Hello. I have a Hayward Pool Heater - model number 36C68. Other info on the unit says type 818 and also p/n 1500989801. I need to get a schematics and manual for my plumber to repair it. Can you tell me how I can get this?
    Brigadier General:
  • 4,736 Answers
Here is a link to Hayward Pool Heaters - Owners Manuals page. Click on Pool Heaters and then locate yours by the model number. You'll then be able to download and print the manual.
http://www.hayward-pool.com/prd/In-Ground-Pool-Manuals_10201_10551_14502_-1_14003__I.htm
Posted on Apr 04, 2011
Hayward H200P1 Pool Heater- need to convert propane to natural gas
all the parts needed will be in the kit. usually, its the control valve and the jets that get replaced. my manual shows its the same part all units. HAXCNK0002
Aug 09, 2014 | Hayward H Series Pool & Spa Heater 200k...
H250 hayward pilot series
Those particular heaters can be tricky because they came a few different ways, including a millivolt to electronic spark conversion that was done on site.
Your best bet is to get an old pool tech out there to see if they can get it fired up. The variables involved are far too extensive to troubleshoot in this format. Good luck with it.
Jul 02, 2013 | Hayward H Series Electronic Ignition...
Can I change out a Hayward H400ID with an electric heater for the spa only? If so what electric heater product brand would you recommned. Raypak?
Hayward has manuals for each type heater, gas and electric.
http://www.hayward-pool.com/prd/In-Ground-Pool-Manuals_10201_10551_14502_-1___I.htm
Hayward also has contact page, and can probably recommend correct change-over product.
You want to switch from propane to heat-pump type.
There are likely 3 areas of difference. Read each manual and generally look for 1) unit size and capability to match spa 2) pipe connections and sizes 3) Electrical requirement
From electrical standpoint, You need GFCI-protected line from circuit breaker box, or GFCI (arc-fault) breaker. This will prevent electrocution risk around spa.
http://waterheatertimer.org/How-to-wire-GFCI.html
Wire sizes are based on volts and watt-rating of heater.
Each electrical device has rating plate showing volts and watts.
3500 watts divided by 240 volts = 14.5 amps so install double-pole 20 amp breaker and use 12 gauge wire.
1500 watts divided by 120 volts = 12.5 amps so install sinle-pole 20 amp breaker and 12 gauge wire.
http://waterheatertimer.org/Color-codewire.html
Oct 28, 2012 | Raypak Spapak Electric Spa Heater -...
I purchased a used Hayward H100id1 pool heater and lost the instructions. How can I get a manual with install instructions and how to use it?
Here is a copy of the users manual for these pool heaters. It should have all of the installation info that you need.
http://www.backyardcitypools.com/images/Hayward/H100-Manual.pdf
Jul 04, 2011 | Hayward 100,000 BTU Pool Heater H100ID1 -...
I am looking for a WIRING SCHEMATIC for the Hayward 5060 booster pump MOTOR. A wire came off and I cant find where to replace it.
Please comment with the motor manufacturer and the model and serial number off the motor nameplate. It is likely an AOSmith motor and the info will be somewhere on the motor frame.
John
Aug 25, 2010 | Hayward Pool & Spa
Hayward H series pool heater diverter plate moves
next to the water inlet oulet is got to be either two bolts or a silngle big plastic nut all depens on the model take off when system is off!!!and replace if needed
Sep 03, 2009 | Hayward H Series Pool & Spa Heater 400k...
Heater won't stay lit
On your main gas manifold you have orfaces that screw into it at each burner. Remove these and see if their are small spider webs in them. They will look like little lint balls. They can keep your main burner from getting gas and in turn keep the heater from sensing flame. The pilot lights and the heater starts but no flame at the main will shut it rite down. See if this helps.
May 05, 2009 | Hayward H Series Millivolt 250,000 Btu...
Heating & Cooling Logo
238 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
