MIMO ROUTER TO CONNECT IT TO A WIRELESS PRINTER?
to make ur printer go wireless its advisable to keep the WPS in the router disabled and activate the security mode WEP instead of WPA in the router. this will solve all the wireless connectivity issues with the printer.
Aug 12, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Jan 04, 2010 | Belkin (F5D7230-4) Router (587009)
Where and what is WPS pin from my belkin router? Im tring to set up a new kodack printer
You can find the WPS Pin number from the belkin router at the bottom you will have label it will be in the label.
This is a security for your wireless network
Regards,
Ayyasam
Nov 27, 2009 | Belkin (F5D7230-4) Router (587009)
Im trying to set security on belkin n router
Hi...if your router has WPS capability, such as a special button to set up wireless security, then to use it your client computer/device must also be WPS enabled.
If it is, there are usually two options to configure WPS security: the push button method, or the PIN number. The push button method usually requires that you press the WPS button on the router, then within a set time, press the equivalent button on the computer (eg laptop, or whatever device it is). The PIN number method requires a PIN to be entered into the client computer. The PIN can sometimes be found on a sticker on the router.
Your manual should help with the details, but see this page for some more info.
http://kbserver.netgear.com/kb_web_files/n101691.asp
If you don't have a WPS enabled computer or don't want to use it, you can set up security manually. Please come back to Fixya if you'd like help with this.
Dec 29, 2008 | Belkin Wireless Pre-N (F5D8230-4) Router...
Belkin (F5D8235-4) Wireless Router Logo
177 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
