Question about Sanyo DVD-SL20 DVD Player
Power wont stay on powers on and off every 90 seconds
My emerson wont stay on for more than a second
Check its power regulator board. Repalce it as card basis.
Apr 22, 2012 | Televison & Video
Hi, my travelmate 737 (just got it) wont turn on when power is connected, is there a power button? thanks
try this
take out battery
disconnect external power source
hold power button for 60 to 90 seconds
then reconnect everything
then try to power it on
Oct 16, 2010 | Acer TravelMate 737TLV Notebook
Wii wont power up. wall outlet has power
Ok, first, make sure the plug (that connects your Wii to the power outlit) in the back of your wii is fully in. It may have gotten lose. If its lose plug it in, and then check to see if the light is on or not. If it isn't, unplug the same cord, and blow into it (it may have gotten dusty). Now, if that doesn't work either, unlpug your wii from the power outlit, and plug something else in (there could be something wrong with the outlit) if the other thing works, and your wii still won't work, call Nintendo (their number can be found on the game cases).
The AC adapter on a Wii takes 90 seconds (minimum) for it to reset properly - not 30 seconds. Since if you're standing there waiting for it to reset, 90 seconds is actually longer than you may think. Time it out and wait a minimum of two minutes to ensure it has been completed.
As always, a surge protector will always be recommended to try and minimize actual damage from occurring. Even if this is done, you likely will need to follow the aforementioned power reset steps.
Dec 05, 2009 | Nintendo Wii Console
I turn my iphone on but it wont load up the apple stays on cant do nothing
Turn iphone off. Power on holding power and home at same time for 10 seconds, then release power button but hold home for another 30 seconds. Screen will stay blank but should be in DFU recovery mode. Plug into iTunes and recover.
Nov 10, 2009 | Apple iPhone Smartphone
Wii menu will not come on when power is turned on.
Do you hear any sound when you power the console on? I assume it used to work fine? Try disconnecting all cables from the back of the Wii, waiting about 90 seconds, reattach all cables and power on. Does the power light go to green?
Jun 24, 2009 | Nintendo Wii Console
My wii won't turn on
You likely had a power failure. You need to reset your AC adapter. Here's how:
  1. unplug the power cord from the wii. Unplug the adapter from your surge protector or the power outlet.
  2. wait 90 to 120 seconds. (Some people say to wait 30 seconds. Wrong! At least 90 secs is required for the AC adapter to rest.
  3. plug stuff back in and you're good to go.
NOTE: electronics like your wii, ps3, etc should be protected from power surges and power failures! Plug them into a good surge protector. Always!
Jun 27, 2008 | Nintendo Wii Console
Cartridges will not stay in & cannot see the device in 2003 enterprise
Turns out the PSU unit was weak. It couldn't provide the power needed to spin up the disks when inserted.
Problem Solved.
Apr 06, 2008 | Iomega REV Tape Drive
Sanyo DVD-SL20 DVD Player Logo
19 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
