Question about Dacor Epicure ERD30 Dual Fuel (Electric and Gas) Kitchen Range
Range door so whats the fix?
  • 2 more comments
  • bbsb Sep 23, 2008
    I'm not sure if this is what was meant, but on my range the door does not close correctly. The bottom appears to be too close and causes the top to not close flush with the opening. Is there a service procedure for adjusting the door?
  • Anonymous Dec 20, 2008
    Oven door removal
  • mjand3 Feb 05, 2009
    I also have had the same problem with the door looking "ajar"-not quite closed (flush) as I think it should be...the bottom of the door seems tight and the top gaps open-though it doesn't emit heat from the side opening...should be safe I guess. Does anyone else have this problem?
  • J Miller Apr 30, 2013
    Same problem, there is a uneven gap on the door that increases on the way up. How do you adjust the door to be even?
  • 639 Answers
FOR WHAT????????????????????is the problem?
Please describe it!!!!!!!!!!!!
Posted on Aug 24, 2008
Oven shuts off after closing door
Have you put a thermometer in the oven to make sure it is not heating. They will not always glow red if the oven is at temp.
Feb 12, 2014 | Hotpoint RB757 Electric Kitchen Range
Failure Codes
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^&^%$#
Apr 19, 2010 | Kenmore 95002 / 95004 Electric Kitchen...
Getting error code 9-6 on MER6770AAW maytag gemini double oven range...what and how to fix?
That code is for obstruction in the lower door lock mechanism. You need to check for a obstruction in the lower door lock. The next step would be to disconnect the power for a few minutes then turn it back on and see if the code reappears.
Feb 23, 2010 | Maytag MER6772 Gemini Electric Kitchen...
Model JGR8855ADS is reading Code F9. what does
Hi There
I have this code for you. hope this helps you.
F9 Door latch Check door latch components.Thank you for writing to fix ya.
Best Regards Richard
Feb 18, 2010 | Jenn-Air JGR8750 Gas Kitchen Range
Getting F9 Code & beeping
Hi. this fault code represents a door latch fault. You will need to inspect the door latch components. Once this issue is fixed, it will start to work normally. Its nothing serious like a control board or power supply board. Its juts that the door latch components are malfunctioning.
please rate and god bless..
Mar 24, 2009 | Maytag MGS5770 Gas Kitchen Range
Whirlpool oven door won't unlock after cleaning
The motor that controls the door lock was bad. Go online and order a new motor based on range model number. User can fix if reasonably handy with tools.
Feb 05, 2009 | Whirlpool GR460 Electric Kitchen Range
Jenn-air gas electric grill range
any power to unit at all?? clear, start, clean ,button?? what happens when you push them??? clock on?what happens when you try to set to clean again??? it should activate hte door lock latch at which point cancel and it should reset itself. with any luck! what happened thankgiving how was it fixed
Mar 14, 2008 | Kitchen Ranges
Viking Range oven door does not close properly
sounds like the door hinges need replaced. order a part #PC020009 qty 2
Jan 12, 2008 | Viking VDSC365-6B Dual Fuel (Electric and...
Dacor Epicure ERD30 Dual Fuel (Electric and Gas) Kitchen Range Logo
94 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
