Question about Dryers
When you turn dial on and shut door timer make clicking noise but doesnt tumble.You can turn motor by hand and belt isnt broken.
  • 10,319 Answers
You have current going to the timer so the timer is at fault and needs to be replaced. they are expensive so if he dryer is 7 years of age or older I would purchase a new dryer instead
Posted on Apr 04, 2011
Why doesn't it start?
other than the timer noise, do you hear anything else?
is motor turning but a broken belt possibly?
Nov 24, 2015 | Kenmore Dryers
What could possibly the reason my amana dryer wont tumble and just buzzes when you push the start button
Could be a broken belt spin the tumbler by hand it if it spins real easy the belt is off or broke another thing to try if you have resistance when turning the drum have a helper for this one open the door and hold the door switch in set timer to a cycle and press start while holding switch and buzzing spin drum and see if it will continue to rotate while holding switch if so motor going bad
Feb 17, 2015 | Amana Dryers
Frig. gas dryer agq6000es not tumbling
Do you hear the motor running? With door closed.
Most dryers will spin though a little hard to do so. If it spins VERY easy the belt is possibly broken.
If the dryer is several years old it Could be the belt.
Also check for a switch for the door, if there is one.
Door switch would shut off dryer when opened.
Nov 29, 2013 | Frigidaire AGQ6000ES Gas Dryer
Whirlpooldryer LEN2000PW1 when you shut the door turn the dial you hear a clicking sound and doesnt tumble. Belts not broke and you can turn motor manuelly.
This is a symptom of a blown thermal fuse located on the blower housing. It is wired in series with the motor and therefore cuts power to the motor when it blows and results in the motor not running. No dryer function works when the motor is not running. Remove the rear access panel and locate the thermal fuse. Replace it if found blown open including the cycling thermostat. Click on the link below for the detailed troubleshooting procedure.
Troubleshooting Not Starting Whirlpool and Kenmore Dryers
Apr 04, 2011 | Dryers
My dryer won't tumble. The Timer works and I have unplugged and replugged from outlet. The door is shut all the way. It won't tumble
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley.
If you have to check/replace/repair your drum motor or belt and if you have a front loading machine:
Note: This method works for most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the screws that hold the filter housing.
Then remove the top of the dryer.
Note: Some of the tops tilt backwards and do not have to be removed completly.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
Please rate me
Sep 18, 2010 | Roper Dryers
Dryer Does Not Tumble When Pressing Start
Hi,First of all check your door switch, make sure it is operational.If the door switch checks good, the start switch could be faulty, in newer dryers the start switch is built into the timer in older dryers your start switch may be separate, if you have to push on the timer dial to start the dryer, its built into the timer.
Check any other safety's that may be stuck open.Double check anyway. If it wont do anything, I would say its the door switch or the start switch.
Thank you
May 10, 2010 | Frigidaire GLEQ2152ES Electric Dryer
ELECTRIC DRYER WON'T TUMBLE
Possibly the belt assembly. if you open the door and try to turn the drum does it turn with a little resistance, noises? this model has rollers, pulley, and a four groove belt 92 1/4" , sometimes the pulley sticks after yrs of use, belts wear, drum misaligns. the humming should be the motor trying to work.
Feb 03, 2009 | Whirlpool LER7646E Dryer
Tumble dryer makes whine noise but doesnt spin
Sounds like the drive belt has gone,and the noise you can hear is the motor going round.
The red glow you can see, will be the heater element glowing..
To check the belt, remove top cover, and you will be able to see if the belt is on or not, if you can see it round the drum, try to lift it up, if it has not broken,then you will not be able to remove it, and that means the motor or drum could be siezed, try to turn the drum by hand, it should be fairly stiff to turn, but not that stiff that you cannot turn it at all.
Please rate my fixya solution.
Thanks.
Feb 01, 2009 | Hotpoint NWXR473EV Dryer
My dryer will not start. It is not locked. I've turned it off and unplugged it for 30 minutes. All the buttons work fine, but the timer just flashes when I push the start button. Help!
If dryer does not spin it is usually a problem with the belt or the motor. Check also door switch.
See also following indications from Repairclinic:
It won't tumble If your dryer doesn't tumble, check these:
Belt
Motor
Door switch
Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
Click here for a belt installation diagram.
Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Aug 27, 2008 | Whirlpool Dryers
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
