Question about Mach Speed Audio Players & Recorders
When player is turned on, shuts off. also this player has never played more than 3 songs before shutting down.
  • 31 Answers
Sounds like the battery is bad and needs replaced
Posted on Apr 04, 2011
5 Suggested Answers
mattozan
  • 555 Answers
SOURCE: Shuts Down
My MuVO TX was having problems until I installed the latest firmware. The last firmware release was in March 2007. If you haven't updated the player's firmware since then, try downloading it and installing Creative MuVo TX FM Firmware 1.24.02.
Posted on Nov 08, 2007
ThaMp3Doctor
  • 8596 Answers
SOURCE: help
Use the reset method - hold the power button in for 15-20 seconds. If that fails:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 26, 2008
SOURCE: Sansa e250 MP3 player won't turn off
Press and hold down the menu button for 15 seconds.....that what the manual says to do.
Posted on Sep 12, 2008
parqour16
  • 23 Answers
SOURCE: Two problems 1)My sansa clip shut down on its own
Its not usles, you can delete the files while on the computer. After having in plugged in you can access it like a flash drive. Then you can open the music folder and delete as you will. Depending on what kind of files you have on it, its possible that i wont recognize the format of the file. I think though from what you've said that it did work, and then stopped playing songs that worked before. So I don't know what to do about that. I don't use the normal way of loading songs onto my Sansa clip MP# player though. I just dump all of my songs via direct transfer into the music folder in the player itself
Posted on Oct 05, 2009
How do I bookmark or save my place in an audio file
Try and press pause before you shut the player off.
Mar 30, 2010 | Coby MP-610 MP3 Player
Two problems 1)My sansa clip shut down on its own and when I turned it back on all files were erased. When plugged into the computer the media player still showed 3/4 of the memory still used on the clip...
Oct 04, 2009 | SanDisk Sansa Clip MP3 Player
Failure to shut down when playing one cd.
Try checking the control and try pressing repeat. Maybe its in repeat mode. Oh...fast forward and you won't need to wait to Check it out. Let me know...
pita3obn
Jan 06, 2009 | Bose Wave music system Multi-CD Changer...
I have a ml648b gpx digital audio player. When I syn a song it will only play 10 seconds of each song Any ideas
mine did that and it was a preview of a song I needed to wait until the entire song downloaded and my problem went away
Dec 30, 2008 | GPX ML648B MP3 Player
Sansa shutting off during song
this is normal for this player - it goes to sleep fairly quickly - se p.35 of manual to see how to change frequency of shut off
Apr 18, 2008 | SanDisk Sansa e260 MP3 Player
Sansa c140 screen frozen
Try a "hard reset". Press and hold the power button for 15 seconds to shut off. With the device off, press and hold the vol + and the center select button. Power it back on, see if that works. You can add to the question if you have more questions. Best of Luck.
Sep 27, 2007 | SanDisk Sansa c140 MP3 Player
RCA stands for Really Crappy Appliance!!
yeah you have to slide the power button and hold it for awhile.
Sep 09, 2007 | RCA TH1101 MP3 Player
Playing songs
Did it always do this...if so it may just be the way the unit was built... a way around this is to turn on shuffle so even when it starts at the begginging you dont hear all the same songs over and over.
Mar 24, 2007 | RCA RD2826 MP3 Player
Device keeps shutting off by itself and won't synch
Make sure the songs are in the right format. Napster is a real bear about disappearing songs - try another music svc.
Oct 11, 2006 | SanDisk Sansa e270 MP3 Player
141 people viewed this question
Top Mach Speed Audio Players & Recorders Experts
Gyula Lacz
Are you a Mach Speed Audio Player and Recorder Expert? Answer questions, earn points and help others
